Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 05-03-2009, 10:10   #1 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Sonork: 100.1577222
3120c RPL Rebuild Plus Unlock OK
Here is Log IMEI was corrupted RPL rebuilded and Then Unlocking Thx Cyclone Team Live long and Keep it Comming
MCU Version    V 07.16
MCU Date    27-05-08
Product        RM-364
Manufacturer    (c) Nokia
IMEI        12345610654321?
Failed to read info -> '?' is not a valid integer value
Failed to Write RPL File -> RPL File invalid, not begins with `REBUILD DATA` Magic, Maybe it is PLAIN ONE ?
Skipping RPL decryption...
Erasing Security...
Booting RAP...
CMT_SYSTEM_ASIC_ID:     000000010000022600010006010C192101003000
CMT_EM_ASIC_ID:         00000295
CMT_EM_ASIC_ID:         00000B22
CMT_PUBLIC_ID:         04D0000B475C7C5688AD6038A44564AEC27647B5
CMT_ASIC_MODE_ID:     00
CMT_ROOT_KEY_HASH:     BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_ROM_ID:         273F6D55DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 4.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: B778DFBE4C5F277CE2DE8A38AF46E5D6803E4A79
APE Boot skipped on user request
CMT NPC Erased
Restarting MCU...
Parsing decrypted RPL...
Processing FBUS Part...
Writing Product Code...
Processing FLASHBUS Part...
Booting RAP...
Box VPP disabled
APE Subsystem Not Found
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Write RPL Finished!
MCU Version    V 07.16
MCU Date    27-05-08
Product        RM-364
IMEI        354849022589750
Mastercode    2312304355
IMEI Spare    3A45480922857905
IMEI SV        3345480922857945F8000000
PPM        V 07.16, 27-05-08, RM-364, (c) Nokia            , C
CNT        Content: 3_uk, V 07.16, 27-05-08, RM-364, (c) Nokia            , ,
PSN        KKR887602
Product Code    backup
Module Code    0203882
Basic Product Code    0553930
PSD        0000000000000000
LPSN        0
RETU        15
TAHVO        22
AHNE        30
HW        2001
RFIC        17141715
DSP        ICPR71_08w17
LCD        SEIKO
BT        06cc-P9.2
Simlock Server    SIMLOCK SERVER
Simlock Key    2342000000000000
Simlock Profile    8000000000000002
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Simlock[1,1]    State: CLOSED    Type: MCC-MNC    Data: 23420F
Simlock[2,1]    State: CLOSED    Type: MCC-MNC    Data: 23594F
BB5 Unlock Started...
MCU Version    V 07.16
MCU Date    27-05-08
Product        RM-364
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
Box VPP disabled
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support...
Restarting MCU...
Booting RAP...
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Received Security Block OK !
Bypassing SX4...
Booting RAP...
Box VPP disabled
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Writing Security Block...
Writing Simlock Key...
SP Accepted, doing reset to update block...
Booting RAP...
Box VPP disabled
Restoring NPC...
Restarting MCU...
SX4 Bypass Finished
MCU Version    V 07.16
MCU Date    27-05-08
Product        RM-364
Simlock Key    0010100000000000
Simlock Profile    8000000000000000
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Simlock[1,1]    State: OPENED    Type: MCC-MNC    Data: 00101F
Unlock finished!
The Following 3 Users Say Thank You to Amir-SkillZ For This Useful Post:
Old 05-03-2009, 10:14   #2 (permalink)
aswancamel's Avatar
Member: 303402
please, give step how you do that.
thanks
Old 05-03-2009, 10:20   #3 (permalink)
musmanm's Avatar
Member: 437422
give more detail you repair with rpl? or make rpl with pm?
Old 05-03-2009, 10:27   #4 (permalink)
milandhal's Avatar
Member: 508774
Sonork: 100.1590207
sir can u post details step by step with screen short its help s us
thanks in advance
Old 05-03-2009, 10:30   #5 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
MCU Version V 07.16
MCU Date 27-05-08
Product RM-364
Erasing Security...
Booting RAP...
Box VPP disabled
CMT NPC Erased
Restarting MCU...
Booting RAP...
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Write RPL Finished!
MCU Version V 07.16
MCU Date 27-05-08
Product RM-364
PSN KKR887602
Product Code backup
Module Code 0203882
LPSN 0
RETU 15
TAHVO 22
AHNE 30
HW 2001
RFIC 17141715
DSP ICPR71_08w17
LCD SEIKO
BT 06cc-P9.2
Simlock Key Cnt 0
Simlock FBUS Cnt 0
MCU Version V 07.16
MCU Date 27-05-08
Product RM-364
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK!
