Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > Cyclonebox
Old 06-12-2010, 15:09   #1 (permalink)
Member: 146708
Sonork: 100.108221
6300i Security Test Fail..Contact Service..
hi supporters..
can i fix this pb by cyclone..? i have full pm from anther phone.. can u help me pls..
self test inf..
Passed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Passed ST_SIM_IO_CTRL_LOOP_TEST
Passed ST_SLEEP_X_LOOP_TEST
Passed ST_UEM_CBUS_IF_TEST
Passed ST_KEYBOARD_STUCK_TEST
Passed ST_CAMERA_IF_TEST
Passed ST_BACKUP_BATT_TEST
Passed ST_LCD_TEST
Passed ST_LPRF_IF_TEST
Passed ST_LPRF_AUDIO_LINES_TEST
Passed ST_CURRENT_CONS_TEST
Passed ST_RADIO_TEST
Passed ST_BACKLIGHT_TEST
Passed ST_SIM_LOCK_TEST
Failed ST_SECURITY_TEST
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
Old 06-12-2010, 15:33   #2 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: 100.1614583
yes click sx4 authrorize/repair SD
Old 06-12-2010, 15:37   #3 (permalink)
Member: 146708
Sonork: 100.108221
yes i did..
nothing changed..strill same..
Old 06-12-2010, 16:16   #4 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: 100.1614583
post info log and security anaylize log
Old 06-12-2010, 16:24   #5 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: 100.1614583
or save to notepad this and save as RPL
tick plain RPL and write saved RPL
[CERT_PROG_DATA_OUT_CMT]
CCC_DATA_1=4343434302004150010000009138E0941D18B84 6C3115600EC969B00000060010000000000000000
CCC_DATA_2=000000000000000000000000000000000000000 00000000000000000000000003035353436303043
CCC_DATA_3=B8A5F5420000000000000000010000000E00000 00000000000000000000000000000000000000000
CCC_DATA_4=000000000000000000000000000000000000000 00000000000000000000000000000000000000000
CCC_DATA_5=000000000000000000000000000000000000000 00000000000000000000000000000000000000000
CCC_DATA_6=000000000000000000000000000000000000000 0000000003A7B4A205F7634485B2E7244956D013A
CCC_DATA_7=F4ED2F6ADE8D4B840A8037C6D911C379283662E 4A62F47C26438441F4155DA3AF94AEA5B0ECC1425
CCC_DATA_8=5D8455C86655EE10FE2FE0C51815C635F6C4E8F E0B389619A95773BCB4ACA73BC6C856D982639927
CCC_DATA_9=9E9F5D921A8EA969066A9D0EC76BE541C7061AC E8AD426EDCE24D2ECDD0B56D8FFFFFFFFFFFFFFFF
HWC_DATA_1=4348574305004150010000007548E0941E2C614 70000000000000000000000000000000000000000
HWC_DATA_2=000000000000000005700108381D6E56A3FEE99 E2F06C4D9E47A6C71303535343630304300000000
HWC_DATA_3=000000004B80E4A2AD5EEDF3B7B3B8353823FE5 A10B354B375EA4ED817C28890783D73CF918E616B
HWC_DATA_4=33D5BFAF34A60D1A80AD3497F4623A15AE69BE5 875C7A703B6B1E133CCAB4C8286716A2C510A4B0D
HWC_DATA_5=69FA46D95B4828E458DA870E6C99E74617998D5 54E8502F22238F0F707C0F4FD029071028A91783A
HWC_DATA_6=A36CFEA3384480D17628C935FFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Old 06-12-2010, 16:29   #6 (permalink)
Member: 146708
Sonork: 100.108221
started Phone Security Analysis...
MCU Version	V 05.60
MCU Date	10-12-08
Product		RM-337
Manufacturer	(c) Nokia
IMEI		3548xxxxxxxxxxxxx47
Mastercode	4512176477
Reading Security Block...
Security block OK and saved to "RM-337_3548xxxxxxxxxxx9347_12.06.2010_182833.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
SIMLOCK SEFLTEST PASSED OK!
Step 2 : Testing SECURITY
-- SECURITY PROBLEM --
Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED!
To repair it, simply slick "SX4 Authorization / SD Repair" button.
After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically)
Additionaly, Checking HWC/CCC Certs...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006010C192101001101
CMT_EM_ASIC_ID:		00000232
CMT_EM_ASIC_ID:		00000353
CMT_PUBLIC_ID:		2C70010D71977D56C3B70E4171AA0CE390BDF037
CMT_ASIC_MODE_ID:	00
CMT_ROOT_KEY_HASH:	BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC:	191EC665
CMT_SECURE_ROM_CRC:	DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 7F791A8EC5CEF8D23B5C6789B94C6F2843253DA5
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
 !!!!! HWC IS CORRUPTED, ANOTHER REASON OF SECURITY TEST FAILED !!!!!
 !!!!! CCC IS CORRUPTED, ANOTHER REASON OF SECURITY TEST FAILED !!!!!
Restarting MCU...
Step 3 : Analyzing Security Block
"2C70010D71977D56C3B70E4171AA0CE390BDF037.C00011DE" Exists, That is good...
Checking SUPERDONGLE...
SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
Checking SIMLOCK...
SIMLOCK FOUND AND CHECKSUM OK! PASSED!
Checking MCU&DSP TIMESTAMPS...
MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
Checking CMLA KEYS...
CMLA KEYS FOUND AND CHECKSUM OK! PASSED!
Checking ECC KEYS...
ECC KEYS FOUND AND CHECKSUM OK! PASSED!
Checking DIV KEYS...
DIV KEYS FOUND AND CHECKSUM OK! PASSED!
Analyze finished!
Warning: At least one Certificate Test failed, but no Local Generic RPL File found, Put it in SX4 folder.
Old 06-12-2010, 16:31   #7 (permalink)
Member: 146708
Sonork: 100.108221
Skipping RPL decryption...
Parsing decrypted RPL...
Processing FBUS Part...
Processing FLASHBUS Part...
Failed to Write RPL File -> '$4 ' is not a valid integer value
Old 06-12-2010, 16:34   #8 (permalink)
Member: 146708
Sonork: 100.108221
Originally Posted by LoveLess View Post
hi supporters..
self test inf..
Passed ST_LCD_TEST
i really fixed it.. thanx cyclone team...
RPL..Create RPL From Phone.. then Plain RPL and Write stored rpl and bingo..
Selftests to proceed: 34
Passed		ST_LCD_TEST
Passed		ST_SECURITY_TEST
Passed		ST_BT_WAKEUP_TEST
Passed		ST_HOOKINT_TEST
Passed		ST_TAHVOINT_TEST
Passed		ST_BTEMP_TEST
Passed		ST_WLAN_TEST
Old 06-12-2010, 16:44   #9 (permalink)
Member: 146708
Sonork: 100.108221
Passed		ST_LCD_TEST
Passed		ST_WLAN_TEST
but there is a pb.. phone imei is 123456789-1.
Old 06-14-2010, 10:46   #10 (permalink)
Member: 146708
Sonork: 100.108221
supporters i am still waiting...
