09-18-2010, 05:48 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | 2700c nokia show after power off please help not downgread prob here or i am hwk full rd crt backup here i am flash lettest v 9.97 but same here read crt log here CMT NPC Ok CMT HWC Ok CMT CCC Ok CMT R&D Ok CMT VARIANT Not Found CMT PAPUBKEYS Ok CMT KEYS Ok Restarting MCU... Read all certificates finished |
09-18-2010, 05:51 | #2 (permalink) |
Freak Poster Join Date: Jan 2007 Location: @ planet EARTH
Member: 433173 Status: Offline Sonork: 100.1590587 Thanks Meter: 31 | is the phone flashing fully??? If yes then phone not going in local or test mode.. Try flashing with usb cable or remove parts near battery coonector and try... Should work for u.. Regards |
09-18-2010, 06:34 | #3 (permalink) |
Member: 823633 Status: Offline Thanks Meter: 1,705 | i am flash usb but same here i am remove near battry conecter local mode part Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.46, (Jul 24 2010 23:54:36, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0000949 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: 00000000000 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.16v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.07v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Read RPL operation not possible for USB bus Backing up simlock... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Selecting USB Flashing Method... [BB5 ADL Server]: Found 0 active devices [BB5 ADL Server]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Proceeding with Dead USB Mode Press power-on shortly to run USB Boot ROM [BB5 BootRom]: Found 1 active devices [Nokia USB Flashing Generic]: Opening Connection [Nokia USB Flashing Generic]: Port opened OK! CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 11B0010ACB8C8E562DA7D2C7EE4400CDA043ED5E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5 Sending RAW Loader... Sending CMT UPDAPP Certificate and Data... Waiting for ADL Server Startup... [BB5 ADL Server]: Found 1 active devices [Nokia BB5 ADL Loader USB Generic]: Opening Connection [Nokia BB5 ADL Loader USB Generic]: Port opened OK! ADL Server Startup Confirmed OK! Processing rm561__09.97.mcusw (CMT)... rm561__09.97.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR Erase taken 122.422s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... All blocks written OK! Time taken 66.234s Flashing Speed: 2457.99 kBit/S Processing rm561__09.97.ppm_mh (CMT)... rm561__09.97.ppm_mh, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x01520000-0x01DBFFFF, NOR Erase taken 49.328s Writing all blocks... All blocks written OK! Time taken 21.531s Flashing Speed: 2427.48 kBit/S Processing rm561__09.97.image_mh_blac_128 (CMT)... rm561__09.97.image_mh_blac_128, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR Erase taken 223.984s Writing all blocks... All blocks written OK! Time taken 26.906s Flashing Speed: 2477.64 kBit/S Restarting CMT... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Factory defaults OK Reading info... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Failed to read info -> Phone not detected Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
09-18-2010, 07:08 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | 100 % hardware problem..............carefuly reheat in rap...double rire ic...tested more times |
The Following User Says Thank You to jaleelkuttikkar For This Useful Post: |
09-18-2010, 08:22 | #5 (permalink) | |
Member: 823633 Status: Offline Thanks Meter: 1,705 | Quote:
after dead after 2nd time heat power on same prob here my phone hardwer prob / softwer prob here ? | |
