01-06-2010, 03:44 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: San Pedro Sula
Member: 909015 Status: Offline Thanks Meter: 75 | 5800 Big Problem [SOLVED] The real imeiīs phone is 359348023406929 product code 0581855 pleaseeeeeee help Last edited by moulnisky; 01-08-2010 at 19:31. |
01-06-2010, 05:01 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | put all the back-ups you have of this mobile in a zip file and post them here, we will have a look if there is any solution. Make a serach on your computer for al the files with as name the first 14 numbers of the imei. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
01-06-2010, 17:42 | #3 (permalink) | |
Member: 909015 Status: Offline Thanks Meter: 75 | Quote:
Im sorry I couldn't upload the file to te forum, but here are all the backups http://rapidshare.com/files/33127196...06929.zip.html Last edited by fabrtz; 01-06-2010 at 17:48. | |
01-06-2010, 21:06 | #4 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | start doing click on "write certs" and select the file 06B000116C7C005238764E3A89F8F9D6567819B3.Sx4Bypass .NPC.CMT.crt with this the imei should be ok afterward close the cyclone suite, open it again and write the plain rpl attached in this post. let me know BR Alex |
01-06-2010, 22:27 | #5 (permalink) | |
No Life Poster Join Date: Sep 2008
Member: 868940 Status: Offline Thanks Meter: 90 | Quote:
01-06-2010, 22:29 | #6 (permalink) | |
01-07-2010, 17:29 | #7 (permalink) | |
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8198 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.15, (Jan 2 2010 03:59:40, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application Box Serial Number: C0001562 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D30001D2 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,01v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,78v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,96v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,88v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Processing 06B000116C7C005238764E3A89F8F9D6567819B3.Sx4Bypass .NPC.CMT.crt... CMT NPC Erased CMT NPC Written Write CMT NPC Certificate finished Restarting MCU... All files processed OK! MCU Version V ICPR72_09w20.8 MCU Date 09-07-09 Product RM-428 Manufacturer (c) Nokia IMEI 359348023406929 Mastercode 267755174 IMEI Spare 3A95430832049602 IMEI SV 3395430832049602F7000000 PSN CZC269260 Product Code 0561618 Basic Product Code 0559231 PSD 0000000000000000 LPSN 0 WLAN MAC 0026689F1628 APE SW V 31.2.008 APE Variant V 31.2.008 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1101 RFIC 17141715 DSP SANGALO_ICPR72_09w19_1 Failed to read info -> Failed to read SP info Failed to Write PM -> No file assigned by user Failed to Write RPL File -> RPL File invalid, not begins with `REBUILD DATA` Magic, Maybe it is PLAIN ONE ? Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Simlock... Simlock NOT ACCEPTED ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing FBUS Part... Writing Simlock... Simlock NOT ACCEPTED ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Restarting MCU... Write RPL Finished! MCU Version V ICPR72_09w20.8 MCU Date 09-07-09 Product RM-428 Manufacturer (c) Nokia IMEI 359348023406929 Mastercode 267755174 IMEI Spare 3A95430832049602 IMEI SV 3395430832049602F7000000 PSN CZC269260 Product Code 0561618 Basic Product Code 0559231 PSD 0000000000000000 LPSN 0 WLAN MAC 0026689F1628 APE SW V 31.2.008 APE Variant V 31.2.008 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1101 RFIC 17141715 DSP SANGALO_ICPR72_09w19_1 Failed to read info -> Failed to read SP info IMEI BACK but still problem with SL and no power on | |
01-07-2010, 18:14 | #8 (permalink) | |
After I write RPL with JAF, and this was the log CMT Boot Data: Asic ID: 000000010000022600010006400C192101031103 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 06B000116C7C005238764E3A89F8F9D6567819B3 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: 4B9B75103E691FF8 CMT Boot File: C:\Archivos de programa\ODEON\JAF\Flash\RAPIDOv11_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Archivos de programa\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.23.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Done! Restarting phone...Done! Scanning RPL file... NPC DATA NOT FOUND... VARIANT DATA NOT FOUND... CCC DATA NOT FOUND... HWC DATA NOT FOUND... NPC APE DATA NOT FOUND... VARIANT APE DATA NOT FOUND... CCC APE DATA NOT FOUND... HWC APE DATA NOT FOUND... SIMLOCK DATA OK... SIMLOCK KEY DATA OK... SUPERDONGLE KEY DATA NOT FOUND... CMLA KEY DATA NOT FOUND... WMDRM PD DATA NOT FOUND... Connecting to phone... Writing SIMLOCK DATA and SIMLOCK DATA KEY... FAST PHONE detected! CMT Boot File: C:\Archivos de programa\ODEON\JAF\Flash\RAPIDOv11_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Archivos de programa\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.23.