Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-15-2011, 01:23   #1 (permalink)
audymar's Avatar
Member: 1219937
Thanks Meter: 35
5300 nokia only now dead after flash
hi team why error i update sw and box firmware
error n flashing
Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error
Processing Flash Image Failed -> Failed to write all blocks
Failed to Process all Image files -> Failed to process rm146__07.20.mcusw
now phone dead i cannot flash i cannot revive again
Old 04-15-2011, 03:36   #2 (permalink)
audymar's Avatar
Member: 1219937
Thanks Meter: 35
6500 flashing error again..
Old 04-15-2011, 03:48   #3 (permalink)
Member: 1088612
Thanks Meter: 5
try to hwk adn post log
Old 04-15-2011, 03:50   #4 (permalink)
powerlogic's Avatar
Member: 1133716
Thanks Meter: 282
5300 is not RM-240
it is rm 146
and no flashfile for 5300 highier than 7.21
your version is 9.40.
i think you got wrong file ang model selected.
pls check your phone model and corect your file. and try again.
Old 04-15-2011, 03:54   #5 (permalink)
Crazy Poster
Member: 1540257
Sonork: 8105641
Thanks Meter: 16
its is true bro..
5300 is not rm 240
it is rm 146
why you flash in 240....
im sure the IMEI is 1234.......
Old 04-15-2011, 04:04   #6 (permalink)
Member: 1088612
Thanks Meter: 5
5300 rm 240 good flash file try this
Deposit Files
you have rpl backup restore you can fix imei
Old 04-15-2011, 04:08   #7 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
@ powerlogic & ehrah The Log you r seen this is NOKIA 6500 not 5300 . B4 advice read the hole mater
Old 04-15-2011, 04:13   #8 (permalink)
gadgetxxpert's Avatar
Member: 1476674
Thanks Meter: 23
this kind of problem seems to be common now in the new update of cyclone me to having this kind of problem now bad at may part 5130 7.95 original firmware installed in hand set
note this hand set is not water damage or drup
problem humming sound on off hang not shorted very clean board so i try factory reset to cyclone not done so i try flash hand set same version flash not successful hand set dead 5130 sl3 phone now dead in flashing in cyclone so try to find flash file in support German server every time off line i cant download in support so i made thread lackey some one help me but still cyclone cont continue flash hand set 5130 all ways asking cmt id
so i try used mxkey this tool is not offend used by me but suddenly it flashes the 5130 using mxkey not phone is reboot but still problem not fix i try to flash it one more time in cyclone this time it finish flashing but still problem not fix so im waiting for German server to get back on line so i can download the flash file i need,
way coz i believe that when i used that flash file form German server maybe may problem we be fix im not sure but that i hoping for
pls cyclone what it the root of this troubles is it the up date?
so many handset dead after flashing in cyclone
thanks for reading may story
Old 04-15-2011, 04:54   #9 (permalink)
Crazy Poster
Member: 1540257
Sonork: 8105641
Thanks Meter: 16
im sorry.....im wrong ...i am only a person..
@TS your title is wrong also pls check the title of your post.....
Old 04-15-2011, 04:59   #10 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
OKAY NOP
Thread Starter 1st post about Nokia 5300 & in 2nd post he clearly say AGAIN PROBLEM IN NOKIA 6500
Thanks
Old 04-16-2011, 07:14   #11 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
@audymar
Programming Error 3 stands for:
- RX2 not properly connected, mostly caused by poor cables.
- Many times it is caused by hardware. Clean Board and Reheat TAHV0 and RETU.
Br,
Shadab Ahmad
Page generated in 0.22361 seconds with 9 queries
