03-10-2010, 14:04 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Russia Age: 45
Member: 31044 Status: Offline Thanks Meter: 0 | 5700 simlock fail, need help. -- SECURITY PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. If security problem still exists - check CCC and HWC Certificates. -- SECURITY PROBLEM -- Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "04B001085C4F00589FF2ABA262DA71C7CCAE76BE.C0003640 " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... CMLA KEYS FOUND AND CHECKSUM OK! PASSED! Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! FullErase by 128Mbit file Flash 03.83 RPL SX4 PM HWC+CCC No result, still simlock |
03-10-2010, 14:07 | #2 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | 5700 simlock fail solu 5700 simlock fail solu cyclone box.png |
03-10-2010, 14:15 | #3 (permalink) |
Member: 31044 Status: Offline Thanks Meter: 0 | Step 1 : Testing SIMLOCK -- SECURITY PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. If security problem still exists - check CCC and HWC Certificates. -- SECURITY PROBLEM -- Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "04B001085C4F00589FF2ABA262DA71C7CCAE76BE.C0003640 " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... CMLA KEYS FOUND AND CHECKSUM OK! PASSED! Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! MAybe i need another PM? |
03-10-2010, 14:18 | #4 (permalink) |
Member: 823633 Status: Offline Thanks Meter: 1,705 | 5700 Full Modified PM here 5700 Full Modified PM here 5700 Full Modified PM.rar |
03-10-2010, 14:23 | #6 (permalink) |
Member: 31044 Status: Offline Thanks Meter: 0 | Step 1 : Testing SIMLOCK -- SECURITY PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. If security problem still exists - check CCC and HWC Certificates. -- SECURITY PROBLEM -- Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "04B001085C4F00589FF2ABA262DA71C7CCAE76BE.C0003640 " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... CMLA KEYS FOUND AND CHECKSUM OK! PASSED! Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! |
03-11-2010, 07:13 | #7 (permalink) |
Member: 31044 Status: Offline Thanks Meter: 0 | Also can't read 308 block Starting PM read in range 308-308... [308] Reading 8 records [308,0] Reading 50593800 bytes Failed to read PM -> Failed to read PM Record 308,0 |
03-11-2010, 08:05 | #8 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | did you follow the instructions in this thread? http://forum.gsmhosting.com/vbb/f528...phones-819077/ BR Alex |
5700 simlock repair, need some help | Alex1234 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-16-2010 07:59 |
nokia 6085 invalid simlock mxkey need help | sameed_j | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-09-2010 15:31 |
Nokia 5800 Simlock Repair failed..Need help | wmli | Universalbox | 11 | 12-02-2009 13:53 |
5700 no sim need helpe | nokia-ps | Nokia Hardware & Hardware Repair | 1 | 10-28-2008 07:40 |
**Box Login Failed**Need Help | shahjee | Cruiser Suite | 4 | 08-22-2006 09:10 |
