problem whit gpg universal interface whit jaf... Some users have reported problem in universal interface whit jaf pkey (jaf dont see pkey) how to solve this? Many thanks. |
pkey card slot behind.. open casing behind |
my problem is that jaf dont see the pkey, i have in the internal slot setool and ust-pro2 and on external slot the pkey , setool and ust work whitout problem, jaf box work but pkey card is not recognized at all... |
hello br uninstall p key drivers and put ur p key card in uni box and then install drivers and plug ur box !!! hope u will solve ur porblem ! br jass |
Same here with UFS+UI the external sim reader did not detect the card i inserted.It suppose to work together with UFS |
Tell us in which socket you put the simcard. Remember that you can't put a JCOP card in an AXALTO reader. This means JAF Pkey can be loaded only in JAF slot, also check that the switch it's in the correct position Regards Luskao |
to Luskao What to do if GPG interface with UFS inside doesn't check/flash any BB5 Nokia? After pressing "Check" button always gives error "unexpected exeption: division by zero". But DCT4 is working fine "Check" and "Info" etc. HWK update, ufs drivers, req->fbi, UFS eeprom are ok. Tried to connect directly to USB port and to USB hub with external +5v - no difference. USB cable is ok (tried 3 pcs). http://img122.imageshack.us/img122/8900/556677.jpg |
Lords which is the pinout of this box to work many thanks in rj45 cables that are compatible |
