Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section
GPGIndustries Support section The Best of GPGIndustries
Old 10-18-2009, 19:10   #1 (permalink)
Member: 137234
Exclamation problem whit gpg universal interface whit jaf...
Some users have reported problem in universal interface whit jaf pkey (jaf dont see pkey) how to solve this?
Many thanks.
Old 10-18-2009, 22:14   #2 (permalink)
iwan8818's Avatar
Member: 859702
Sonork: 12345
Many thanks.
whats your problem friends?
pkey card slot behind.. open casing behind
Old 10-20-2009, 12:38   #3 (permalink)
Member: 137234
my problem is that jaf dont see the pkey, i have in the internal slot setool and ust-pro2 and on external slot the pkey , setool and ust work whitout problem, jaf box work but pkey card is not recognized at all...
Old 10-22-2009, 08:55   #4 (permalink)
GSM-FUTURE's Avatar
Member: 230831
Sonork: 100.98820
hello br uninstall p key drivers and put ur p key card in uni box and then install drivers and plug ur box !!! hope u will solve ur porblem !
br
jass
Old 11-22-2009, 23:28   #5 (permalink)
fretburner's Avatar
Member: 45571
Same here with UFS+UI the external sim reader did not detect the card i inserted.It suppose to work together with UFS
Old 11-24-2009, 21:45   #6 (permalink)
Member: 81703
Tell us in which socket you put the simcard. Remember that you can't put a JCOP card in an AXALTO reader.
This means JAF Pkey can be loaded only in JAF slot, also check that the switch it's in the correct position
Regards
Luskao
Old 03-31-2010, 15:41   #7 (permalink)
c1rca's Avatar
Member: 751758
to Luskao
What to do if GPG interface with UFS inside doesn't check/flash any BB5 Nokia? After pressing "Check" button always gives error "unexpected exeption: division by zero". But DCT4 is working fine "Check" and "Info" etc.
HWK update, ufs drivers, req->fbi, UFS eeprom are ok. Tried to connect directly to USB port and to USB hub with external +5v - no difference. USB cable is ok (tried 3 pcs).
Old 09-01-2010, 17:10   #8 (permalink)
fabicel's Avatar
Member: 808967
Lords which is the pinout of this box to work many thanks in rj45 cables that are compatible
GPG Universal Interface Now released! GPGIndustries Latest GPGIndustries News 116 06-08-2011 14:53
GPG Universal Interface with JAF Hardware BackSlash_cu GPGInterfaces - www.gpginterface.com 11 03-03-2011 08:51
problem with GPG Universal Interface with JAF Hardware [ANSWERED] albasheer GPGHardwares - World's Finest Hardware ever made 1 03-17-2010 11:22
GPG Universal Interface What can it be? GPGIndustries Latest GPGIndustries News 41 10-30-2009 16:13
<<<<< HOT Products: GPG-HUB, GPG Universal Interface, GPG Red Cable >>>>> sagtel Main Sales Section 0 08-10-2009 07:13
Page generated in 0.26901 seconds with 11 queries
