Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5KING for (BB5BOX)
Old 12-08-2008, 12:38   #16 (permalink)
kamot37's Avatar
Member: 337001
Thanks Meter: 48
Originally Posted by DaWizard View Post
This Product does not make the E90 and N95 Go to LOCAL MODE OR TEST MODE tested by me many time
did you try all resistor setting sir? because im planning to buy one for my Shop....
Old 12-13-2008, 07:16   #17 (permalink)
patric's Avatar
Member: 8228
Thanks Meter: 132
please i need pinout nokia N96
Old 12-14-2008, 01:21   #18 (permalink)
winnitsa's Avatar
Member: 372207
Thanks Meter: 59
YES, I agree - NO LOcal Mode with all resistor
Old 12-14-2008, 01:28   #19 (permalink)
fred's Avatar
Member: 12411
Sonork: 100.113572
Thanks Meter: 813
thats because there is no 15k ohms selector attached to its BSI lines....
br
freddy
The Following User Says Thank You to fred For This Useful Post:
Old 12-14-2008, 01:52   #20 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
Thanks Meter: 786
this bad product i tested and not work
Old 12-15-2008, 13:21   #21 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Thanks Meter: 12,669
friend patric check here:
GPGUFC 2k12 - All you need to know!!
Try & post the results.
br
elcapitel
Old 12-15-2008, 15:08   #22 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
N82, N95, E90 can't local mode with UFC
maybe should get some revision in next product,
br,
kevin168
Old 12-15-2008, 16:56   #23 (permalink)
bestncheap's Avatar
Member: 19785
Thanks Meter: 1,242
N82
N95 8GB
E90 can easyly go to local mode..
just add more power to vcc by power suply..
in red clip (vcc) and black clip (gnd) remove the back clip.. then at the back just plug power from power suply about 4,2 or 4,4 Volt..
Then will be sure 100% LOCAL MODE..
Test on N82 with UFC with Tornado http://www.bestncheap.net/index.php?...sg8433#msg8433
Setting UFC for N82 to GO LOCAL MODE : N82 / Pin 3/4 Resitor=10k + Power to VCC and GND 4,5 Volt
BnC
Old 12-16-2008, 21:11   #24 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 73
6124c
same as 6125? 6120?
Old 07-22-2009, 13:23   #25 (permalink)
Member: 436120
i need n95 pinout 100% tested PLZ
Old 07-22-2009, 23:37   #26 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 765
other here ---> http://cellcarcol.forumcommunity.net/?t=28271264
Old 09-22-2009, 13:37   #27 (permalink)
Member: 57108
Thanks Meter: 7
e90 need bsi 15k
stupsi
Old 09-22-2009, 22:17   #28 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
N95 Can't Go to LOCAL MODE OR TEST MODE
Old 09-22-2009, 22:20   #29 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
Only with external power suplay N95 can Go to LOCAL MODE OR TEST MODE any anather solution
pinout of UFC cables. hugmax GPGUFC - The best Universal Fbus Cables ever made 3 10-30-2013 13:12
UFC v1 adaptor cable pinout ! tgcommss GPGUFC - The best Universal Fbus Cables ever made 7 02-17-2010 06:29
pinout schema of UFC cables miga GPGUFC - The best Universal Fbus Cables ever made 1 12-18-2009 20:42
UFC all cable pinout iiiaudiologicii GPGIndustries Support section 2 05-20-2009 19:37
Page generated in 0.54241 seconds with 9 queries
