01-15-2010, 22:47 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Slovakia Age: 43
Member: 13922 Status: Offline Thanks Meter: 334 | e90 ra-6 impossible to flash - BUG in SW? I'm unable to flash E90 with my cyclonebox, I used UFCv2 cable with same cable and HWK same phone was flashed succesfully here it the log from cyclone Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone WMDRM Store not supported Booting RAP... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9DF56128C124EEBE45DEDBBF3A89274D78D7A902 APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0BF0001774B9015881EBB880CCA08347D87D699E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 External Box VPP Enabled External CMT Phone VPP Enabled, Source: Box External 9V PAPUBKEYS Hash for CMT: CCE4D6D72835B461FE6259BFF52C5566B3FAB11C omap2420_m1_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.41.0, Algo: BB5 FlashChip[0,APE]: 0x00EC004000220000, Samsung, NAND Requested Algorithm: OMAP2420 UNISTORE-II-1.5.1 ALG (APE) FlashChip[0,APE]: 0xFFFF000000000000, Unknown, MMC teflon_sam_nand_xsr151_m1.fg, Type: Algorithm, Rev: 0.1.57.0, Algo: OMAP2420 UNISTORE-II-1.5.1 ALG External Box VPP Enabled External APE Phone VPP Enabled, Source: Box External 9V PAPUBKEYS Hash for APE: CCE4D6D72835B461FE6259BFF52C5566B3FAB11C Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... Storing VARIANT... Processing APE Part... Storing Product Code... Storing PSN... Storing HWID... Storing NPC... Storing CCC... Storing HWC... APE VARIANT Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Processing pre flash tasks... Pre flash tasks finished, continuing... Processing ra6_400.34.93_prd.c00 (CMT)... Booting RAP... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9DF56128C124EEBE45DEDBBF3A89274D78D7A902 APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0BF0001774B9015881EBB880CCA08347D87D699E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 ra6_400.34.93_prd.c00, Type: Flash Image, Algo: BB5, XSR 1.5, BB5, OMAP2420 UNISTORE-II-1.5.1 ALG RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Internal Box VPP Enabled External CMT Phone VPP Enabled, Source: Box Internal 5V PAPUBKEYS Hash for CMT: CCE4D6D72835B461FE6259BFF52C5566B3FAB11C Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00080000-0x007C26C5, NOR EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR EraseArea[0,CMT]: 0x00880000-0x00FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 5.31s Processing Flash Image Failed -> Group Erase failed Failed to Process all Image files -> Failed to process ra6_400.34.93_prd.c00 |
E90 RA-6 Flashing DONE with usb cable | F@RUK S | MT-BOX | 3 | 01-06-2010 23:36 |
E90 RA-6 locked to ONE Austria network | nokia-xxx | Nokia Base Band 5 ( BB-5 ) | 0 | 11-11-2009 08:52 |
Nokia E90 RA-6 Flashing Issue | yueyo | J.A.F. By Jafsupport.com | 3 | 09-07-2008 11:05 |
Nokia E90 RA-6 v210.34.75 firmware | lukasz1 | Nokia Base Band 5 ( BB-5 ) | 1 | 05-25-2008 09:21 |
E90 RA-6 V07.40.1.2 EMEA Flash Files | SteelBlade | Nokia Base Band 5 ( BB-5 ) | 1 | 11-09-2007 04:28 |