Old 06-14-2010, 10:49   #11 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: 100.1614583
restore NPC cerificate if u have backup
Old 06-14-2010, 11:38   #12 (permalink)
Member: 146708
Sonork: 100.108221
another service point flashed the phone as 6300 then now phone is contact service.. can u check my rpl exist or not..? it looks like exist..
[CODE]
PRODUCTCODE=0555967
PSN=KEV541594
HWID=1202
NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303535353936374300000000
NPC_DATA_2=00000000000000000000000093060297EB247D4 98B570000646F7242000000002C70010D71977D56
NPC_DATA_3=C3B70E4171AA0CE390BDF0377F791A8EC5CEF8D 23B5C6789B94C6F2843253DA5026EF7533EB8AC1B
NPC_DATA_4=D0DC0950B66BEE38C7AC30A9000000000000000 000000000000000000300000047534D0000000000
NPC_DATA_5=3345380012623974FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000
NPC_DATA_6=D6EF01AA2100000000000000000000000000000 0000000000000000000000000574C414E5F494400
NPC_DATA_7=163211AA2100000000000000000000000000000 000000000000000000000000006EE2C605111207F
NPC_DATA_8=6A634F62CB3BFC96C2BCB3F68D9266A3DC432CB 4214121ABD469859A13D5B60E494AFCE1AAE61720
NPC_DATA_9=43F6628936AAA353576E97B1CC20DBCA0618B3F 2E8EA8ABF533A2DB87549ED7C7E3ABA1211316BBE
NPC_DATA_10=AF41F73B59F5CE4A82CDC9C4873864F753DBE4 44EDDFC368E14FD34B74B9820D959AED2D7A5E6CBD
CCC_DATA_1=11D1F04DF0492C6808A8241F242233F0E0E94EC D04A84EC0FF230025280040330026EF2731000093
CCC_DATA_2=3B00002201AF07C73200290020001DF03AFA11B 0F0BDF0B5040095B020201A00009000206B460494
CCC_DATA_3=188300251877002A58771AD11220DB4A0229988 201D1B12000E090206B46D8821720E72101AB07C3
CCC_DATA_4=1227D34924220CA833F0A6E9CF4808AE0FC80FC 6D04810AB588101206B46987708A803AA0CA91EF0
CCC_DATA_5=E3FE14206B46185E029988424FDD502003F012F C6B4606009F8240E020886900A41C705220886D1C
CCC_DATA_6=2D042D14202801D00028F3D1690000207052142 56B465D5F0120987708A80CA903AA04961EF0BCFE
CCC_DATA_7=14206B46185E0299884206DDD98A01980A30081 8D8829F8201E06B469D8200206B46987708A803AA
CCC_DATA_8=0CA91EF0A5FE6B4619882088884209D16846049 00120987708A803AA0CA91EF097FEA41C00252088
CCC_DATA_9=0028BBD1300003F020FE15B0F0BD6B4600209F8 2987708A803AA0CA91EF084FEF3E7F3B595B01698
CCC_DATA_10=00281DD18A4838304189C48885880689079109 1BC91E0904090C0691711BC91E0904090C0591C068
CCC_DATA_11=8D490004000C049024220CA833F018E9884808 AF0FC80FC7711C601E621E6B1E1F00029200900191
CCC_DATA_12=00220CA908A81FF077F9079A691E521C601E3B 0000900292019100220CA908A81FF06AF9079A0798
CCC_DATA_13=711C3B00521C401C6F4607C700220CA908A81F F05DF9079A711C601E521C6F4607C7731C00220CA9
CCC_DATA_14=08A81FF051F9069810AB801C98736E48711E18 81601C621C6E4607C66B1C00220CA908A81FF040F9
CCC_DATA_15=1598002825D0069810AB987304981881169801 280BD115980A2808D8059815994843642134F086ED
CCC_DATA_16=4119891C07E0059815994843642134F07EED41 19491CA21CA01C6C4607C4AB1C00220CA908A81FF0
CCC_DATA_17=17F917B0F0BD4F48FF224B2110B50068C90232 F0E2EF10BDFFB51F00160001250400642881B002D9
CCC_DATA_18=002005B0F0BDFFF7EAFF029B33F086EA062104 09090909212006000E0021FFF74CFF002E05D00121
CCC_DATA_19=3000029A0023FFF7B2FE002F05D00221380002 9A0023FFF7AAFE0020FFF785FE002100201DF00CF9
CCC_DATA_20=00E000252800D4E725480A2138308180E52101 81CD21C180E42141810D21C1607047FEB52DA21268
CCC_DATA_21=002302922CA214CA00921B4A01943832967812 7800296ED11749294C103168E09D004D592D788542
CCC_DATA_22=60D198000858C6888588C768F02E5ED1FF2041 3085425AD1082A0CD0102A56D10620754320802800
CCC_DATA_23=42003900201D668032F076EF44E00422390020 0032F070EF201D3A1D0021754302AC6B46AC4635E0
CCC_DATA_24=D40C00D875615F666C617368696E675F68775F 636F6E74726F6C5F75695F6170692E6300C4090000
CCC_DATA_25=F80300D8C40800D8D40800D8202614F0FF0F00 0000050A0F00020406080A0C0F346804D8555CEF06
CCC_DATA_26=6E097F0FDF5D9E5DAD07AD0F655D3F0136023E 4335434E00491C85538C45EDD80120FEBD5B1C1B04
CCC_DATA_27=1B0CB34294D30020FEBD70B50E000500012464 2801D9002070BDFFF72CFFF9488078012805D10021
CCC_DATA_28=3000FFF76EFF040001D1FFF75DFF330033F0BC E906110409090909112806000E0021FFF782FE0020
CCC_DATA_29=FFF7CBFD002100201DF052F800E00024200070 BD10B5E84C200034F0E9FF02201CF0D6FF200034F0
CCC_DATA_30=E3FF10BD10B5002890B07BD1E149242207A832 F09AEFE04803AC0FC80FC400206B4698867B207B22
CCC_DATA_31=EB216B4607C30022022307A903A81EF0F7FFC3 2202217B206B4607C30022022307A903A81EF0ECFF
CCC_DATA_32=C322EB21C3206B4607C30022022307A903A81E F0E1FFC322EB217B206B4607C30022EB2307A903A8
CCC_DATA_33=1EF0D6FFC7486B4698867C207C22EA216B4607 C30022032307A903A81EF0C8FFC22203217C206B46
CCC_DATA_34=07C30022032307A903A81EF0BDFFC222EA21C2 206B4607C30022032307A903A81EF0B2FFC222EA21
CCC_DATA_35=7C206B4607C30022EA2307A903A81EF0A7FFB1 486B4698867D207D22E9216B4607C30022042307A9
CCC_DATA_36=03A81EF099FFC12204217D206B4607C3002200 E093E0042307A903A81EF08CFFC122E921C1206B46
CCC_DATA_37=07C30022042307A903A81EF081FFC122E9217D 206B4607C30022E92307A903A81EF076FF99486B46
CCC_DATA_38=98867E207E22E8216B4607C30022052307A903 A81EF068FFC02205217E206B4607C30022052307A9
