03-10-2010, 13:09 | #1 (permalink) |
Freak Poster Join Date: Feb 2003
Member: 23459 Status: Offline Thanks Meter: 29 | 6120c Analyze Security Problem Code: Started Phone Security Analysis... MCU Version V 07.10 MCU Date 15-07-09 Product RM-243 Manufacturer (c) Nokia IMEI 359342034081789 Mastercode 7277135710 Reading Security Block... Security block OK and saved to "RM-243_359342034081789_10-03-10_80607 PM.SecurityBlock.PM" Step 1 : Testing SIMLOCK -- SECURITY PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. If security problem still exists - check CCC and HWC Certificates. -- SECURITY PROBLEM -- Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block WARNING: "1F700109F2308D525A503BEBE6754FA977E7B8F6.C00010B0" Not Exists, Will read it... Reading CYC file from phone... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1F700109F2308D525A503BEBE6754FA977E7B8F6 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "1F700109F2308D525A503BEBE6754FA977E7B8F6.C00010B0" Checking SUPERDONGLE... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking MCU&DSP TIMESTAMPS... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Analyze finished! |
03-10-2010, 13:23 | #2 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | 6120c solu 6120c solu.............. cyclone box.png |
The Following User Says Thank You to vaghubha_sodha For This Useful Post: |
03-10-2010, 18:26 | #3 (permalink) | |
Member: 23459 Status: Offline Thanks Meter: 29 | Quote:
What i mean is the analyze report maybe got problem because i test on new set not 1 set but 1-5 set all same. all set i test is in good condition so no problem with the set. I'm just curios why analyze report show it got problem on security section. | |
03-11-2010, 08:27 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | The 6120 needs a stable local mode and loads of power to work on it. Use a TMA adapter (Better the evo version) make RPL from phone (So it creates the file CYC needed) and afterward work on it BR Alex |
5800 analyze security problem | nunu.gabriel | Cyclonebox | 10 | 05-14-2010 08:56 |
6120c network pcn problem | jettlee | Nokia Hardware & Hardware Repair | 1 | 01-16-2010 10:27 |
nokia 6120c the same problem after flach !!! | seddik-gsm | Nokia Base Band 5 ( BB-5 ) | 6 | 05-18-2009 08:59 |
6120c Autor camera problem... | manyosa | Nokia Hardware & Hardware Repair | 3 | 12-13-2008 12:26 |
analyze the problem and apply the solution | _iskor_ | Nokia Hardware & Hardware Repair | 6 | 01-31-2006 17:19 |
