07-02-2009, 15:45 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Muzaffarabad
Member: 695543 Status: Offline Sonork: 100.1602536 Thanks Meter: 149 | ???????????4 nokia 1600 successly Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.04, (May 12 2009 00:28:13, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: C0000075 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D0000340 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.07v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.82v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.99v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Programming data for IMEI: 358639012137280 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... UPP ID: 2201 [HW_UPP2M_v2] Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00EC2268 @ 0x01000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 0Kbits u_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2268 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Programming FLASH data... FLASH data Programmed OK Programming UEM data... UEM data Programmed OK Terminating flash session Write UEM finished MCU Version V 5.53 MCU Date 20-07-06 Product RH-64 Manufacturer (c) NMP IMEI 358639012137280 Mastercode 6373254220 Asic 2 HW Signature 1E5E5D6FFCA9191A Simlock Server Simlock Key 0010100000000000 Simlock Profile 0000000000000002 Simlock Aux 00020000 Simlock IMEI 00003586390121372800 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[1,2] State: OPENED Type: GID Data: FFFF Simlock[1,3] State: OPENED Type: GID Data: FFFF Simlock[1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[2,2] State: OPENED Type: GID Data: FFFF Simlock[2,3] State: OPENED Type: GID Data: FFFF Simlock[2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[3,2] State: OPENED Type: GID Data: FFFF Simlock[3,3] State: OPENED Type: GID Data: FFFF Simlock[3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[4,2] State: OPENED Type: GID Data: FFFF Simlock[4,3] State: OPENED Type: GID Data: FFFF Simlock[4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[5,2] State: OPENED Type: GID Data: FFFF Simlock[5,3] State: OPENED Type: GID Data: FFFF Simlock[5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[6,2] State: OPENED Type: GID Data: FFFF Simlock[6,3] State: OPENED Type: GID Data: FFFF Simlock[6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[7,2] State: OPENED Type: GID Data: FFFF Simlock[7,3] State: OPENED Type: GID Data: FFFF Simlock[7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RH-64_V 5.53.unlock_img Unlock data not found, Trying to calculate Unlock Codes... #pw+757750777530502+1# #pw+257005573503351+2# #pw+227975444532522+3# #pw+408207526625357+4# #pw+045753060340101+5# #pw+088713501650567+6# #pw+998012414613064+7# Setting factory defaults of: Factory set full Factory defaults set OK |
Nokia 1600 Keypad,1,4,7,* is not Working | akt007 | Nokia Hardware & Hardware Repair | 3 | 03-01-2015 14:27 |
Nokia 1600 imei ????????????4 | aminnovelty | Universalbox | 10 | 02-23-2012 11:37 |
nokia 1600 ?????????????????????4 | theonly1 | Nokia Hardware & Hardware Repair | 1 | 05-01-2009 19:17 |
hiii please dct-4 nokia 1600 2600 .. full patch ?? | teknoloji1907 | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 10-11-2006 20:17 |