Booting RAP...
Box VPP disabled
Restarting MCU...
Restarting MCU...
Booting RAP...
Bypassing SX4...
Booting RAP...
Box VPP disabled
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Booting RAP...
Box VPP disabled
Restoring NPC...
Restarting MCU...
SX4 Bypass Finished
MCU Version V 07.16
MCU Date 27-05-08
Product RM-364
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Unlock finished!
i think Cyclonebox BB5 Unlocking Solution is same/Copied from zulea trick .and UB loaders ,
See the simlock key it's changed after unlock with GSM Test Equipment , 00101000
best regrads,
..::Angel::..
Old 05-03-2009, 10:35   #6 (permalink)
kikikokoki's Avatar
Member: 748785
Sonork: KIKO_GSM
help rpl IMEI: 12345610654321
RM-217_354864024868284
Old 05-03-2009, 10:39   #7 (permalink)
m_amien's Avatar
Member: 238204
Talking
nothing can help you... use ASK2RPL service if don't have backup...
Old 05-03-2009, 11:22   #8 (permalink)
Member: 91045
Sonork: 100.1577222
Simple Get RPL from Server then Goto Bb5 tab click Plain RPL and Write After that Unlock ur Phone..
@angel
its not important bro who copies from who its all here as TIT for TAT important is who puts it in right manners making easy for people and safe instead for ending up crying on forum...
about this solution UB has notthing to do with it...UB solution was for Rapido phones was stolen not properly by zulea
this working well so enjoy for now...
i wanted to talk to u my sonork not working to day bro uve got msn ?
Old 05-03-2009, 11:27   #9 (permalink)
Member: 643472
Sonork: 100.96901
@angel
sonork is not working today
i m available in msn .but status is Offline
you can talk to me on MSN
Old 05-03-2009, 11:40   #10 (permalink)
NawabN Sahoo's Avatar
Member: 687312
best regrads,
..::Angel::..
AOA sir Would you please give a little bet more detailes about this matter,Do you mean than with Cyclone box there is no need to buy RPL for phones with crupted RPL?
Old 05-03-2009, 11:54   #11 (permalink)
Member: 643472
Sonork: 100.96901
no need to buy if you don't erased ur phone before .and this only for BB5+ PA_SL2 phones not for old bb5 bcoz it has no pm120 filed.
if u have config 0000 than cyclonebox can repair this fault. without buy rpl but if you have invalid npc like IMEI 123456 than you need buy rpl from nokia server no one can calcuate only nokia can do that .from rap id
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 05-03-2009, 12:26   #12 (permalink)
Member: 687312
Thanx sir for your useful information,Sir I can not update my PKey becuase it is Damged By Zulea SW and I intend to buy a new device for Nokia what is your selection among UB, Genie Universal and Cyclone.
Old 05-03-2009, 12:50   #13 (permalink)
Member: 91045
Sonork: 100.1577222
all r good at their work...
professional cant relay on one box
Old 05-03-2009, 12:54   #14 (permalink)
gul_hassan528's Avatar
Member: 420821
Sonork: 100.1603493
dear NawabN Sahoo ub and cyclone is best for nokia this time
The Following User Says Thank You to gul_hassan528 For This Useful Post:
Old 05-03-2009, 13:10   #15 (permalink)
Member: 159880
its better if you have all,but if you need one just for now,if for flashing or unlocking try UB, but if you what new and good update (i hope) buy cyclone...
as for me i like to BUY CYCLONE...
sir amir skillz cyclone box does or doesn't need internet / server connection just to unlock? thank's in Advance
3120c-1 not unlock with JAF_BB5Plus_102 unlock ok with MX-KEY adelgsm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 07-11-2009 19:56
Cyclone Box((First In The World Imei rebuildinG without Unlock ok residentdenuevo Cyclonebox 1 06-09-2009 02:43
3120c unlock ok .::allgsmkey::. Cyclonebox 0 05-22-2009 02:12
nokia 6500s unlock ok jaf bb5 launch plus.thanks.sir RASKEL aleem26 Nokia Base Band 5 ( BB-5 ) 1 03-22-2009 07:58
nokia 6500s unlock ok jaf bb5 launch plus.thanks.sir RASKEL aleem26 BB5 No TP By Jafsupport 4 03-22-2009 02:30
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.54262 seconds with 8 queries
