06-19-2011, 17:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | 19-06-2011 Cyclone Box Installer v1.15 Released - Added RESET (to 12345) DCT4+/XGold1 Encrypted Security Code from DCT4+ Based phone - of course WITHOUT data loss - seems Worlds First - Added Reading Full RPL (NPC,CCC,HWC,SIMLOCK,SD,...) from Dead/Downgraded/Security Wrong BB5 Units - seems 1st in world. If phone doesn't power on (Stuck on Nokia logo, or completly dead), you can now dump full RPL file in order to Full Erase your phone and revive it. Software before dumping RPL in Recovery mode, will ask user of doing so. So in any case of reviving downgraded phone is: 1. Create RPL from Dead Phone 2. Full Erase 3. Write any SW version 4. Write previously backed-up RPL file 5. Authorize with Super Dongle 6. Write virgin PM - Added (fixed) NCK Counter Reset for XGold2 based phones - Security Block is now backed-up before NCK Counters Reset, just in case - XGold1 Dead units booting fixed - Separate button for Receiving L7 Code for LBF added - Fixed DCT4 Security Counter Attempts Reset for some DCT4 variants - PMM Management Tab added to BB5 Security Tab - Auto-Imei RESTORE added. Used if you have corrupted your imei, but having valid NPC file. Will scan Stored Files for CRT file matching with CMT Public ID and automatically write it. - Added DCC camera Hardware Fault alert on DCC repair - some units is hardware fault and repair is not possible (DCC file not found) - XGold1 PMM parsing fixed (While reading LBF, Simlock table not found for some operators/phones) - XGold2 Flashing problems fixed (Invalid pointer) - USB transactions module rewritten - Full Erase button added for BB5 mobiles. No need to know FlashChip mapping and size - it's scanned automaticlly. It will erase CMT flash completely. Make sure RPL and PM is readed before erase!!! - Added "Just NPC" option used with "Erase Certificates". Used to delete only NPC certificate (corrupt IMEI and switch phone-on to make necessary job ... with IMEI corrupted phone will switch on even without valid security area). You can use this function to dump PM from non-working phone. Don't forget to CREATE RPL FROM PHONE first! Else you will get corrupted IMEI. - "Force Use Server" added for SX4 Authorization. - Fixed Auto Selecting bug - Fixed problem with parsing DCT4 variants when no DCT4 products installed - Fixed problem with parsing BB5 variants when no BB5 products installed - Index out of bound (0) fixed - Plain RPL is checked now by default - Removed "Bootloader upgrade problem" message, as caused too much confusion - Security Problem #1 and #2 Fixed (anti-idiot-fix) - Added additional Security Problem #5 message for Reinstall Drivers - Minor changes and bugfixes Do you Want More ? if Yes Then wait till Next week for more surprises DOWNLOADS LINK1 LINK2 LINK3 br Cyclone Box Team |
The Following 113 Users Say Thank You to SiRoYa For This Useful Post: |
06-19-2011, 17:15 | #2 (permalink) |
Freak Poster Join Date: Oct 2010 Location: !!!Suck Me I Know You Can!!!
Member: 1421351 Status: Offline Sonork: 100.1605689 Thanks Meter: 143 | [COLOR="*****Brown"]great update from greatest team[/COLOR] |
The Following User Says Thank You to kontil For This Useful Post: |
06-19-2011, 17:39 | #10 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Gujjar AJK
Member: 207308 Status: Offline Thanks Meter: 471 | Sl3 on the wayjust few more work by karwos the great what a great worK SL3 More easy Last edited by ptt; 06-19-2011 at 23:30. Reason: remove quoted part |
The Following 5 Users Say Thank You to adnanali For This Useful Post: |
06-19-2011, 18:46 | #11 (permalink) |
Freak Poster Join Date: Sep 2008 Location: At the center of the Earth
Member: 851708 Status: Offline Sonork: 1000.2brian Thanks Meter: 15 | - Added READING DCT4+/XGold1 Encrypted Security Code from DCT4+ Based phone (previously shown as Crypted DCT4+) - of course WITHOUT data loss - seems 1st in the world - Added RESET (to 12345) DCT4+/XGold1 Encrypted Security Code from DCT4+ Based phone - of course WITHOUT data loss - seems 1st in the world - Added Reading Full RPL (NPC,CCC,HWC,SIMLOCK,SD,...) from Dead/Downgraded/Security Wrong BB5 Units - seems 1st in world. If phone doesn't power on (Stuck on Nokia logo, or completly dead), you can now dump full RPL file in order to Full Erase your phone and revive it. Softwar before dumping RPL in Recovery mode, will ask user of doing so. So in any case of reviving downgraded phone is: 1. Create RPL from Dead Phone 2. Full Erase 3. Write any SW version 4. Write previously backed-up RPL file 5. Authorize with SuperDongle 6. Write virgin PM thanks karwos, this is what i was waiting for. this is great sir. |
06-19-2011, 19:32 | #13 (permalink) |
Freak Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 43
Member: 120908 Status: Offline Thanks Meter: 38 | for update in upthere can that use dor new hash sl3 for backup simlock without local mode because in new hash phone can't to local mode although npc empty what recovery mode that bott phone to local with reset npc or diferent metode Last edited by moulnisky; 06-19-2011 at 19:59. |
06-19-2011, 20:00 | #15 (permalink) |
No Life Poster Join Date: Oct 2009 Location: JAM Exploring Simlock 3!!! Age: 36
Member: 1149815 Status: Offline Sonork: N/A for now Thanks Meter: 218 | What is meant by "Force Use Server" added for SX4 Authorization" Is it that all SX4 authorization will be server base? or only just for SL3 downgrading need to Authorize via is needed? |
The Following User Says Thank You to GSM_STREET For This Useful Post: |
i WANT TO BUY NOKIA BOX !!! | Eric | Wanted Products | 8 | 02-14-2011 13:23 |
2 FREE NOKIA SP SIM CARDS TO RELEASE FOR INFORMATION WE NEED | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-25-1999 03:34 |