CCC_DATA_39=03A81EF05DFFC022E821C0206B4607C3002205 2307A903A81EF052FFC022E8217E206B4607C30022
CCC_DATA_40=E82307A903A81EF047FF412008AB987681486B 4698867F207F22E7216B4607C30022062307A903A8
CCC_DATA_41=1EF036FF7848012408AB9C76FB306B4698867D 20C422EC216B4607C30022EC2307A903A81EF024FF
CCC_DATA_42=C422EC21C4206B4607C30022042307A903A81E F019FF6B4808AB9C76ED306B4698867F20C522ED21
CCC_DATA_43=6B4607C30022ED2307A903A81EF008FFC522ED 21C5206B4607C30022062307A903A81EF0FDFE10B0
CCC_DATA_44=10BD002A30B50DD0002303E05D005B1C521E44 53CC5C002C01D0002AF6D100215A00815230BDF1B5
CCC_DATA_45=88B0089A0020002A04900CD051480068102808 D350480899102232F0B6ED4E4A1078102802D90020
CCC_DATA_46=09B0F0BD97780A2F61D8002F5FD0908800280A D1D088002807D11089002804D15089002801D1FFF7
CCC_DATA_47=E7FD414AD068431C01D10D20D060089C103400 26A7E01C20FEF7D4FF3A4BB500283B38495851089A
CCC_DATA_48=0968511822001B32491E914237D31C22210032 F07EED324A507801283148405966D101000C318446
CCC_DATA_49=0EC901A80EC06B4618795979089A0002084399 79000409020843D97908438646187A597A00020843
CCC_DATA_50=997A000409020843D97A204B084305901B6860 46806821000B31D218521E4118914204D805990C31
CCC_DATA_51=8842079103D00F490020887093E77046FEF788 FF04900798FEF784FF2100079A0C31009032F038ED
CCC_DATA_52=009804991FF032F900281DD00098FEF794FF04 98FEF791FFE1E70000F80300D880A90300D40800D8
CCC_DATA_53=C40800D8FF0F00009E080000DF0B0000EF0D00 00000600D80C0D00D8E40C00D80098FEF776FF10E0
CCC_DATA_54=8188C08848431178C90848430690FEF74DFF04 902348069A415904A80C3132F0B4ED204B04985959
CCC_DATA_55=761CBE42C8600CD258590C34806804190020A1 0705D0401C0006000E641C0328F7D33606360EBE42
CCC_DATA_56=00D254E714490120887031E73221642810B500 D9080000F09FFA10BD70B500F08DFA0D4D04006878
CCC_DATA_57=0F2804D3002C02D10020FFF7EBFF2878002804 D1012C02D16420FFF7E3FF2C7068780F2801D2401C
CCC_DATA_58=687070BDE40C00D8F80300D8F449F548016000 218180D5218160F3A1C160704710B59AB0FFF74CFB
CCC_DATA_59=FFF756FB6420FFF7C5FFF74C2069FFF7DEFE01 2804D10521FFF777FD00280AD1F249642201A832F0
CCC_DATA_60=4CED05210120002301AAFFF7A9FC012020711A B010BD70B5E94E00243300F57899781A78E4435B78
CCC_DATA_61=002D0AD13500012A01D0012B05D1452024F03D F90120E87005E0012905D1012A01D0012B01D12000
CCC_DATA_62=70BD23F034FA70BDF8B59446D84A00241600D7 78B3783578E4437678002F0BD1012D01D0012E07D1
CCC_DATA_63=15001900452024F01AF90120E87005E0012B05 D1012D01D0012E01D12000F8BD624623F014FAF8BD
CCC_DATA_64=70B5C74D0400E8780E0088B000280BD1287801 2802D06878012805D1A978452024F0F9F80120E870
CCC_DATA_65=A878012809D12878012802D06878012803D100 20C04308B070BD80220021200023F0DEF90400431C
CCC_DATA_66=01D12000F3E7287901280CD1A878002809D128 78012802D06878012803D1FFF715FD002028712000
CCC_DATA_67=01A923F046FA431CE8D00298002809D19A49C3 2080008880FF219848C13198A2FDF75AFD02983060
CCC_DATA_68=D7E7FEB50020461E002502909C4F02A9B868FF F7A5FF431C019022D00298FEF72DFE994907000860
CCC_DATA_69=02999848002401609648391902680198FFF76E FF0600431C0BD00298A419844203D10198FFF743FF
CCC_DATA_70=012502988442EBD306E08B490868FEF72CFE8B 4834F0B8FC8A4C20684068431C15D0834F78790028
CCC_DATA_71=11D1002D0FD1387801280CD1B878002809D172 49C3208000888001006F4826396FA2FDF709FD784F
CCC_DATA_72=387928430BD13878012808D17879012803D020 684068431C01D0FFF7E9FE002D09D13878012806D1
CCC_DATA_73=787901289ED020684068431C9AD1731C01D100 20FEBD0120FEBDFEB50026664F00250296F86802A9
CCC_DATA_74=FFF736FF019002986749086001994B1C19D0FE F7BBFD060000240198029A3119FFF702FF431C0BD0
CCC_DATA_75=24180298844203D10198FFF7D8FE0125029884 42EDD305E03000FEF7C2FD564834F04EFC554C2068
CCC_DATA_76=4068431C14D07879002811D1002D0FD1787801 280CD1B878002809D13D49C3208000888001003B48
CCC_DATA_77=82393BA2FDF7A0FC387928430BD17878012808 D17879012803D020684068431C01D0FFF781FE002D
CCC_DATA_78=09D17878012806D178790128A6D02068406843 1CA2D13000FEBD35490022CA7088707047F0B50024
CCC_DATA_79=87B023F0C3FF254E012806D13548FE21B08030 0022A2FDF76FFC33480068058AFF20401D854208D9
CCC_DATA_80=2E48FF21401CB0801A4809311AA2FDF75FFC6F 003800FEF741FD21493A00886027490968123132F0
CCC_DATA_81=F4EA00E0641CAC42FCDB234908683D1812352C 88FF20401D844208D91D48FF21401CB08009482431
CCC_DATA_82=09A2FDF73DFCAF1C65002800FEF71EFD0F492A 00C860390032F0D2EA00202AE006000020280D00D8
CCC_DATA_83=75615F666C617368696E675F68775F636F6E74 726F6C5F66696C657379735F6170692E6300000000
CCC_DATA_84=FC0300D868F913F0D00500D8CC0500D820A107 00880300D8000600D80D030000840300D8401CA042
CCC_DATA_85=FCDB1E4C0125E0680088452801D0652800D165 70A0680088452801D0652810D11748257009210390
CCC_DATA_86=02206A4627F019FD00984004800F032801D1A5 7001E00020A070FFF7FAFEC327BF000028206106D1
CCC_DATA_87=FF210C4A0C486431B780FDF7D5FBFFF77CFE00 2806D1FF21064A07486D31B780FDF7CAFBE57007B0
CCC_DATA_88=F0BD0000FC0300D8233C10F0D03C10F0280D00 D810B50D48002109F0BBF80C48FF2109F0B7F80948
CCC_DATA_89=0021C01C09F0B2F806480021C01D09F0ADF810 BD10B5054809F000F80006000E10BD000001000800
CCC_DATA_90=FF00040000101600FEB50400642800D9642401 A805F073FD6B46187A2E4D7F260B28687012D00D28
