09-18-2010, 07:32 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: IN FRONT OF YOU Age: 44
Member: 475440 Status: Offline Sonork: 1604067 Thanks Meter: 965 | 1208 Flashing error help cyclone teame logs are here[/QUOTE][/QUOTE]Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.46, (Jul 24 2010 23:54:36, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C00037A1 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40 Initializing security card... Card Serial Number: D9000330 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.14v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.81v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00898872 @ 0x01000000, Intel, SectorSize: 64kB, Ext: 00000121 Signature: 88529418008C0080214828441A2A2500 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898872 (32Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Terminating flash session Boot operation took 7.31s Check Flashing Bus finished Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00898872 @ 0x01000000, Intel, SectorSize: 64kB, Ext: 00000121 Signature: 88529418008C0080214828441A2A2500 Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00898872 @ 0x01000000, Intel, SectorSize: 64kB, Ext: 00000121 Signature: 88529418008C0080214828441A2A2500 u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898872 (32Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits Flashbus Write baud set to 1.0Mbits Erasing NOR Region [0x01000000-0x013FFFFF] Erase All Chips finished Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 52 products, Filtering DCT4 Products - wait... 9 Products left after filtering. Ready. Retrieving Variants for Product RH-105 - wait... 187 Variants Retrieved Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh105_04.110, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Box VPP Enabled PLL Factor: 3 FlashChip[0]: 0x00898872 @ 0x01000000, Intel, SectorSize: 64kB, Ext: 00000121 Signature: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898872 (32Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 5.06V MSID-Crypted: 84FE845C88B49A99A495EF5672 MSID-Plain: 3E4EBAE900146AF1A9000000 FAID-Crypted: 44C860E7E50C81F019D667AA Flashbus Write baud set to 6.50Mbits 5 Region(s) to erase Erasing NOR Region [0x01000000-0x0100FFFF] Erasing NOR Region [0x01010000-0x013AFFFF] Erasing NOR Region [0x013B0000-0x013EFFFF] Erasing NOR Region [0x017C0000-0x017EFFFF] Erasing NOR Region [0x01FC0000-0x01FEFFFF] Erase taken 36.453s Writing 146 blocks... All blocks written OK! Time taken 20.516s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh1050_nai4.11ef, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Box VPP Enabled PLL Factor: 3 FlashChip[0]: 0x00898872 @ 0x01000000, Intel, SectorSize: 64kB, Ext: 00000121 Signature: 88529418008C0080214828441A2A2500 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898872 (32Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 5.06V MSID-Crypted: 84784254AB2DF07656DEC0EE84 MSID-Plain: 3E4EBAE900146AF1A8000000 FAID-Crypted: 97F9045F76DE7D39094F5546 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01380000-0x013AFFFF] Erase taken 1.593s Writing 8 blocks... All blocks written OK! Time taken 1.31s Terminating flash session Extracting Content Package... CP Extract Failed -> Phone not detected WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh105_04.11ad, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Box VPP Enabled PLL Factor: 3 FlashChip[0]: 0x00898872 @ 0x01000000, Intel, SectorSize: 64kB, Ext: 00000121 Signature: 88529418008C0080214828441A2A2500 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898872 (32Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 5.06V MSID-Crypted: 8461183E7A13D65B07B5DDEA0B MSID-Plain: 3E4EBAE900146AF1AA000000 FAID-Crypted: 2AE7EF4807936F274E54CA28 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01240000-0x0124FFFF] Erasing NOR Region [0x01250000-0x0137FFFF] Erase taken 11.516s Writing 75 blocks... All blocks written OK! Time taken 10.297s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! |
09-19-2010, 17:01 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: sai baba shirdi Age: 44
Member: 670629 Status: Offline Sonork: 100.1590208 Thanks Meter: 431 | 1st flash only mcu&ppm & 2nd flash mcu pmm cnt youer set is 10000% is ok.i tested many time........ |
The Following 2 Users Say Thank You to d.jain For This Useful Post: |
