Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 11-15-2009, 18:43   #1 (permalink)
Member: 761801
5700 power off after 10min
5700 power off after 10min ...
after repair config key fone is ok but shut down after
10 or 15 min ..
any help cyclone team ???
nb : imei is ok
Old 11-15-2009, 18:46   #2 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Post info & selftest logs.... (maybe superdongle Key corrupted, and WD activated)
Old 11-21-2009, 15:37   #3 (permalink)
jichka's Avatar
Member: 18788
Thanks Meter: 10
10 or 15 min ..
nb : imei is ok
Are you solved the problem
Old 11-21-2009, 16:29   #4 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,683
It is mostly due to st_security_test failed.
To tell more, post selftest log.
Old 11-21-2009, 16:35   #5 (permalink)
jichka's Avatar
Member: 18788
Thanks Meter: 10
I make selftest with UB
MCU Nokia Version: 1.126, and up to date.
SMCU Nokia Version: 1.44, and up to date.
Detecting BB5 USB device...
Reading Info...
Soft Version: V 05.11 Date: 21-04-08 Type: RM-230 (5700 XPRESS MUSIC) Pack: (c) Nokia
Product code: 0544927
Product code: 0536943
Radio: GSM850 / GSM900 / GSM1800 / GSM1900 / WCDMA I
Original IMEI: 353964-01-********
Production serial: CZA124589
HW Version: 0602
DSP Version: 06w41pb_08w08.0.1_rm230
LCD Version:
APE ADSP Version: 256
SIMLock service: SIMLOCK SERVER [040A0C060A04]
Profile bits: 0000000000000000
Simlock config: 2440700000000000
Invalid codes entered: 0 / 0
Block: 1; Lock: 1; State: Open; Data: FFFFFF
Block: 2; Lock: 1; State: Open; Data: FFFFFF
Block: 3; Lock: 1; State: Open; Data: FFFFFF
Block: 4; Lock: 1; State: Open; Data: FFFFFF
Block: 5; Lock: 1; State: Open; Data: FFFFFF
Block: 6; Lock: 1; State: Open; Data: FFFFFF
Block: 7; Lock: 1; State: Open; Data: FFFFFF
All locks are open.
Security code: 12345
Executing self tests...
Passed [2E] ST_TAHVOINT_TEST
Passed [03] ST_UEM_CBUS_IF_TEST
Passed [0C] ST_EAR_DATA_LOOP_TEST
Passed [0D] ST_SIM_CLK_LOOP_TEST
Passed [5D] ST_SIM_IO_CTRL_LOOP_TEST
Passed [5A] ST_SECURITY_TEST
Passed [02] ST_PWR_KEY_TEST
Passed [14] ST_CURRENT_CONS_TEST
Passed [38] ST_BACKUP_BATT_TEST
Passed [60] ST_SLEEPCLK_FREQ_TEST
Passed [65] ST_HOOKINT_TEST
Passed [6C] ST_BTEMP_TEST
Not executed [56] ST_EXT_DEVICE_TEST
Not executed [53] ST_CDSP_RF_BB_IF_TEST
Not executed [55] ST_CDSP_RF_SUPPLY_TEST
Not executed [4A] ST_CDSP_TX_IQ_TEST
Not executed [52] ST_CDSP_TXC_DATA_TEST
Not executed [4F] ST_CDSP_PWR_DETECTOR_BIAS_TEST
Not executed [50] ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Not executed [4B] ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Not executed [51] ST_CDSP_WCDMA_TX_POWER_TEST
Not executed [4D] ST_CDSP_RX_IQ_LOOP_BACK_TEST
Not executed [00] ST_CDSP_GSM_TX_POWER_TEST
TBB5SelfTestThread 2.8.2.2474 finished at: 2009/11/21 15:25:18
Old 11-21-2009, 16:47   #6 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
You may try reflashing it to latest version,
proceeding with SX4 again and writing EM calibration again (pm1, pm309).
If problem will still exist s- that's mostly HW fault.
Old 01-07-2010, 19:18   #7 (permalink)
beo_tech's Avatar
Member: 222999
Thanks Meter: 74
hi .....
i have the same problem please need help here is log:
BB5 Unlock Started...