CCC_DATA_91=00D12E706868052802D268780D2814D1287821 0200024843642132F000EC0002040E15E0F02009F0
CCC_DATA_92=B9F80528686001D32E70EDE70F202870E7E725 206043642133F088EF1B490006000E085C0407240F
CCC_DATA_93=68782900184D0B2811D00D281AD1174E3700F0 1FF838803F002C14D0012109F055F80121380009F0
CCC_DATA_94=51F8012113E04868052802D32100280002E00B 482100703809F044F8FEBD002109F040F800213800
CCC_DATA_95=09F03CF80021300009F038F8EAE70000100400 D8CCF913F07F0005000001090010B5002006F0B4F9
CCC_DATA_96=26A00CF0FBFA00F08AFE002010BD10B527A00C F0F3FA2A4801682AA00CF050FB07F031FC2CA00CF0
CCC_DATA_97=4BFB0CF06DFB35A00CF046FBFEF72AFF012001 F0CFF938A00CF0DCFA0A2034F097FAFBE770B51925
CCC_DATA_98=6D0102F0AEF80400B12809D133A00CF0CDFA02 21072001F0B7FAFCF7D5FAF0E7C72C07D132A00CF0
CCC_DATA_99=C1FA2900072001F0ABFAE6E732A00CF0B9FA20 0002F011FFDFE7012070477047012070476F735F69
CCC_DATA_100=6E697428292063616C6C6564000000006D746 35F69646C655F7461736B0000000004D4FF4D435553
CCC_DATA_101=5320726561736F6E203078253038580068775 F7072655F737461727475705F726561736F6E5F6368
CCC_DATA_102=65636B202D3E20436F6D706C6574656400000 0006E6D7072746C69625F696E6974202D3E20436F6D
CCC_DATA_103=706C65746564000049444C45204C4F4F50000 0007461736B5F313A20737461727465642100000000
CCC_DATA_104=7461736B5F313A2074696D657200000074617 36B5F313A20556E6B6E6F776E206D65737361676520
CCC_DATA_105=72656365697665642E000000254810B50268E F2024A105F00EFF264AEB2080001063FF21EE311000
CCC_DATA_106=4030816122492348016123490162002101632 24B0364224B0365FF235B1C0366204B036720480161
CCC_DATA_107=1A4B803319630124640418004030046001611 C4C04620924E40304631C0080342160194921611949
CCC_DATA_108=2162194921631949196106214161082090630 12006F06FFA01218120400308F041FE07F040FB10BD
CCC_DATA_109=2F207047802DD3FF414343504C4C202578000 000802CD3FF00808ACA001CD3FF55558252000040A1
CCC_DATA_110=2015050055551500401ED3FF41000002FFFF0 0FDFFFFFBFFDF030000C0F4000010B500F083FC0022
CCC_DATA_111=9049062009F01CFF00228F49052009F017FF3 4F07DF808F029FD00F083F98B480021416100698A49
CCC_DATA_112=486000F07FF900F06AFA10BD10B5864C20780 12804D12C2008F0A0FD0020207010BD70B502F084FB
CCC_DATA_113=040011D07E4D7F49EC60886E0028FCD18C622 C2008F087FD7B480460E96801807A492D20087070BD
CCC_DATA_114=FFF7DCFF70BD7849012010B5087072490020C 86075492C2008F038FD10BD10B573497448AA2232F0
CCC_DATA_115=44E873496A4C1120A16034F05BF8A06801218 90241181220216134F053F86B492069216110BD624A
CCC_DATA_116=80081169800040181061704710B50268002A1 9D05C4C00212378012B0CD15B4B996E0029FCD1996A
CCC_DATA_117=E468641A131B9342036001D900230360554B1 9601A600068186054492C20087010BD584808B50068
CCC_DATA_118=431C09D0806800906846FFF7D7FF0098F5280 1D2002008BD012008BD70477047704770B5040000D1
CCC_DATA_119=0124434D434EEC602878002809D1B06E0028F CD1B4622C2008F00DFD0120287009E02C2008F00EFD
CCC_DATA_120=B06E0028FCD1B4622C2008F000FD384804600 021018037492D20087070BD70473048002310B54361
CCC_DATA_121=00692F4C6168884202D2421A521E00E0421A6 060A069E16980185941A061E16110BD10B500F0B6F8
CCC_DATA_122=FFF7E6FF2448C16980693AF08AEE2C493AF0D 0EE0E21C9433BF048E929493AF0CAEE3AF034EE0400
CCC_DATA_123=00F027FD1C4908800C601C497E20087000F09 CF8200010BD10B500F093F8FFF7C3FF1348C1698069
CCC_DATA_124=3AF066EE1A493AF0AEEE0E21C9433BF026E91 9493AF0A6EE16493AF0A4EE3AF00EEE040000F001FD
CCC_DATA_125=094908800C6009495F20087000F076F820001 0BD600D00FE807D13F08004D4FF300400D80001D4FF
CCC_DATA_126=0010B0FF0008B0FF6C0400D87B4110F0908D0 000180407D8A88D07D89C0400D8002474496F12833A
CCC_DATA_127=CDCC4C3E001F0160E749001F0160002100220 01F491C08290260FADB7047032801D1E24802E00428
CCC_DATA_128=02D1E148006802E0E04980000858E04A00210 1E0001D491C03689342FAD088007047032809D22421
CCC_DATA_129=4143DA4A80008918D64A89681058081A70470 0207047032806D2D5490C2358430968401840687047
CCC_DATA_130=032802D1012080027047042802D1FF2091307 04700207047032805D224235843C849401880687047
CCC_DATA_131=0020704710B508F0E9FB10BD10B508F0E1FB1 0BDFEB533F003FFC506C1480121C902461849004418
CCC_DATA_132=ED0E0027122D15D108F0D4FBB81E208027709 92020702560276027601020307008F0C4FB00220092
CCC_DATA_133=019299222B000021FE2017E003F072FC00281 7D108F0BAFB27802770992020702760276027601020
CCC_DATA_134=307008F0ABFB0022009201929922002100200 02305F01DF931F082FE08F0BEFBFEBDFEB533F0C0FE
CCC_DATA_135=C506A0480121C902461849004418ED0E00271 22D15D108F091FBB81E208027709920207025602760
CCC_DATA_136=27601020307008F081FB00220092019299222 B000021FE2017E003F02FFC002817D108F077FB2780
CCC_DATA_137=2770992020702760276027601020307008F06 8FB002200920192992200210020002305F0DAF831F0
CCC_DATA_138=3FFE08F07FFBFEBDF8B5060001AD002400950 0980068001F06F05DF8002825D00098006840084000
CCC_DATA_139=001F0188CA0A1E2A1CD14288D30A1F2B18D18 B055205520DDB0A9A185200490501D571490A438118
CCC_DATA_140=091D4A080020520004E0490849008A422AD04 01C810071580029F6D10098641C001D1E2C0090CCDB
CCC_DATA_141=FF260095654D1D360024771C00980068801E0 6F024F8002814D000985F4A0068403A40084000801E
