Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section
GPGIndustries Support section The Best of GPGIndustries
Old 04-01-2010, 15:21   #1 (permalink)
c1rca's Avatar
Member: 751758
Question Problem with "GPG UI with UFS inside"
What to do if GPG interface with UFS inside doesn't check/flash any BB5 Nokia? After pressing "Check" button always gives error "unexpected exeption: division by zero". But DCT4 is working fine "Check" and "Info" etc.
HWK update, ufs drivers, req->fbi, UFS eeprom are ok. Tried to connect directly to USB port and to USB hub with external +5v - no difference. USB cable is ok (tried 3 pcs).
Old 04-01-2010, 15:34   #2 (permalink)
fr3nsis's Avatar
Member: 190882
Sonork: 100.1593148
Problem with new microhwk (diviion by zero)
for me was occurred on microhwk , replaced because under warranty ...it's hardware problem
The Following User Says Thank You to fr3nsis For This Useful Post:
Old 04-01-2010, 15:53   #3 (permalink)
c1rca's Avatar
Member: 751758
thanks, i'll try to do as described
Problem Using JAF InterFace With MXKey irfanamin2 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 04-01-2010 13:23
problem with POTATO BOX and ufs with new update pls billycomm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 03-21-2010 16:56
i have problem with flashing e600 with ufs-3 petcy UFS2 + UFS3-Tornadoflasher 1 12-14-2004 15:54
i have problem with flashing e600 with ufs-3 petcy UFS2 + UFS3-Tornadoflasher 3 12-07-2004 18:58
Problem Activating Ufs-3 with serial started with 46xxx !! CMV_2K UFS2 + UFS3-Tornadoflasher 3 11-19-2004 11:49
Page generated in 0.21869 seconds with 11 queries
