Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section
GPGIndustries Support section The Best of GPGIndustries
Old 01-27-2010, 13:47   #1 (permalink)
JAVA Good's Avatar
Member: 66136
question about TMA with my Cyclone box [ANSWERED]
hello all,
I use all the time the TMA with my cyclone box, and use the RJ45 cable and put it in the yellow adapter of cyclone (adapter v1), but from some time this don't work and I use now RJ48 (10 pin) adapter in my yellow adapter, and have Problem of peak power (USB),
this is TMA probleme, anny one have idea for repair this or need change one all the 3 month ?
Best Regards,
JAVA Good.
Old 01-27-2010, 17:15   #2 (permalink)
Fast Unlocker's Avatar
Member: 95960
Sonork: 100.1574721
Can you Describe more Please
TMA is working with Cycolone 100%
Old 01-27-2010, 20:56   #3 (permalink)
JAVA Good's Avatar
Member: 66136
TMA don't work now with RJ45, only with RJ48 with peak power (USB) on my computer
anny solution or TMA died ?
Best Regards,
JAVA Good.
Old 01-30-2010, 19:06   #4 (permalink)
JAVA Good's Avatar
Member: 66136
anny help pls, or crap product, or bad publicity ?
Best Regards,
JAVA Good.
Old 02-04-2010, 17:12   #5 (permalink)
JAVA Good's Avatar
Member: 66136
anny one have solution or can help me pls ?
I have the ligth power on if I use RJ45 cable or RJ48 cable, and only RJ48 cable work with my box ?
anny help pls,
Best Regards,
JAVA Good.
Old 02-15-2010, 10:05   #6 (permalink)
JAVA Good's Avatar
Member: 66136
hello all,
my TMA don't work and after search on the forum I'am not sure about value of the fuse of my TMA, any one can confirme or correct me pls ?
Best Regards,
JAVA Good.
Old 02-18-2010, 14:12   #7 (permalink)
JAVA Good's Avatar
Member: 66136
big tks for the team for all your invisible reply and help, and an other big tks for some unlocker like Alex for reply and help,
I desolder all cable and resolder again and change the fuse with an other one,
and my TMA now work, not perfectly but work fine because it's a GPG Money cable,
Best Regards,
JAVA Good.
Old 02-23-2010, 11:02   #8 (permalink)
Member: 1158723
Dear Sir,
sorry for the delay reponse.
pls noted that TMA and cyclone can be connected with the RJ45 and RJ48.
br
winnie
Old 02-23-2010, 11:22   #9 (permalink)
JAVA Good's Avatar
Member: 66136
tks for your reply, so can you tell me why if I use the RJ45 or RJ48 cable I have the same led on PCB power on ?
in the first time, it's not like now, maybe need change some think, if you can help me pls,
maybe next time I buy other one, but I need understand, I don't use it many time,
Best Regards,
JAVA Good.
Old 02-24-2010, 03:16   #10 (permalink)
Member: 1158723
Best Regards,
JAVA Good.
Dear Sir,
pls noted that RJ45 can be used with usb and Jaf cable, but RJ48 can be used the Jaf cable without usb.
regarding to the same led powered on, pls let me know which led powered on, 8pin or 10pin?
br
winnie
Old 02-24-2010, 11:48   #11 (permalink)
JAVA Good's Avatar
Member: 66136
verry nice information and tks for the reply :
about my TMA it's LED of RJ45 cable power on, even I use RJ48 cable it's all the time the same led power on,
and have a question pls, maybe it's not the section, but the team I think can understand, can use the TMA with MTbox with out anny probleme pls ?
Best Regards,
JAVA Good.
Old 02-24-2010, 12:14   #12 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
You can but you must not connect the usb cable when working with the MT-Box
Alex
Old 02-24-2010, 13:24   #13 (permalink)
Raj7979's Avatar
Member: 126067
hello all,
Best Regards,
JAVA Good.
On the Cyclone Box dont use the Yellow adaptor, just connect TMA to Cyclone Box and connect the usb cable to pc or laptop. works for me that way.
Old 02-24-2010, 14:43   #14 (permalink)
JAVA Good's Avatar
Member: 66136
tks for all, and I forget Alex, tks for your help on TMA, my probleme is solved with desolder and solder again the cable,
Best Regards,
JAVA Good.
Old 02-24-2010, 17:41   #15 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
You are always welcome my friend
Alex
problem with my cyclone box.box is not in needed mode samih127 Cyclonebox 18 06-12-2010 06:05
question about TMA with my CycloneBox JAVA Good Cyclonebox 4 01-24-2010 12:20
cyclone team,plz help with my cyclone box. ADAMISKY Cyclonebox 9 09-28-2009 18:02
I have problem with my cyclone box. Only bootloader mode - No main mode [SOLVED] ivanrlobato Cyclonebox 6 08-30-2009 21:16
Please help with my cyclone box ????? geovanny78 Cyclonebox 9 07-27-2009 18:19
Page generated in 0.38108 seconds with 12 queries
