GPGIndustries Support section The Best of GPGIndustries |
04-01-2010, 15:21 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Location: Location:
Member: 751758 Status: Offline Thanks Meter: 113 | Problem with "GPG UI with UFS inside" HWK update, ufs drivers, req->fbi, UFS eeprom are ok. Tried to connect directly to USB port and to USB hub with external +5v - no difference. USB cable is ok (tried 3 pcs). |
04-01-2010, 15:34 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Rome , Italy
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | http://forum.gsmhosting.com/vbb/f311...n-zero-591134/ for me was occurred on microhwk , replaced because under warranty ...it's hardware problem |
The Following User Says Thank You to fr3nsis For This Useful Post: |
Problem Using JAF InterFace With MXKey | irfanamin2 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 04-01-2010 13:23 |
problem with POTATO BOX and ufs with new update pls | billycomm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-21-2010 16:56 |
i have problem with flashing e600 with ufs-3 | petcy | UFS2 + UFS3-Tornadoflasher | 1 | 12-14-2004 16:54 |
i have problem with flashing e600 with ufs-3 | petcy | UFS2 + UFS3-Tornadoflasher | 3 | 12-07-2004 19:58 |
Problem Activating Ufs-3 with serial started with 46xxx !! | CMV_2K | UFS2 + UFS3-Tornadoflasher | 3 | 11-19-2004 12:49 |
