Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section
GPGIndustries Support section The Best of GPGIndustries
Old 07-10-2009, 16:48   #1 (permalink)
meisam's Avatar
Member: 115172
SETOOL from GPG has diffrent pinout?
Hi dear GPG team;
I just got my SETOOL3 box made by you,but seemingly something goes wrong here,i try flashing via box RJ45 with the cable came by box,in most phones it phone can't connect to box and software,i tried the original RJ45 that i had from my last dead box,again no connection,have u used other pinout thatn original SETOOL boxes?
Is it your cable fault?
Please check and answer here,thanks.
Old 07-11-2009, 13:58   #2 (permalink)
meisam's Avatar
Member: 115172
Dear product supporters;
please let me know what the problem might be?!!!
Old 07-11-2009, 14:13   #3 (permalink)
asad_nomy7's Avatar
Member: 570093
Yes GPG setool has diffrent pinout.your old cable not work on gpg setool.use ufs as interface and use UFS cable.
Old 07-12-2009, 09:32   #4 (permalink)
meisam's Avatar
Member: 115172
I got difficulty using GPG SETOOL RJ45 port,it does flash but start very hard or let's say seems bad connection,most of phones DO NOT start flashing,those which connect i have to insert cable and wait few seconds and suddenly it starts flashing
plz help.
Old 07-12-2009, 11:22   #5 (permalink)
Miftahudin's Avatar
Member: 115242
Sonork: 100.1581364
plz help.
bro GPG setool hardware = universal pinout u can use all uni box cable like infinity furousgold etc......
Br.
Old 08-20-2009, 15:31   #6 (permalink)
fretburner's Avatar
Member: 45571
No answer from the cable maker about the pinout.We need it badly.
Old 08-21-2009, 09:23   #7 (permalink)
Member: 81703
WEll about Setool connection through RJ45 it never worked smooth, I have tested on usb cables and two different boxes. So the problem it's not the hardware
Luskao
Old 07-21-2010, 08:32   #8 (permalink)
Member: 1039966
SETool 3 Hardware problem
I have the setool 3 Hardware whit two RJ45 ports , they are correctly installed in device manager whithout error's, all works well in usb to unlock/flash but when need to unlock/flash some cellphone in rj45 ports they dont work.
Is a problem of hardware/instalation because i have the gpg hardware universal too and the rj45 works well.
In the same computer only change setool box and all work's fine
Can anybody help me in what way i resolve the two rj45 ports problem ?
Dear GSMTricks My Pad FInder Cant FInd Pinouts Always Gives Diffrent Pinouts lovingazmee PadFinder box 33 03-04-2009 08:28
tested E65 with unifbus from GPG UHK BB5KING for (BB5BOX) 0 11-03-2008 15:21
tested E65 with unifbus from GPG UHK GPGIndustries Support section 0 11-03-2008 15:18
Problems with Argon test point cable from GPG indrustries CMV_2K Smart-Clip 26 04-28-2008 19:36
[REQ] N95 slider diffrent pinout !!! matin-gsm Chinese Miracle & PinFinder 5 09-27-2007 09:03
Page generated in 2.65031 seconds with 11 queries
