did you try all resistor setting sir? because im planning to buy one for my Shop....:confused: |
please i need pinout nokia N96 |
br freddy |
this bad product i tested and not work |
friend patric check here: http://forum.gsmhosting.com/vbb/show...7&postcount=39 Try & post the results. br elcapitel Quote:
N82, N95, E90 can't local mode with UFC maybe should get some revision in next product, br, kevin168 |
N82 N95 8GB E90 can easyly go to local mode.. just add more power to vcc by power suply.. in red clip (vcc) and black clip (gnd) remove the back clip.. then at the back just plug power from power suply about 4,2 or 4,4 Volt.. Then will be sure 100% LOCAL MODE.. Test on N82 with UFC with Tornado http://www.bestncheap.net/index.php?...sg8433#msg8433 Setting UFC for N82 to GO LOCAL MODE : N82 / Pin 3/4 Resitor=10k + Power to VCC and GND 4,5 Volt BR BnC |
6124c ? same as 6125? 6120? |
i need n95 pinout 100% tested PLZ |
other here ---> http://cellcarcol.forumcommunity.net/?t=28271264 |
e90 need bsi 15k stupsi |
N95 Can't Go to LOCAL MODE OR TEST MODE |
Only with external power suplay N95 can Go to LOCAL MODE OR TEST MODE any anather solution |