CCC_DATA_142=018888098001904206D0A84204D08809B0420 1D0B84201D10098F8BD0098641C001D1E2C0090DDDB
CCC_DATA_143=0020C043F8BDF0B5524F514D00214FE000224 008400003885B0A5A2B12D106883206120E002305E0
CCC_DATA_144=D40702D05B1C1B041B0C5208002AF7D1F205D 20FD2184B00EA5203E0521C801C1E2AE4DB0022FF23
CCC_DATA_145=62330488E4099C4207D100884A00AB5A40064 00E1818A85203E0521C801C1E2AEFDB002915D13868
CCC_DATA_146=0022400840000388DB0A152B07D100884A00A B5A0007000F181AA85203E0521C801C1E2AEFDB0029
CCC_DATA_147=05D048002A5A2B88D218521E2A52491C88003 8580028ABD1F0BDF7B5900082B001AA841820680027
CCC_DATA_148=401F01C10E00012024E00025241D2068001F0 5F098FF00280DD0206840084000001F0188C90A1E29
CCC_DATA_149=05D14088C00A1F2801D1012709E06D1C241D1 E2DE7DB002F03D1781E306005B0F0BD2068401F01C6
CCC_DATA_150=0198401C029901908842D6D3F3E70000897F1 3F0F8F913F0F4F913F0FCF913F0AAAAAAAAF41300D8
CCC_DATA_151=980400D80000B0FF0100C0FFC746000018100 0D814FA13F0F7B5002082B0019002980D0081001400
CCC_DATA_152=280031F050EE2000FFF7E6FE0400431C02D15 81E2860C6E72068401F01C52E00012724E00025241D
CCC_DATA_153=2068001F05F03BFF00280ED02068400840000 01F0188C90A1E2906D14088C00A1F2802D101200190
CCC_DATA_154=09E06D1C241D1E2DE6DB0198002802D1401E3 0609FE72068401F7F1C01C602988742D7D397E71CB5
CCC_DATA_155=08F00CFA00F0A5FA454908801C2008709C200 8700024E4430C600C600C6041491020087008F0F6F9
CCC_DATA_156=00F093FA9C221C2123000094019404F068FF3 1F0CDFC7CB50D000400160008F0E9F9354804800570
CCC_DATA_157=0670002101600160016032491120087008F0D 8F900222006009201923200000E2900002304F053FF
CCC_DATA_158=7CBD7CB50D000400160008F0CBF9264804800 5700670002101600160016023491020087008F0BAF9
CCC_DATA_159=00222006009201923200000E2900002304F02 BFF7CBD10B5FFF72EFD10BD10B5FF2403F05FFA0028
CCC_DATA_160=01D1FF2010BD1649164A00200B681B8893420 1D0040005E0401C0006000E091D0328F3D3FF2C15D1
CCC_DATA_161=0F4800680088904201D003240EE00D4800680 088904201D0042407E00A480078002802D109480478
CCC_DATA_162=00E0FE24200010BD0010B0FF0008B0FFFCF91 3F0AAAA0000F8F913F0F4F913F05C0400D86B0400D8
CCC_DATA_163=70B533F08DFCC006C00E122804D1434C20896 189884201D131F03EFC404D00266089C00029586089
CCC_DATA_164=C0004019007900F038FF6089401C0004000C6 081212800D1668108F0E3F820896189884202D008F0
CCC_DATA_165=D9F8E5E70120800308F0ABF808F0D2F870BDF 8B533F05CFCC006C00E122804D12C4CA08AE18A8842
CCC_DATA_166=01D131F00DFC274D0C35E08A1423584340190 369E08A1F00142358434019C268E08A584340198168
CCC_DATA_167=E08A584340194068E68A7343EE583B00B047E 08A401C0004000CE082212801D10020E08208F0A2F8
CCC_DATA_168=A08AE18A884202D008F098F8D5E70120C0030 8F06AF808F091F8F8BD10B51049212008F0FBF80F49
CCC_DATA_169=202008F0F7F8202008F02DF9212008F02AF91 0BD0A4A1268104738B51400049A00922200064C6468
CCC_DATA_170=A04738BD2C1100D82C1000D8B81300D8B3491 0F0514910F0600400D8F1B582B033F0F2FBC506FE48
CCC_DATA_171=0121C902461849004418ED0E0027122D15D1F FF7D7FCB81E20802770992020702560276027601020
CCC_DATA_172=3070FFF7CFFC00220092019299222B000021F E2017E0EF490878002817D1FFF7BDFC278027709920
CCC_DATA_173=207027602760276010203070FFF7B6FC00220 0920192992200210020002304F00CFE31F071FB1520
CCC_DATA_174=30700298E04A086300211400543C1C234B430 025ED431B191D605D609D601F745F741F765F76457A
CCC_DATA_175=012D04D9DA60457AAD00AA1800E0DF60857A0 12D04D95A61857AAD00AA1800E05F61C57A002D09D0
CCC_DATA_176=DE68B125756001251D74CA4D0A356B5C5B1C6 B54491C0906090E0C300329CED3FEBDF8B5C54A1921
CCC_DATA_177=00921170C44F0600002524206843C34944180 020411E61600521206061733D803970009A57211170
CCC_DATA_178=A573E0736061A061E06120627068FFF71EFBA 060307A20733168A068FFF7F6FB6D1C2D062D0E0C36
CCC_DATA_179=032DA060D9D3B149012040314875022139803 870009A57211170A849801E486288623000F8BDF0B5
CCC_DATA_180=89B004F0CAFDA34F01223A70FFF72EFCA24D1 6202870A5480026BE7006700120A14C8002FFF7D3FA
CCC_DATA_181=F8622000FFF7A9FF2000FFF72BFF1A2129700 40000200122411E1823974F43436C37DB1919605960
CCC_DATA_182=9E609A7498826778401C00041F74277808340 00C09285F74EBD38A4F0021C9437963FFF7A0FA3879
CCC_DATA_183=002801D0FFF776FA200003F031FC040003F0D EFC8548243806604660866018202870854A0020FF21
CCC_DATA_184=461EC3009B181E602578401C00065D716578A 41C000E1D7118289971F1D3FFF737FA02206B467749
CCC_DATA_185=9873F870503102A833F032F909B0F0BDFEB56 D4B01240D00AA7BE4021E1964001C190021032A8446
CCC_DATA_186=96461BD3FFF7B2FB664FF87820801E2020708 C202070A87B206000202060206010203070FFF7A6FB
CCC_DATA_187=0022009201928C22AB7BF8781E2104F0FCFCF EBD0022D24328606A602F7B07E0137BBB4202D90268
CCC_DATA_188=6A6004E0101D491C0268531CF4D1724622805 04F01222437BC4500D00222227021701E2131700560
CCC_DATA_189=FEBD4A490878002801D1FF2070474D4800780 02801D1C8787047FE20704730B5454C208018224549
CCC_DATA_190=42436C3151180A7C2280404C262323701C235 A433C4B543BD218083210E0A38A83420CD113680120
CCC_DATA_191=98741368002098601068406810600020C0434 86030BD221D1468631CEBD130BDF0B50600002785B0
CCC_DATA_192=039733F049FAC006C00E112801D131F0FFF92 7480121C90241180491012109034518092E1DD3FFF7
