Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| GPGIndustries Support section The Best of GPGIndustries |
| | #61 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2005 Age: 29
Member: 138583 Status: Offline Thanks: 111
| Hi. There are some ¨iphones¨ becoming so popular, and some others china phones. Can u make a set of this popular cables??? For example i68, Mini iPhone, P168C, CECT i9, KA08, 95 RM.17.... Can u make a nice set???? I need it urgent!!!!! |
| | #62 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Sep 2004 Age: 28
Member: 81703 Status: Offline Thanks: 841
| I got a possible idea. Many of us have had problems with UFC when the phone it's N78, 5800, 2630 and so on. With this new phones it's quite difficult to put the battery tweezers so, the idea it's the follow I did with paint. It can be a big tweezer or like in the pic with two screws and nuts. The idea it's use the pins of normal cables for this phones, with a connection to the normal tweezers By using this method the connection will be good and tweezers won't jump. This adapter could help a lot people. The main issue it's that it can't be really big or we must be careful because of the other tweezer(for the 5-7 pins) to do not touch between them. If someone can do this it's GPG BR Luskao |
| | #63 (permalink) |
| Super Moderator ![]() Join Date: Jan 2009 Location: England Age: 48
Member: 947561 Status: Offline Thanks: 2,690
| if you consider all the battery contacts are the same you can use this little trick: cut carefully one old battery (in my one i used a 6500s battery dead) so you can keep the three contact together. Just connect 3 wires to them and connect at the end of the three wires an old nokia battery block (I used one of a 3310 in mine) The battery bit fits in the mobile properly without giving you problems when you set the UFC and just connect the tweezers to the extended connector. BR Alex |
| | #64 (permalink) |
| This is the cable for usb powered v3 miniUSB 1. +5v 2. data- 3. data+ 4. short to 1 pins(or use resistor 390k for example). 5. GND. USB - from PC. 1. +5v 2. data- 3. data+ 4. gnd. Can also u make it for v60, sony ericsson, etc? Its very usefull.... No more problematic bateries.... |
| | #65 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Dec 2006 Location: Glasgow
Member: 410814 Status: Offline Thanks: 2
| My Firmware for my KA08 Mini TV: SW-ZZT.TV400PO3.5.2 - MB01 made by a company called wbt and is called an N8 (under battery) Is there a firmware upgrade for this phone? and a how to... thanks! |
| | #66 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2008
Member: 755804 Status: Offline Sonork: aaa Thanks: 168
| 1. Can you make high quality RJ45 cable set for spiderman?? 2. Can you make high quality stickers with big letters for our old Nokia service cables like on new GPG Cables so it will be easier for us to find them? |
| | #67 (permalink) |
| Junior Member Join Date: Oct 2009
Member: 1142463 Status: Offline Thanks: 0
| I dont know if u have maked, but its very useful the cable for motorola that make the phone power on without need of battery (Directly to usb connector).... Or maybe also an adapter for normal cables to convert it on energy cables for power on.... My hw technician maked that but just work one day and after that nothing, tried 2 times.. Regards Olympus ____ dossier surendettement |
| | #68 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2004 Location: Pakistan Age: 35
Member: 68392 Status: Offline Sonork: 100.100701 Thanks: 506
| TMA Second Edetion I MOdify my TMA adapter with push on/off 6pin switch how i use show in pic when switch push down work with MT box 10 pin cable normaly when switch push up use at Mt box with 10 pin jack in Mt your 10pin cable as 7pin cable Also work here your normal 7pin cable mean no need other adapter for use 7pin cable put 10pin jack of Tma in Jaf for use use your 10 pin cables as 7pin at jaf. Bsi resister should be use as need a phone. |
| | #69 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks: 803
| Hi GPGIndustries! I was thinking about this cable from a long time. So this Sunday, I decided to make a picture of it and post here, so if you think it worth production, please make it. This concept has a TP Connector as seen in UFC for Samsung Phones which are available in market. I don't want to purchase separate cables for each of them as they have same TP Pinout but only placing or orientation has changed. This Idea can help users to use only one cable for these phones. Some of them are following: C140(i) C160 C260 C266 B239 B259 B279 B189 and many more... Also, if added two VPP and GND with extra RX and TX probe, it will help us to connect other phones which have TP connection. This cable will be compatible with UniBox pinout (Infinity, ET-Box etc.) and if you can, also make a Direct USB -> COM cable so if any user don't have these boxes, can use it too. Please have a look at the attached PDF. Awaiting kind response... Br, Shadab Ahmad |
| The Following User Says Thank You to [Shadab_M] For This Useful Post: |
| | #70 (permalink) |
| Hi GPGIndustries! Can you please produce SE USB Cables with VBAT Clip so we do not need battery any more while flashing with SETOOL or other tools? Only one VBAT Clip with traditional SE USB Cable. It could also made for Nokia Phones. Even if we can use UFC Supply clips with USB cable but this is not that comfortable. For Nokia phones, you have to add only three Clips (VBAT, BSI and GND) with BSI Resistance Selector. It will be really helpful for users who often use USB Interface for flashing. And yes, if you provide all three types of USB ports (MiniUSB, DKU-2 and MicroUSB) in single cable, It will be really FANTASTIC. ![]() Br, Shadab Ahmad |
| | #71 (permalink) |
| Junior Member ![]() ![]() Join Date: Jun 2006
Member: 294418 Status: Offline Thanks: 11
| its very difficult to find a cable from many type so i need to hang it after some time rj45 connector got broken can you add some hook to all new cable so we easily hang without got broken. THANKS |
| | #72 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2007 Location: nothing
Member: 494167 Status: Offline Thanks: 449
| i have also one idea.i dont see dream box cable in this new section.so waiting for good quality cable set for dream box. ufs,jaf and nspro have same cable pinout.and all other using unibox inter face as like infinity box.ust pro2,furious gold,microbox,multibox,and many other have same box pinout. |
| | #73 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2004 Location: Poland, Wroclaw Age: 39
Member: 67562 Status: Offline Sonork: none Thanks: 161
| Seems thread dead... What about http://w*ww.gpgufc.com ? Site is not updated for long time, where is some patron? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| please help us with ZTE A301 UNLOCK | kfkevin | Infinity-Box | 1 | 01-04-2010 16:22 |
| Help us with language packs description | Multi-box TEAM | Multi-Box | 59 | 06-25-2007 13:12 |
| Who will help us in S-46 unlocking and repairing? | kingofhearts | x1x to x45/x50 | 3 | 04-23-2003 12:04 |
