08-13-2009, 05:03 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | 1200 cyclone errore help Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.06, (Aug 8 2009 17:54:19, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: Revised Box Serial Number: C0000949 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D20001EA Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.17v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.09v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 44 products, Filtering DCT4 Products - wait... 9 Products left after filtering. Ready. Retrieving Variants for Product RH-99 - wait... 1 Variants Retrieved Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Terminating flash session Boot operation took 6.765s Check Flashing Bus finished Failed to Write UEM -> No reply file chosen Programming data for IMEI: 356804027027650 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 0Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Programming FLASH data... FLASH data Programmed OK Programming UEM data... UEM data Programmed OK Terminating flash session Write UEM finished Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh99_05.910, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.07V MSID-Crypted: 84AD771CB48A36B1EF2F900F46 MSID-Plain: 3E4EBAE900513342A8000000 FAID-Crypted: D1A90160B3BDE936498D12A7 Flashbus Write baud set to 6.50Mbits 5 Region(s) to erase Erasing NOR Region [0x01000000-0x0100FFFF] Erasing NOR Region [0x01010000-0x013AFFFF] Erasing NOR Region [0x013B0000-0x013EFFFF] Erasing NOR Region [0x017C0000-0x017EFFFF] Erasing NOR Region [0x01FC0000-0x01FEFFFF] Erase taken 73.297s Writing 146 blocks... All blocks written OK! Time taken 13.531s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh990_nai5.91mh, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 842BB70A0304D0676AD2638118 MSID-Plain: 3E4EBAE900513342A9000000 FAID-Crypted: 67116B3BDDA1F281DA32ECA1 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01380000-0x013AFFFF] Erase taken 3.453s Writing 10 blocks... All blocks written OK! Time taken 0.891s Terminating flash session Extracting Content Package... CP Server: File Server fake reply for CUI phone. CP Extract Failed -> Phone is not responding for CP Server Extract Request WARNING: Failed to extract CP Failed to disable VPP -> CBUS reported an error Processing Flash Image Failed -> Failed to disable box VPP Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh99_05.91mh, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Failed to disable VPP -> No answer from CBUS Processing Flash Image Failed -> Failed to disable box VPP Failed to Flash -> Problem with processing CNT Image file |
08-13-2009, 06:44 | #4 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
Considering it is a DCT4, if you are using a standard JAF/UFS cable try using the Box 5V (Don't need the external power supply for this) and just flash the CNT. BR Alex | |
The Following User Says Thank You to moulnisky For This Useful Post: |
1200 cyclon erore help | vaghubha_sodha | Cyclonebox | 4 | 08-17-2009 07:45 |
1200 cyclone errore help | vaghubha_sodha | Cyclonebox | 6 | 08-08-2009 08:06 |
1200 cyclone errore help | vaghubha_sodha | Nokia Hardware & Hardware Repair | 3 | 08-07-2009 05:44 |
1200 Flash Error Plz Help Me | sonojee | Nokia Hardware & Hardware Repair | 2 | 07-29-2009 17:36 |
cyclone error ,help | spyslinky | Cyclonebox | 5 | 07-06-2009 04:51 |
