Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2008 Location: r k g i Age: 31
Member: 823633 Status: Offline Sonork: 9898260467 Thanks: 201
| 1200 cyclon erore help jaf flashing ok hwk flashing ok but cyclone this errore help Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7880 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.06, (Aug 8 2009 17:54:19, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: Revised Box Serial Number: C0000949 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D20001EA Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.17v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.38v PASSED VBAT Voltage 5.10v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 49 products, Filtering DCT4 Products - wait... 10 Products left after filtering. Ready. Retrieving Variants for Product RH-99 - wait... 1 Variants Retrieved Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V Terminating flash session Boot operation took 6.797s Check Flashing Bus finished Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh99_05.910, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V MSID-Crypted: 844BC603DE7F37096E62271137 MSID-Plain: 3E4EBAE9000CEBCDA8000000 FAID-Crypted: 41BFE040FB4773ECE8574A84 Flashbus Write baud set to 6.50Mbits 5 Region(s) to erase Erasing NOR Region [0x01000000-0x0100FFFF] Erasing NOR Region [0x01010000-0x013AFFFF] Erasing NOR Region [0x013B0000-0x013EFFFF] Erasing NOR Region [0x017C0000-0x017EFFFF] Erasing NOR Region [0x01FC0000-0x01FEFFFF] Erase taken 74.735s Writing 146 blocks... All blocks written OK! Time taken 13.750s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh990_nai5.91mh, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.07V MSID-Crypted: 84D7E090E5A844B500821F7A9D MSID-Plain: 3E4EBAE9000CEBCDA9000000 FAID-Crypted: 5C96EFDDC598B4084F9899AE Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01380000-0x013AFFFF] Erase taken 3.500s Writing 10 blocks... All blocks written OK! Time taken 0.891s Terminating flash session Extracting Content Package... CP Server: File Server fake reply for CUI phone. CP Extract Failed -> CP Not Extracted, Code: 1 WARNING: Failed to extract CP Failed to disable VPP -> No answer from CBUS Processing Flash Image Failed -> Failed to disable box VPP Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh99_05.91mh, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Failed to disable VPP -> No answer from CBUS Processing Flash Image Failed -> Failed to disable box VPP Failed to Flash -> Problem with processing CNT Image file |
| | #5 (permalink) |
| Super Moderator ![]() Join Date: Jan 2009 Location: England Age: 48
Member: 947561 Status: Offline Thanks: 2,691
| Just use cable 1101A and use external 9V DC (Check before the hardware version of your Cyclone box, in case use box internal 5V) psu connected the the AC port of Cyclone. BR Alex |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 1200 cyclone errore help | vaghubha_sodha | Cyclonebox | 3 | 08-13-2009 06:44 |
| 1200 cyclone errore help | vaghubha_sodha | Cyclonebox | 6 | 08-08-2009 08:06 |
| 1200 cyclone reroore | vaghubha_sodha | Cyclonebox | 4 | 08-07-2009 14:13 |
| 1200 cyclone errore help | vaghubha_sodha | Nokia Hardware & Hardware-Repair Area | 3 | 08-07-2009 05:44 |
