Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 07-23-2009, 15:52   #1 (permalink)
Member: 16943
6110N problem
hi
i have one 6110N after i power on, appears white screen and after several seconds, it autopower off, i have read the phone with jaf and it seems all is good, no imei, provider o simlock wrong but i have read only one time, the time i read the info but after that, imposible to read it again.
now i have cyclonebox and when i try to read the phone, i have the box led red usb lighting and a windows telling me "phone was not detected at fbus interface-even after repowering it. please power it on manually now and click retray when local/test mode appears in display".
the cable is good because i try to read another good 6110n and no problem
what can i do?
thanks
Old 07-23-2009, 17:20   #2 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Looks like ape problem..
You can try going in the tab BB5/flash and doing click on "check flashing bus" if you get successfull the information you can read afterward the info and do the self test.
If you get both just post the logs here and we can look for a solution
Alex
Old 07-26-2009, 02:53   #3 (permalink)
Member: 16943
hi
very strange problem, i try with check flashing bus and not success, i don't remember the answer (next update, please, log backup) but when i try for second or third time ( i don't remember), i have good answer, i can read info and to do all the security backups, then i try with jaf and is working, i try to power on the phone and is working good, i don't understand it.
what do you thing?
thanks
Old 07-26-2009, 04:17   #4 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
i think cable was not fitted properly as it should be ...
TX 2 adapter is connected rite ?
When u get Restarting MCU there ur phone should come into Needed mode for Reading INFO Unlock making backup ETC
perhaps i say might be bad communication between cable and phone
Old 07-27-2009, 00:12   #5 (permalink)
Member: 16943
hi
cable not was the problem because i have used with other 6110n in the same day and works perfect but remember the phone after i power on, appears white screen and after several seconds, it autopower off and now is working, where is the mistery?
thanks
Old 07-27-2009, 05:16   #6 (permalink)
Member: 575900
well u cant try flashing ur PHONE with USB and see if problem exist or Recovered
6110n microphone problem momayaz Nokia Hardware & Hardware-Repair Area 20 08-25-2009 11:30
problem unlock 6110n mohamed bessa Nokia Base Band 5 ( BB-5 ) 4 04-13-2009 18:10
6110n problem unnis Nokia Base Band 5 ( BB-5 ) 4 03-20-2009 15:25
what about 6110n flash problem wisam_wa J.A.F. By Jafsupport.com 14 09-04-2007 08:39
Page generated in 0.45589 seconds with 11 queries
