01-13-2010, 10:57 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Romania Age: 53
Member: 1169376 Status: Offline Sonork: 100.1618134 Thanks Meter: 8 | 6234 flash problem - need advice [SOLVED] MCU Version V 03.70 MCU Date 15-05-06 Product RM-123 Manufacturer (c) Nokia IMEI 359395004022530 Mastercode 3647634716 Simlock backup OK, saved to RM-123_359395004022530_13.01.2010_113504.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm123_145_30003.700.mcusw (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 10D0001154BF005473FBC0A30492DFF2DF3F9370 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F rm123_145_30003.700.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 2F36DDC4990FD844712A61A80C033211BD9602E3 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0000FFFF, NOR EraseArea[0,CMT]: 0x00010000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x000A0000-0x0021FFFF, NOR EraseArea[0,CMT]: 0x00220000-0x011DDFFF, NOR EraseArea[0,CMT]: 0x011DE000-0x011DEFFF, NOR EraseArea[0,CMT]: 0x011DF000-0x011DFFFF, NOR Waiting 320s for erasure finish... Erase taken 56.797s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm123_145_30003.700.mcusw Thanks |
01-13-2010, 11:32 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Use the TX2 adapter (the yellow cable in bundle with the box) If you are using it, try flashing the mobile with "use TX2" not thicked BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
01-13-2010, 11:58 | #3 (permalink) |
Member: 1169376 Status: Offline Sonork: 100.1618134 Thanks Meter: 8 | Best regards for "Product Supporter", always I have quickly response from them, seen as involved. Thanks again. P.S. Flashed works OK without TX2. |
6234 Flashing problem... | adnanskyland | HWK | 1 | 09-04-2008 08:55 |
N70 flashing problem need advice | kungpaoski | Nokia Base Band 5 ( BB-5 ) | 5 | 11-07-2007 18:28 |
6233 6234 flash problem BIG BIG THING!!!!!!!!! HELP!!! | maniek27 | HWK | 4 | 11-11-2006 22:10 |
8910 Flashing Problem, Need Advice Please... | Rizal Arsyad Dini | Griffin | 0 | 07-29-2004 08:20 |
