UFS problem please help Searching for UFS box ... UFS box NOT detected UFS box UFSBOX_BB5_FLASH_bb5challenge ... Error. 0x11130101 ERROR! Operation time: 00:00. Successfully done. Thread phone exit. What I have to do with this problem? Help:confused: |
try to update the ufs box to ver 208 br |
My ufs firmware is 208... |
just unplug and plug again ufs from usb whitout close BB5King program and press "Chk Conections" |
The problem not on cacle... My friends told me the problem whit this 1. UFS box firmware should be 208. If any of you not have this firmware inside their box, can easy upgrade to 208 following this steps: - Download this soft: http://www.bb5king.com/files/mobileE...3.0_beta11.exe - Install it - After install plug your UFS device - Start installed program - At the left top select your ufs device and click connect - An automatic prompt ask you if you want to upgrade your firmware - Confirm it (thanks to user Serjer for pointing to this software) 2. Some UFS manufacturers used one wrong IC chip. If still encounter errors on some phones, please open your UFS box and check with this picture info: http://www.bb5king.com/files/UFS_Mods.JPG Sorry for any troubles created to our end-users, but our BB5 King team is not responsable of UFS boxes firmware updates and manufacture process. Also, for better performance and to avoid communication errors, we still recomand to all our BB5 King users to use JAF interface, is more faster and more stable. |
Hope Cinek can give solution for us |
Try this solution http://forum.gsmhosting.com/vbb/showthread.php?t=630144 and all your problems are away. |
well I tried the following while I have both HWK and the JAF on the same PC I tried the unlocker on the JAF interface and all was OK now IF you try the 5310 and notice the problems on unlocking try the following connect it to HWk and disconect the JAF fbus interface and check the connection now you should notice the difference and the unlocking will work thanx in advance |
I install the soft but don't work. this error: "Sorry, application was expired? Check wxw.mxkey.biz for update, please!" But the website is offline. Have you got a solution please? Thank's in advance |
Problem solved: Change the date of your pc and is ok for the update!:) |
Brother I have new ufs3+hwk but the problem is when i setup main file & connect the ufs box they want usb driver then i located the driver & open the software but when i connect its show HWK not locate. But why? when i buy it the seals man show & check me the box it's 100% ok but my PC say error. So what can i do? PLEASE HELP ME. |
brothers when m try to instal ufs3 hwk on my pc its says that( screen shot is attachment is linked) am try both files one by one but not done .i have no any more prioves version instal on my pc...... plzhttp://i45.tinypic.com/m8eikj.jpg solve my prob |
Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Connection to server failed: Socket Error # 10061 Connection refused.(No connection could be made because the target machine actively refused it.) |
this might be hwk server problem |
