10-18-2007, 14:51 | #1 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | Successfully Unlocked A 5500d just unlocked a 5500d in two attemts with the help of magnifying glass, so no microscope used BB5 BOX IS GREAT Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-86 Version: V__03.55_23-11-06_RM-86_(c)_Nokia. IMEI: xxxxxxxxxxxxxxxxxxx SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-86_xxxxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_10__V __03.55_23-11-06_RM-86_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-86_351855014401485_Locked_Keycnt_0_Fbuscnt_0__V__0 3.55_23-11-06_RM-86_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
10-28-2008, 19:18 | #3 (permalink) | |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Quote:
download all tp u need ! BR, | |
10-30-2008, 01:34 | #5 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | remove lcd remove back plate with the imei sticker from the casing put the pcb in casing connect the flex connector from the side keys put an elastic band round itespecially at the bottom part. now u can power your phone on br |
E75 Success Unlock!!! | jr astigin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-29-2010 11:19 |
Post Here Successfully unlocked using SE A1 Fast Java unlocker | bhart | Cruiser Suite | 90 | 01-27-2009 22:07 |
has anybody unlocked a 5500d with no tp | ganto | Universalbox | 11 | 01-19-2009 20:54 |
HElp me in unlocking in 5500d | rose4u86 | MT-BOX | 8 | 11-11-2007 10:13 |