MCU Version V 04.21
MCU Date 04-10-07
Product RM-230
Manufacturer (c) Nokia
IMEI 353964011537743
Mastercode 317214123
Simlock Server SIMLOCK SERVER
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101011103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 03F00004574F0058B9BC0C26E4136956A3B7DA40
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C
CMT_ROM_ID: F2C6EBADC86E6189
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC003000400121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 3D66090E94F3701646DA91CCD35BBAC22E5CBF73
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Determined PA Simlock: PA_SL
Checking for Rootkey Hash support and selecting Unlock Method...
Selected Unlock Method: PM Security Block Calculation
Booting RAP...
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Received Security Block OK !
Writing Security Block...
SP Accepted, doing reset to update block...
MCU Version V 04.21
MCU Date 04-10-07
Product RM-230
Simlock Profile 8000000000000006
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Unlock finished!
Selftests to proceed: 31
Passed ST_TAHVOINT_TEST
Passed ST_UEM_CBUS_IF_TEST
Passed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Passed ST_SIM_IO_CTRL_LOOP_TEST
Passed ST_SECURITY_TEST
Passed ST_PWR_KEY_TEST
Passed ST_CURRENT_CONS_TEST
Passed ST_BACKUP_BATT_TEST
Passed ST_SLEEPCLK_FREQ_TEST
Passed ST_HOOKINT_TEST
Passed ST_BTEMP_TEST
Passed ST_EXT_DEVICE_TEST
Passed ST_CDSP_RF_BB_IF_TEST
Passed ST_CDSP_RF_SUPPLY_TEST
Passed ST_CDSP_TX_IQ_TEST
Passed ST_CDSP_TXC_DATA_TEST
Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST
Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Passed ST_CDSP_WCDMA_TX_POWER_TEST
Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST
Passed ST_CDSP_GSM_TX_POWER_TEST
Passed ST_IR_LOOP_TEST
Passed ST_KEYBOARD_STUCK_TEST
Passed ST_LPRF_IF_TEST
Passed ST_CAMERA_IF_TEST
Passed ST_LPRF_AUDIO_LINES_TEST
Passed ST_MAIN_LCD_IF_TEST
Passed ST_BT_WAKEUP_TEST
Passed ST_BT_SLEEP_CLK_TEST
Selftests done, Tests total: 31, Tests passed: 30, Tests not passed: 1
Old 01-08-2010, 10:44   #8 (permalink)
beo_tech's Avatar
Member: 222999
Thanks Meter: 74
any help ...............?????????????
Old 01-08-2010, 11:31   #9 (permalink)
.::Dr.Gsm::.'s Avatar
Member: 238374
Sonork: 100.1597005
Thanks Meter: 1,084
try to repair super dongle key
Old 01-08-2010, 11:39   #10 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 13,995
Security test is ok.. is not a superdongle problem...
I would check the hardware, expecially the aerial and the battery section
Alex
Old 01-08-2010, 12:30   #11 (permalink)
beo_tech's Avatar
Member: 222999
Thanks Meter: 74
thanks MR moulnisky for reply......
the set power off when in calling and when playing music...
i change batterie but in vain...
Old 01-08-2010, 20:49   #12 (permalink)
hackgsm's Avatar
Member: 64014
Sonork: 100.1603152
Thanks Meter: 255
imei problem ..........just new rpl
Old 01-09-2010, 09:12   #13 (permalink)
Member: 132881
Thanks Meter: 94
that is 100 percent superdongle problm.if you have ub you can repair it.i have done many with that prob.
Old 01-09-2010, 10:00   #14 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,358
superdongle problm
This is the problem of superdongle. Use the Universal Box to repair it.
BR.
[email protected]
The Following User Says Thank You to Dipendra Pathak For This Useful Post:
Old 01-10-2010, 17:12   #15 (permalink)
beo_tech's Avatar
Member: 222999
Thanks Meter: 74
imei 353964011537743 is ok
BB5 power off after (20min,10min...) FINAL SOLUTION foufou34 MT-BOX 233 09-17-2010 12:08
Default BB5 power off after 20min,10min... FINAL SOLUTION Jilani001 Nokia Base Band 5 ( BB-5 ) 8 01-20-2010 11:16
BB5 power off after (20min,10min...) FINAL SOLUTION [email protected] Nokia Base Band 5 ( BB-5 ) 11 08-04-2009 05:19
6267 power off after 10min genci titi 2002 Nokia Base Band 5 ( BB-5 ) 2 01-12-2009 12:35
6267 power off after 10min genci titi 2002 Nokia Hardware & Hardware Repair 3 01-12-2009 11:03
Page generated in 0.45153 seconds with 8 queries