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Restarting phone... Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V ICPR72_09w20.8 09-07-09 RM-428 (c) Nokia HW version: 1101 PCI version: RFIC version: DSP version: Retu version: 16 Tahvo version: 22 Production serial number: CZC269260 Product code: 0561618 Module code: Basic production code: 0559231 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 359348023406929 IMEI spare to net: 3A 95 43 08 32 04 96 02 IMEI SV to net: 33 95 43 08 32 04 96 02 F7 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-428.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0561618 Searching for JAF saved location of ini... Checking path: C:\Archivos de programa\Nokia\Phoenix\Products\RM-428\ Searching for default location of ini... Checking path: C:\Archivos de programa\Archivos comunes\Nokia\DataPackage\Products\RM-428\ Searching for JAF saved location of ini... Checking path: C:\Archivos de programa\Nokia\Phoenix\Products\RM-428\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! | |
01-07-2010, 18:42 | #10 (permalink) |
Member: 909015 Status: Offline Thanks Meter: 75 | |
01-07-2010, 21:00 | #11 (permalink) | |
an small doubt, I open the RPL file and i can see something [CERT_PROG_DATA_OUT_CMT] SIMLOCK_DATA_1=72E71606EEC5BBA80AFA8D062B7FAA04DD9 9A8268000000000000000704010108642481000180500 SIMLOCK_DATA_2=000000000040000001FFFFFF0054000001F FFFFF0068000001FFFFFF007C000001FFFFFF00900000 SIMLOCK_DATA_3=01FFFFFF000000007FFF6F07FFFFFFFFF80 000A403000502000000007FFF6F07FFFFFFFF80000000 SIMLOCK_DATA_4=00000000704010108642481000180500000000000040000001FFFFFFBE94397 E0D8E3A7E78040D00 SIMLOCK_DATA_5=2000000094040B0001000002000000009E0 2000001000000647B6F0182214C000000000003000502 SIMLOCK_DATA_6=00000000 SIMLOCK_KEY_DATA_1=7FF66721EC60DD89F8E9DC2038A26E9 88893E8ECBBFE6F361510E5571799E40D5638037F1E2AA35F SIMLOCK_KEY_DATA_2=1EF8E1DBAF0E56B8D4C6D61D9F9349F 6589DDE8F1A4708CE84542B676D6C885A3ED8912A22C80774 SIMLOCK_KEY_DATA_3=4932C54848EFF436F25DB474BD1BF29 F23B0842B it does not matter the phone is already unlocked and in the RPL file i can see there is the numbers from the company my phone was locked to | |
01-07-2010, 21:05 | #12 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Donwload this file http://rapidshare.com/files/28293637...covery_kit.zip Inside there is an eno file for the rm-356 flash the mobile using this file as mcu and afterward flash it again with the actual firmware. Please, let me know if it switches on afterward BR Alex |
01-07-2010, 23:01 | #13 (permalink) | |
Scanning avaiable products... Processing C:\Archivos de programa\Nokia\Phoenix\Products\... Found 52 products, Filtering DCT4 Products - wait... 15 Products left after filtering. Ready. Scanning avaiable products... Processing C:\Archivos de programa\Nokia\Phoenix\Products\... Found 52 products, Filtering BB5 Products - wait... 18 Products left after filtering. Ready. Retrieving Variants for Product RM-428 - wait... 1 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone WMDRM Store not supported Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Backing up simlock... MCU Version V ICPR72_09w20.8 MCU Date 09-07-09 Product RM-428 Manufacturer (c) Nokia IMEI 359348023406929 Mastercode 267755174 Simlock backup OK, saved to RM-428_359348023406929_07012010_34514 p.m..SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm346_300.21.012_prd.c00 (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 rm346_300.21.012_prd.c00, Type: Flash Image, Algo: BB5, XSR 1.5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x007FFFFF, ONENAND EraseArea[0,CMT]: 0x00A00000-0x0759FFFF, ONENAND EraseArea[0,CMT]: 0x0F1C0000-0x0F8BFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.797s Writing all blocks... Writing CMT ADA Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm346_300.21.012_prd.c00 Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm346_300.21.012_prd.c00 (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 rm346_300.21.012_prd.c00, Type: Flash Image, Algo: BB5, XSR 1.5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x007FFFFF, ONENAND EraseArea[0,CMT]: 0x00A00000-0x0759FFFF, ONENAND EraseArea[0,CMT]: 0x0F1C0000-0x0F8BFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.765s Writing all blocks... Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS*CORE Certificate... Writing CMT SOS+ROFS Certificate... Programming Status OK! All blocks written OK! Time taken 105.453s Restarting MCU... Processing rm346_300.21.012_prd.c00 (APE)... Processing rm346_300.21.012_prd.v17 (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 rm346_300.21.012_prd.v17, Type: Flash Image, Algo: BB5, XSR 1.5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x05420000-0x0759FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.266s Writing all blocks... Writing CMT SOS+ROFX Certificate... Programming Status OK! All blocks written OK! Time taken 71.875s Restarting MCU... Processing rm346_300.21.012_prd.v17 (APE)... Processing rm346_300.21.012.02U (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 rm346_300.21.012.02U, Type: Flash Image, Algo: BB5, XSR 1.5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Started group flash erase Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.359s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 14.234s Restarting MCU... Processing rm346_300.21.012.02U (APE)... Processing RM346_ENO_0741.10_08wk42.a36.