02-23-2010, 19:42 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Pakistan
Member: 87676 Status: Offline Thanks Meter: 114 | 2630 57.20 unlocking no signal i have a problem with 2630 i unlock that phone but after no signal i flash it with its orignal product code same problem i erase that phone then flash again with orignal product code same position i also wright a pm file but same result i did not understand whats the problem i also use ub,cyclone and other boxes but no success i also use all methoed which is written in this forum like flash with orignal product code unlock with latest cyclone and ub software with updated box its hardware id (upp id) is 3162 and phone orignal version is 57.20 and product code is 0582682 and its from vodafone uk now tell me its a old upp id with new version thats why or i have to right a special pm file for that 57.20 version which is diffrent from simple 2630 or some think else a refernse for old post which i read for this problem and i use that metheod is http://forum.gsmhosting.com/vbb/showthread.php?t=838315 http://forum.gsmhosting.com/vbb/showthread.php?t=853227 and also some other plz tell orignal facts about that thanx in advance sarmad alvi |
02-24-2010, 10:02 | #7 (permalink) |
Member: 87676 Status: Offline Thanks Meter: 114 | @venuno yes this phone have signal before unlocking also i have 2 pcs same problem same version and same product code also i wright pm after flashing and for other tools i used all like ub and mxkey but same problem br sarmad alvi |
02-24-2010, 11:03 | #8 (permalink) | |
No Life Poster Join Date: Sep 2008
Member: 868940 Status: Offline Thanks Meter: 90 | Quote:
sorry to say here.... br dawah telecom | |
02-24-2010, 12:01 | #10 (permalink) |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Its very simple and common problem in 2630 just downgrade to v6.xx and ur problem is solved tested this many times |
The Following User Says Thank You to .::AZEEM::. For This Useful Post: |
02-24-2010, 14:33 | #11 (permalink) |
Member: 87676 Status: Offline Thanks Meter: 114 | @.::AZEEM::. thanx for ur help @all forum members how r facing this problem i have simple methoed for that problem if the hardware id (upp id) is 3162 u can wright 6.xx or downgrade it and if u have hardware id (upp id) is 3168 u have to wright 7.xx or higher like 57.20 regards .::SARMAD ALVI::. |
02-24-2010, 16:50 | #12 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | There is a problem with the last models asic. before this version been using the asic 3168 and now looks like they are using again the 3162 hence the problem with the signal BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
02-24-2010, 17:07 | #13 (permalink) |
Member: 87676 Status: Offline Thanks Meter: 114 | @moulnisky(ALEX) THANX FOR UR ANWER YES U R RIGHT I FLASH THAT WITH 6.82 AND PROBLEM SOLVE THIS IS ONLY ASIC ID (HARDWARE ID,UPP ID) AND FLASH MATCHING PROBLEM BR .::SARMAD ALVI::. |
02-24-2010, 18:08 | #14 (permalink) |
No Life Poster Join Date: Dec 2003 Location: in the center of the heart
Member: 46125 Status: Offline Thanks Meter: 59 | if its mcu id 3162 then just downgrade it to 6.xx version and signal will be fine ............tested but then if mcu id 3168 then no solution i think or may be try using pm |
2630 57.20 unlocking no signal | alvis | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 04-29-2010 00:47 |
2630 57.20 unlocking no signal | alvis | Universalbox | 10 | 02-24-2010 15:43 |
2630 57.20 unlock successfully | gsmexpertgsmexp | Cyclonebox | 2 | 09-16-2009 12:33 |
2630 57.20 unlock done | bhoybits99 | Cyclonebox | 8 | 05-30-2009 15:12 |