CCC_DATA_193=29FB224CE07828802B2028708C2028702E600 02028602860049910200870FFF71DFB002200920192
CCC_DATA_194=8C223300E0782B2104F073FC002005B0F0BDF FF70BFB182016497043114A6C314418107900280AD0
CCC_DATA_195=506B431C07D00830FFF7D4F90B4A506B8068F FF702FAA07C01281FD002281FD003284FD1607CC007
CCC_DATA_196=02D03000FFF77FFF607C400743D411E00000B 0FF680400D8C41600D80008B0FF0010B0FFF41300D8
CCC_DATA_197=3CFA13F05C0400D8B01500D8A7684FE0FB490 A00343A506B431C04D0808AB04201D1012003900027
CCC_DATA_198=0FE08368DF19838AB34209D108680068431C0 86008D08168A368C918816003E001000868431CECD1
CCC_DATA_199=0020A060039801282AD1506B431C03D08068F FF7B2F923E0FFF72CF920E00220A074A8E7FFF79EFA
CCC_DATA_200=FFF723FF28802B202870892028702E60A07C2 86000202860049910200870FFF791FAFFF712FFA17C
CCC_DATA_201=002201928922330000912B2104F0E5FB0120A 074801E206038003AF09CE8D1493AF09CE8D0493AF0
CCC_DATA_202=9AE83F21090639F022EE3AF000E80400FFF7F 3FE28802E802C6004992B200870C54A343A10790028
CCC_DATA_203=04D0506B431C01D1FFF7E4F8FFF75EFA20004 8E7FEB5FFF75DFABD4A0020343A9070D1782420BD4B
CCC_DATA_204=4843C518506ABC4A0123DB02D7185B00D4184 31C79D06B7B31F0F8EB079F4F2D050505059F00B04E
CCC_DATA_205=B249343E4831884204D1B06A431C01D003F0C 6FA3100766A7068486200203060
HWC_DATA_1=0818012192E710B504003048FFF7CEFF8021E14 0014201D0012010BD002010BD38B52A48FFF7C2FF
HWC_DATA_2=04002948FFF7BEFF84430020802200900098110 0C14021420FD00B210120EE236A46FCF74DFE0098
HWC_DATA_3=810020484058002801D129F0C5F8804703E0401 C08280090E6DB1B480121C902016238BD70B50400
HWC_DATA_4=0D00FFF7D7FD17480178012918D100210170154 91048FFF74DFF192040012BF0DBF91249D920FFF7
HWC_DATA_5=C9FD0D4801214160C9024163C16201620161D92 0FFF7F7FD0649A0000C580D50FFF7B0FD200070BD
HWC_DATA_6=080814F0FF000100FF0003005C2000D8C01DD3F F2D0500D8FFFF000021D010F00200244810B505D0
HWC_DATA_7=012A05D0022A08D0002010BD022200E00122012 909D1826008E0042201241C4B012901D15C60F6E7
HWC_DATA_8=9C60C260012010BD70B50400080016001D0003F 024F88008C10100221000002D00D0782008430021
HWC_DATA_9=C943B61EB1400901002D00D00F2211434A000B4 90B68DB07DB0F18430860094802600122022C01D1
HWC_DATA_10=826070BD42600420002C01D1886070BD486070 BD0000D5FF002ED4FF802ED4FF10B5FFF74FFDFF21
HWC_DATA_11=87488D3129F052E98648152129F04EE9854900 20086048608860C8608349C8600A004032D0601300
HWC_DATA_12=4033D8601C004034E060012048605060586060 60FFF72AFD012010BD30B4784C0021002914D00129
HWC_DATA_13=16D0022919D0032927D1744BE268C0334A20DD 682A40DA60DA6BDD60531C1AD0202A0FD328F0F0FF
HWC_DATA_14=6C4B22680020F0E76A4B626840332020EBE768 4BA26880334020E6E76249801880000A58002A04D0
HWC_DATA_15=085830BC0047491CCFE730BC7047F3B5040063 2881B010D2FFF7F0FC5849A500485900905A485B49
HWC_DATA_16=40590027BA008A58824204D07F1C152FF8D328 F0BDFF5149C95D0126002904D15349FFF7DBFC4D49
HWC_DATA_17=CE554B49029848514B484A2C05D34A3CC168A6 403143C16013E0402C05D3403C8168A64031438160
HWC_DATA_18=0BE0202C05D3203C4168A6403143416003E001 68A640314301603F484059FFF7EEFCFFF7ABFC0098
HWC_DATA_19=FEBD01224A2804D3384BC0334A380B6005E040 2806D3354B803340380B6082404A607047354B2028
HWC_DATA_20=04D3FF33813320380B60F4E7FF3341330B60F0 E77CB50D000400632825D2FFF789FC20006946FFF7
HWC_DATA_21=D8FF002D0CD0012D0ED0022D10D0032D17D101 980099C8620198009948630DE0019800998862F7E7
HWC_DATA_22=01980099886202E001980099C8620198009988 63FFF762FC7CBD28F041FF63281CB501D328F03CFF
HWC_DATA_23=6946FFF7AEFF0198009908621CBD63281CB501 D328F030FF6946FFF7A2FF0198009908611CBD6328
HWC_DATA_24=1CB501D328F024FF6946FFF796FF0198009948 611CBD00007C2000D8082200D8300500D8401DD3FF
HWC_DATA_25=400814F0CC0914F0D5D110F0001CD3FF704701 000822F648002901D042637047826370470100F248
HWC_DATA_26=40224030002901D042617047826170470100ED 4880224030002901D042617047826170470100E848
HWC_DATA_27=FF22521C4030002901D0426170478261704701 00E24804224030002901D042617047826170470100
HWC_DATA_28=DD4808224030002901D0426170478261704701 00D84820224030002901D042617047826170470100
HWC_DATA_29=D34801224030002901D0426170478261704701 00C022CE48002901D04260704782607047CB498A78
HWC_DATA_30=012A01D100228A70487008787047C84A002104 E0491C042901D128F0A1FE8B00D358002BF6D18900
HWC_DATA_31=505001207047C04A002104E0491C042901D128 F091FE8B00D3588342F6D100208900505001207047
HWC_DATA_32=042808DAB64A9032431C0AD1002004E0401C04 2801D128F07BFE8300D358002BF6D18300D1507047
HWC_DATA_33=AB4910B580390A00FF31491C8032002807D001 2803D0022801D0032807D000200FE0086A12680123
HWC_DATA_34=1B031A4005E0A348006812685204D217521C00 2A01D0A04A00E0A04A496A0905C90E4B0141060005
HWC_DATA_35=C00E890F491C184350432AF004EC10BD10B500 F03DF9012806D2924AD21C115C002902D0491E1154
HWC_DATA_36=10BD28F035FE10B500F02EF901280AD28A4AD2 1C115C491C0906090EFF29115401D328F025FE10BD
HWC_DATA_37=10B50C0000F01CF9012810D242018248002110 30101804E0491C082901D128F013FE8A008258002A
HWC_DATA_38=F6D189004450002010BD10B50C0000F003F901 2811D24201754800211030101804E0491C082901D1
HWC_DATA_39=28F0FAFD8A008258A242F6D100228900425000 2010BD10B50C0000F0E9F8012810D2420168480021
