| Freak Poster
Member: 1133716
| backup cert ok
full earse
after full earse write eno file
writing eno file
log: Quote:
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 1AB00108117D0052513194569C1E614AE8B7D891
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0xFFFFFFFF00000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND
Requested Algorithm: XSR 1.5 (CMT)
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
Warning: PAPUBKEYS Hash Missing!
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Sending User Abort Signal...
CBUS Request Error -> User abort
Failed to disable VBAT -> No answer from CBUS
Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE Subsystem Not Found
CMT NPC Not Found
CMT CCC Not Found
CMT HWC Not Found
CMT VARIANT Not Found
CMT PARTNERC Not Found
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Pre flash tasks finished, continuing...
Processing rm356_ENO_x_2008wk42v0.033.fpsx (CMT)...
Booting CMT...
CMT Ready!
rm356_ENO_x_2008wk42v0.033.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
Flashbus Write baud set to 650Kbits
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND
EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND
EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND
EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND
EraseArea[0,CMT]: 0x00D60000-0x0A81FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 0.969s
Writing all blocks...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
Writing CMT PAPUBKEYS Certificate...
Writing CMT SOS*ENO Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT SOS*ISASW Certificate...
Programming Status OK!
All blocks written OK! Time taken 8.125s
Flashing Speed: 6611.16 kBit/S
Restarting MCU...
Processing rm356_ENO_x_2008wk42v0.033.fpsx (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults..
not respnding
still no power
after eno flashed
full flash
log: Quote:
Booting CMT...
CMT Ready!
RM-356_60.0.003_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5
Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol)
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Using OLD BB5 FLASHING PROTOCOL
FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5
Flashbus Write baud set to 2.0Mbits
Box VPP disabled
PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00D60000-0x09E5FFFF, ONENAND
Erase taken 0.875s
TurboCache Loaded!
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
All blocks written OK! Time taken 143.953s
Flashing Speed: 6436.02 kBit/S
Restarting MCU...
Processing RM-356_60.0.003_prd.core.C00 (APE)...
Processing RM-356_60.0.003_prd.rofs2.V03 (CMT)...
Booting CMT...
CMT Ready!
RM-356_60.0.003_prd.rofs2.V03, Type: Flash Image, Algo: XSR 1.5, BB5
Box VPP disabled
EraseArea[0,CMT]: 0x07180000-0x0915FFFF, ONENAND
Erase taken 0.171s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 31.796s
Flashing Speed: 6282.82 kBit/S
Restarting MCU...
Processing RM-356_60.0.003_prd.rofs2.V03 (APE)...
Processing RM-356_60.0.003_C02_prd.rofs3.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM-356_60.0.003_C02_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
Box VPP disabled
EraseArea[0,CMT]: 0x09160000-0x09E5FFFF, ONENAND
Erase taken 0.93s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 1.547s
Flashing Speed: 5939.52 kBit/S
Restarting MCU...
Processing RM-356_60.0.003_C02_prd.rofs3.fpsx (APE)...
Processing RM356_60.0.003_005_U226.uda.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM356_60.0.003_005_U226.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
Box VPP disabled
EraseArea[0,CMT]: 0x09E60000-0x0F71FFFF, ONENAND
Erase taken 0.484s
TurboCache Loaded!
All blocks written OK! Time taken 11.625s
Flashing Speed: 5669.10 kBit/S
Restarting MCU...
Processing RM356_60.0.003_005_U226.uda.fpsx (APE)...
Setting Factory Defaults...
| phone not responding
no luck !!!
what is next? |
