Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-01-2009, 17:44   #1 (permalink)
Member: 270521
Sonork: 100.15962233
Thanks Meter: 369
5800 not completely flashed
Hi, its my second 5800 which i tried to flash with cyclon and it stucks here can u please check where i'm wrong.
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC
Box Serial Number: C000110E
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk14
Initializing security card...
Card Serial Number: D3000364
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.15v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 0.69v PASSED
VBAT Voltage 5.05v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 5.06v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Found 17 products, Filtering BB5 Products - wait...
10 Products left after filtering. Ready.
Retrieving Variants for Product RM-356 - wait...
73 Variants Retrieved
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 12B0010B57750052AF8E1A244B7D4FD7284FAEF3
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_ROM_ID: 4B9B75103E691FF8
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5
Flashbus Write baud set to 4.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61
APE Subsystem Not Found
Restarting MCU...
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Simlock Store not supported, not a PA_SL2 Phone
WMDRM Store not supported
Booting RAP...
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Backing up simlock...
MCU Version V ICPR72_08w47.1
MCU Date 23-01-09
Product RM-356
Manufacturer (c) Nokia
IMEI 353205035795978
Mastercode 5421177346
Simlock backup OK, saved to RM-356_353205035795978_01082009_173833.SLBackup.PM
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Processing RM-356_20.0.012_prd.core.C00 (CMT)...
Booting RAP...
RM-356_20.0.012_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5
Flashbus Write baud set to 650Kbits
Box VPP disabled
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND
EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND
EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND
EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND
EraseArea[0,CMT]: 0x00D60000-0x09E5FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 0.922s
Writing all blocks...
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*ENO Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 125.937s
Restarting MCU...
Processing RM-356_20.0.012_prd.core.C00 (APE)...
Processing RM-356_20.0.012_prd.rofs2.V11 (CMT)...
Booting RAP...
Processing Flash Image Failed -> RAP Not Responding
Failed to Process all Image files -> Failed to process RM-356_20.0.012_prd.rofs2.V11
Old 08-01-2009, 18:42   #2 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,103
Did you thick "repower on boot"?
Alex
Old 08-02-2009, 05:49   #3 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,691
i thing that wont gona Help him...as happened to me Before
This is phone which need bigger delay between flashing initialization, or a bit changed booting procedure,
phone can be flashed file after file,
So for now can flash each seprate (MCU PPM CNT)
i thing an update FW should come to solve this problem
or try flashing with USB
Old 08-02-2009, 09:40   #4 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
Thanks Meter: 26,419
exactly this fone need bigger delay between flashing initialization, so temporary flashing mcu and ppm seperatly wil work out anyway this will be fixed asap
wbr
SiRoYa
Old 08-02-2009, 09:53   #5 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,515
Correct, all RAPIDO phones needs .
Old 08-18-2009, 16:33   #6 (permalink)
jufong's Avatar
Member: 120908
Thanks Meter: 37
so how to resolved this problem
or that is cable problem
Old 08-19-2009, 05:47   #7 (permalink)
Member: 91045
Thanks Meter: 8,691
To resolve ... Try with Newer Bulk Update Flashing ....
If still same (think Not) Then u should Flash MCU PPM and CNT one by one Seprately....
Old 08-26-2009, 20:10   #8 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,714
Firmware v1.0.6 have solved this problem
The Following User Says Thank You to karwos For This Useful Post:
Old 08-28-2009, 17:49   #9 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 199
I am new on CycloneBox, wher can I see the version of software pls ?
Best Regards,
JAVA Good.
Old 08-28-2009, 17:56   #10 (permalink)
moulnisky's Avatar
Member: 947561
Just follow the instructions in this thread
*** Cyclone Box - Download - Installation - First Steps ***
Alex
N70 not complete flashing in PPm please help russell_07 Universalbox 1 12-02-2008 08:17
6680 not complete flash zeroualot_7 MT-BOX 1 02-28-2007 14:34
D600 can't not complete flashing ..... TPS UST Pro II 3 04-14-2006 20:20
Page generated in 0.36525 seconds with 8 queries