HWC_DATA_40=3030101804E0491C082901D128F0E0FD8A0082 58002AF6D189004450002010BD10B50C0000F0D0F8
HWC_DATA_41=012811D242015C4800213030101804E0491C08 2901D128F0C7FD8A008258A242F6D1002289004250
HWC_DATA_42=002010BD0206130D514A002050329A1804E040 1C042801D128F0B2FD8300D358002BF6D180001150
HWC_DATA_43=002070470206130D474A002050329A1804E040 1C042801D128F09EFD8300D3588B42F6D100218000
HWC_DATA_44=115000207047002A10B501D001209047002010 BDF7B53E490500430018184218567894780F5CFFF7
HWC_DATA_45=A5FA3548019A2E38022A05D1415DFF2941D249 1C415535E0019A2E49002A24D1425D002A06D0521E
HWC_DATA_46=4255B00702D54868401E486028493839085D00 282BD0401E244A0006000E08320855D15D491E0028
HWC_DATA_47=D15505D12449A000283909580020884770072A D5FEF742FC27E0019A012A09D1425D002A06D0521E
HWC_DATA_48=4255B00702D54868401E4860700701D5FEF753 FC124D383D285DFF2801D328F037FD002805D11249
HWC_DATA_49=A0002839095801208847285D094A401C083228 55D05D401CD055FFF743FA0299002902D002990120
HWC_DATA_50=88470020FEBD0000802CD3FF400500D8582200 D8802DD3FF00F0490200F82401480A14F0074B0521
HWC_DATA_51=5A5C0800002A02D1491E0129F8DA70470100FF 20002900D100207047480500D870B504000D0030F0
HWC_DATA_52=29F8C0070CD00A4862190CE0A14202D84368A3 4204D88A4204D341688A4201D2012070BD08300168
HWC_DATA_53=0029EFD1002070BDCC0A14F00B4A002803D011 688907890F016010680002000F704710B5054C2268
HWC_DATA_54=054B0007000A89071A401043890F0843206010 BD0004D4FFFCFF0FFFF0B505000C005B4985B04868
HWC_DATA_55=029001204860594802F07DFC5749081A049003 A802F077FC03A9081A03902AF0EFFC01902AF0DEFC
HWC_DATA_56=30F084F8049803992FF0AEFF01264E4FF60300 901AE0EC22290030002DF0ABFCA41B4A48AD190026
HWC_DATA_57=46602EF0A5FB7E6139694748474B7E61464A52 42521EFDD13A69521A832A01D8C018F4D10126F603
HWC_DATA_58=B442E0DCEC22290020002DF08CFC0498039900 9A2FF060FF3549029848600198400601D42AF070FC
HWC_DATA_59=0198000601D42AF07FFC05B0F0BD7FB5EC2033 A1FCF7A7FA2DF0E7FC002850D0E220EC2333A236A1
HWC_DATA_60=FCF79DFA012189034803FFF78FFFEC22E22034 A1FCF793FAE220EC2334A22EA1FCF78DFA00210420
HWC_DATA_61=2DF0A0FD002804D081680A0301D1C06802E001 2109060801FFF774FFEC22E22026A1FCF778FAE220
HWC_DATA_62=EC232AA220A1FCF772FA28A1684628F09FFD00 2413E0200030306B465873E220EC236A4618A1FCF7
HWC_DATA_63=62FAE868A968FFF755FFEC22E22017A1FCF759 FA641C210000202DF06BFD0500E5D17FBD70477047
HWC_DATA_64=8004D4FF65D810F0800404200005042020A107 00F0D8FFFF436F72652064756D7020666F6C6C6F77
HWC_DATA_65=73000000636F72652E706472616D00002A4F50 454E202573202564002A434C4F5345202564000000
HWC_DATA_66=636F72652E736472616D0000636F72652E6E6F 72666C61736830000010B5040008D000222D482100
HWC_DATA_67=02F0D7F92B4821002FF0BEFE10BD002210B529 49022000F083FA00222749032000F07EFA00222649
HWC_DATA_68=012000F079FA00222449002000F074FA002105 202DF00AFD8468002105202DF005FD0022C0682100
HWC_DATA_69=02F0AFF900F0BCFA1B48FFF7CBFF2FF047FF2F F06FFFF6F70BFA002010BD002210B50D212DF0CFFC
HWC_DATA_70=002808D08068810401D4000504D51149114828 F0B0EC10BD0020FFF7A3FE0E2804D00020FFF79EFE
HWC_DATA_71=0B2804D100210020FFF7A3FEEBE7F9F7EBFF10 BD000000FE2CE110F0F0E010F030E210F0A4E110F0
HWC_DATA_72=080E00007C030000000000D870B5040002F025 FB0500084802F021FB2A00072100232DF0A4EA0128
HWC_DATA_73=01D0002070BD3D200001201870BD0000040B14 F0F3B5060081B002988100AC480C1800946068431C
HWC_DATA_74=28D0009C029801273F030025241D87401DE001 007940B14217D1002D04D001220421200002F039F9
HWC_DATA_75=2068002D0068206004D000220421200002F02F F902993000B843491CFFF7D2FFFEBD04006D1C2068
HWC_DATA_76=431CDED101220421300002F01EF9009C002260 6804213060300002F016F9009C6660FEBDFEB58C49
HWC_DATA_77=04000C39FF2008700B1D00200025ED43002101 2758603F031D600CE0A258C61BB24207D81E68B242
HWC_DATA_78=00D21A605A68904200D95860491CCA00101940 680028EDD17B485C2128F00AEC002001000CE0E358
HWC_DATA_79=0022F31A00E0521C3E009640B342FAD8914200 D21100401CC3001A195668002EEDD1481C6E49421E
HWC_DATA_80=0A6002E0820052185560401EFAD2002624E060 59010519D00105090D791A401813E0012100E0491C
HWC_DATA_81=3A008A40531E184202D182186245F6D9491E01 91FFF75EFF01993A0060598A408018605102984168
HWC_DATA_82=60598C46091AB942E3D2761CF5002819029040 680028D4D1FEBD5449F8B5884216D2002401273F03
HWC_DATA_83=00E0641C3900A1408142FAD34C4E2500316800 E0641CA20092195268531C01D1A142F7D2A14206D2
HWC_DATA_84=0200EF2046A1FCF7BAF80020F8BDA000801946 683168416007E0601E390081408819611EFFF71AFF
HWC_DATA_85=641EA542F5D13C00AC4021000122300002F067 F8BC4200D2270039005522300028F08AEA3000F8BD
HWC_DATA_86=F8B5040031480D0081420AD22E4808380168A1 4205D840686219824201D2200503D02B00220033A1
HWC_DATA_87=2CE0274801260C3800783603244FC00700282D D038680021844627E08800C019406820E0844204D3
HWC_DATA_88=33008B401B18A34211D8824204D933008B401B 189A420AD3A04201D3824206D833008B401B18A342
HWC_DATA_89=08D9934206D229492B002200EF20FCF752F8F8 BD0068431CDCD1491C8C45D5D800222900200002F0
HWC_DATA_90=0CF8002100E0491C30008840A842FAD3386888 42E9D32000FFF7A8FEF8BD02490C39087070470000
HWC_DATA_91=980200D8FFFFFF7F5741524E494E473A206B65 726E656C5F616C6C6F636174652825752920666169