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RM346_ENO_0741.10_08wk42.a36.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase Erase Certificate: SOS*ENO (CMT) Waiting 320s for erasure finish... Erase taken 0.16s Writing all blocks... Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 2.609s Restarting MCU... Processing RM346_ENO_0741.10_08wk42.a36.fpsx (APE)... Processing leevi_erase_y_drive.fpsx (CMT)... Processing leevi_erase_y_drive.fpsx (APE)... All images processed OK! Processing post flash tasks... Reading info... Failed to read info -> Phone not detected Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Scanning avaiable products... Processing C:\Archivos de programa\Nokia\Phoenix\Products\... Found 52 products, Filtering BB5 Products - wait... 18 Products left after filtering. Ready. Retrieving Variants for Product RM-428--- - wait... 6 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing RM-428_21.2.025_prd.core.C00 (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RM-428_21.2.025_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND EraseArea[0,CMT]: 0x00D60000-0x09E5FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.891s Writing all blocks... Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*ENO Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 140.515s Restarting MCU... Processing RM-428_21.2.025_prd.core.C00 (APE)... Processing RM-428_21.2.025_prd.rofs2.V08 (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RM-428_21.2.025_prd.rofs2.V08, Type: Flash Image, Algo: XSR 1.5, BB5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x06560000-0x0915FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.250s Writing all blocks... Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 84.922s Restarting MCU... Processing RM-428_21.2.025_prd.rofs2.V08 (APE)... Processing RM-428_21.2.025_C03_prd.rofs3.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RM-428_21.2.025_C03_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x09160000-0x09E5FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.78s Writing all blocks... Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 1.172s Restarting MCU... Processing RM-428_21.2.025_C03_prd.rofs3.fpsx (APE)... Processing RM356_20.0.010_008_xxx_U01.uda.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 06B000116C7C005238764E3A89F8F9D6567819B3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RM356_20.0.010_008_xxx_U01.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x09E60000-0x0F71FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.484s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 8.16s Restarting MCU... Processing RM356_20.0.010_008_xxx_U01.uda.fpsx (APE)... All images processed OK! Processing post flash tasks... Reading info... MCU Version V ICPR72_09w06.2 MCU Date 03-03-09 Product RM-428 Manufacturer (c) Nokia IMEI 359348023406929 Mastercode 267755174 IMEI Spare 3A95430832049602 IMEI SV 3395430832049602F6000000 CNT v 20.0.010_008_xxx_U01, 21-01-09, vanilla, RM356 PSN CZC269260 Product Code 0561618 Basic Product Code 0559231 PSD 0000000000000000 LPSN 0 WLAN MAC 0026689F1628 APE SW V 21.2.025 APE Variant V 21.2.025V 52.50.2009.21.2.025 V 52.50.2009.21.2.025 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1101 RFIC 17141715 DSP sangalo_ICPR72_09w06_p1 Failed to read info -> Failed to read SP info Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! MCU Version V ICPR72_09w06.2 MCU Date 03-03-09 Product RM-428 Manufacturer (c) Nokia IMEI 359348023406929 Mastercode 267755174 IMEI Spare 3A95430832049602 IMEI SV 3395430832049602F6000000 CNT v 20.0.010_008_xxx_U01, 21-01-09, vanilla, RM356 PSN CZC269260 Product Code 0561618 Basic Product Code 0559231 PSD 0000000000000000 LPSN 0 WLAN MAC 0026689F1628 APE SW V 21.2.025 APE Variant V 21.2.025V 52.50.2009.21.2.025 V 52.50.2009.21.2.025 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1101 RFIC 17141715 DSP sangalo_ICPR72_09w06_p1 Failed to read info -> Failed to read SP info Im starting to give up | |
Big problem solved | sainu | Nokia Base Band 5 ( BB-5 ) | 2 | 07-10-2011 11:05 |
plz i have a big problem[SOLVED by USER] | lloydgsm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 03-16-2010 18:46 |
5800 big problem | janek233 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-16-2010 10:38 |
big problem solved in singmatel s3 | venusmobilecare | Chinese Models & Cloned Phones | 3 | 06-25-2008 23:13 |
