3110c need help phone restricted how to solve with my cyclone 3110c phone restricted
acct. try unlock / sx4 write pm / unlock again but no luck
here logs: Code:
All initialized - Ready to work
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101
CMT_EM_ASIC_ID: 00000232
CMT_EM_ASIC_ID: 00000353
CMT_PUBLIC_ID: 20B00012CF457C56B45577FA28550096321A65C6
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC: 191EC665
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00898981 (Intel), Size: 32MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
MCU Version V 07.30
MCU Date 07-05-09
Product RM-237 (Nokia 3110c)
Manufacturer (c) Nokia.
IMEI 355728029886873
Mastercode 3127407663
IMEI Spare 3A55270892888607
IMEI SV 3355270892888627F7000000
PPM V 07.30, 07-05-09, RM-237, (c) Nokia. , B
CNT Content: ora_pl, V 07.30, 07-05-09, RM-237, (c) Nokia. , ,
PSD 0000000000000000
RETU 32
TAHVO 53
AHNE 11
RFIC 17211721
DSP ICPR61_08w10
BT 06cc-P9.1
Simlock Server SIMLOCK SERVER VERSION 63
Simlock Key FFFFFFFFFFFFFFFF
Simlock Profile FFFFFFFFFFFFFFFF
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 00101F
Auto Selecting Flash Files on User Request...
Product Code:
This is Valid BB5 Product
Variant found for readen Product Data!
[308,1] Written, Length: 8192 bytes, Status: OK
Write PM Finished, Record written OK: 1, Record written NOT OK: 0
SX4 Authorization / SD Repair Procedure Started....
"20B00012CF457C56B45577FA28550096321A65C6.C000539D" Exists, That is good...
MCU Version V 07.30
MCU Date 07-05-09
Reading Security Block...
Security block OK and saved to "RM-237_355728029886873_242012_92058 AM.SecurityBlock.PM"
Superdongle Key is probably CORRUPTED, Writing custom keys...
Received SD Keys from box, writing to phone...
Superdongle Key ACCEPTED OK !
SX4 Status: Not authorized (76)
Started mutual authenthication with card...
Receiving Phone Seed 1...
Phone Seed 1 Received
Sending calculated Data 1, and expecting Seed 2...
Calculated Data 1 accepted, Phone Seed 2 Received
Sending calculated Data 2
Calculated Data 2 sent, Checking Authorization Status again
Authorization successfully finished!
Looking for Virgin PM In Database...
Found, writing...
[1,0] Written, Length: 114 bytes, Status: OK
[1,2] Written, Length: 98 bytes, Status: OK
[1,4] Written, Length: 110 bytes, Status: OK
[1,6] Written, Length: 98 bytes, Status: OK
[1,8] Written, Length: 110 bytes, Status: OK
[1,13] Written, Length: 98 bytes, Status: OK
[1,16] Written, Length: 86 bytes, Status: OK
[1,18] Written, Length: 86 bytes, Status: OK
[1,20] Written, Length: 86 bytes, Status: OK
[1,25] Written, Length: 4 bytes, Status: OK
[1,29] Written, Length: 6 bytes, Status: OK
[1,34] Written, Length: 80 bytes, Status: OK
[309,0] Written, Length: 4 bytes, Status: OK
[309,1] Written, Length: 2 bytes, Status: OK
[309,2] Written, Length: 12 bytes, Status: OK
[309,4] Written, Length: 12 bytes, Status: OK
[309,5] Written, Length: 12 bytes, Status: OK
[309,7] Written, Length: 12 bytes, Status: OK
[309,8] Written, Length: 12 bytes, Status: OK
[309,17] Written, Length: 12 bytes, Status: OK
[309,22] Written, Length: 12 bytes, Status: OK
Write PM Finished, Record written OK: 21, Record written NOT OK: 0
BB5 Unlock Started...
MCU Version V 07.30
MCU Date 07-05-09
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK and saved to "RM-237_355728029886873_242012_92157 AM.SecurityBlock.PM"
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: NCK Calculation (new method)
#pw+177934383676312+1#
#pw+590232230074719+2#
#pw+440248147145134+3#
#pw+454086334144128+4#
#pw+937573212663654+5#
#pw+524610371418294+6#
#pw+001541013372491+7#
Sending NCK Codes..
NCK[1] - Not locked on given lock level
NCK[2] - Not locked on given lock level
NCK[3] - Not locked on given lock level
NCK[4] - Not locked on given lock level
NCK[5] - Not locked on given lock level
NCK[6] - Not locked on given lock level
NCK[7] - Not locked on given lock level
BB5 Unlock Failed -> No any NCK Code has been accepted THANK YOU IN ADVACE.....;)) |