HWC_DATA_92=6C6564005741524E494E473A206B65726E656C 5F6465616C6C6F636174652830782530386C582C20
HWC_DATA_93=257529206661696C65640000140B14F07CB52A F0FDF90500EF206FA1FBF7FBFFEF206EA1FBF7F7FF
HWC_DATA_94=01AC221D6E49EF20FBF7F1FF0420019001986C A12258EF20FBF7E9FF0198001D84280190F4D300F0
HWC_DATA_95=C1F9019000F0C4F904002A000090019BEF2064 A1FBF7D7FF2200EF206CA1FBF7D2FF002001900198
HWC_DATA_96=8000001902F04BF9431C04D0019859A1800022 5803E0019872A180000219EF20FBF7BDFF0198001D
HWC_DATA_97=80280190E7D3E806C00E172803D01B2805D10E 2000E02220FDF70CFB7CBD0120FAE770B50124A402
HWC_DATA_98=2000FFF7CAFE6A4D01002200280002F0D4F93C 226749280028F046EA3C2128002FF048FC00222100
HWC_DATA_99=280001F056FF3C4D0024603DE0004119496828 5C2AF096F9641C052CF6D370BDF7B50400072801D2
HWC_DATA_100=042C01D128F034F90122554E9502290030000 1F03AFFA100A801081A0199076A01623C2130002FF0
HWC_DATA_101=1DFC00222900300001F02BFF0298002810D02 54900203839C2008A58A24206D1C000401840680299
HWC_DATA_102=2AF064F902E0401C0728F1D33800FEBD70B54 149FF2500202D0682005219401C07281160F9D33D49
HWC_DATA_103=03E082005219401C11600E28F9D3124E00246 03EE00081194968305C2AF042F9641C052CF6D33C21
HWC_DATA_104=28002FF0DFFB70BD314901200870704710B50 1F0DEFB2E490020087010BD00000000000045786365
HWC_DATA_105=7074696F6E000000BC0B14F03078253038580 000435053523A2030782530385820535053523A2030
HWC_DATA_106=78253038582053505F6D6F64653A203078253 03858000000496E746572727570746564206D6F6465
HWC_DATA_107=20737461636B2064756D702066726F6D20616 4647265737320307825303858206F6E20666F6C6C6F
HWC_DATA_108=777300007472616E736C6174696F6E2066617 56C7420402030782530385800000000FFFFD4E110F0
HWC_DATA_109=18F09FE510E210F0F40200D800000000FF5F2 DE91D0000EB10D04DE20D00A0E10A0500FA0211A0E3
HWC_DATA_110=010050E11500000A0060A0E110D08DE234109 DE5061081E034108DE5FF5FBDE808F05EE2FF5F2DE9
HWC_DATA_111=0E0000EB10D04DE20D00A0E1640500FB0211A 0E3010050E10600000A0060A0E110D08DE234109DE5
HWC_DATA_112=061081E034108DE5FF5FBDE804F05EE22200A 0E3F0F4FFFA0D70A0E100200FE100104FE11F0001E2
HWC_DATA_113=100050E31F00A003C00080E300F02FE108009 FE5036027E902F02FE11EFF2FE1BEBABEBAFF5F2DE9
HWC_DATA_114=F0FFFFEB10D04DE20D00A0E1660500FB0060A 0E110D08DE234109DE5061081E034108DE5FF5FBDE8
HWC_DATA_115=0EF0B0E1FEFFFFEA14F09FE514F09FE514F09 FE514F09FE514F09FE514F09FE514F09FE510E210F0
HWC_DATA_116=10E210F010E210F010E210F010E210F010E21 0F010E210F00000E0E3100F03EEFF5F2DE900100FE1
HWC_DATA_117=00004FE103002DE910FFFFFAFEFFFFEAF6FFF FEA7847C04600004FE11EFF2FE17847C0461F1000E2
HWC_DATA_118=100051E31F10A00300000FE101F02FE10D10A 0E100F02FE10100A0E11EFF2FE1FFB5016804008807
HWC_DATA_119=91B08C4612991D0B0905890D8902109112999 E0A8905090E0903B6022D03800F00280F9147D00128
HWC_DATA_120=6DD002286CD003286BD11068109945185068C 005000F01F0A1FA0D9020688006800F01F0AAFAAE42
HWC_DATA_121=8446B7A200D0B8A22368B8A19808C00700D1B 7A1DF08FF07B4A000D1B4A004AF07C7980A0D9A8002
HWC_DATA_122=01AF614607C7129AB0A10095EC20FBF7BEFDB E4FB86800280FD0AE420DD1EC20BBA1FBF7B4FD2168
HWC_DATA_123=BC68022204200623A047EC20BBA1FBF7AAFD1 5B0F0BD6146BA4F890500200B0FC10079588B4231D1
HWC_DATA_124=51688907890F012911681BD10F9A8E18B5429 5A200D096A2C000C019416802920191129AEC20AEA1
HWC_DATA_125=63460096FBF787FDA24FB8680028D8D0B542C 8D0D5E715E023E0C0E0109A8D18AE4287A200D088A2
HWC_DATA_126=C000C019416802920191129AA0A163460095A BE7401C1028C6D3BEE710680F991E0C36044518AE42
HWC_DATA_127=7BA200D07CA20192129A63469FA1009598E75 0688107890F012911684BD10F9AC0058918000F0E91
HWC_DATA_128=01F00CFA070020688006800F01F015FA0D902 0680006800F01F00FFA0C9020688005800F01F009FA
HWC_DATA_129=0B9020680005800F01F003FA84460E9863A28 54200D064A2236864A19808C00700D163A1DE08F607
HWC_DATA_130=60A000D160A007AE07C60C980D9904AA83C21 80B0B9A0003614601AE07C60E9A724900928031129A
HWC_DATA_131=EC20FBF710FD674FB8680028A1D00E9885428 6D05DE7109AC0058918000F0E9101F0C0F907002068
HWC_DATA_132=8006800F01F0C9F90D9020680006800F01F0C 3F90C9020688005800F01F0BDF90B9020680005800F
HWC_DATA_133=01F0B7F984460E983DA2864200D03EA223683 EA19808C00700D13DA1DD08ED073AA000D13AA007AD
HWC_DATA_134=07C50C980D9904AA83C2180B0B9A000361460 1AD07C50E9A4C4900928031129AEC20FBF7C4FC414F
HWC_DATA_135=B8680028B6D00E988642B2D011E727F073FEF 7B588B00999036889040F0D099905009807160D8908
HWC_DATA_136=0C053605800F3F05012838D0022837D003283 6D1D805000F01F060F9A64248A200D01BA2010048A0
HWC_DATA_137=02AB07C32B6848A11A0B12030192099AEC200 094FBF78FFC264B9868002810D0A6420ED1EC204EA1
HWC_DATA_138=FBF785FC214B01229C68042029680623A047E C2023A1FBF77AFC1C4B1868802808D24A49C2008F50
HWC_DATA_139=421C1A60FCE0C7E08EE0FEE0C2E000003C2D2 D2D2D00000000000000310000003000000025303858
HWC_DATA_140=3A202530385820564120253038582054696E7 920202020504120253038582041502025732028444F
HWC_DATA_141=4D41494E20257329204325732042257320257 300540500D853746F72696E67204C3220656E747279
HWC_DATA_142=2E2E2E00646F6E6500000000BC0E14F025303 8583A20253038582056412025303858204641554C54
HWC_DATA_143=202825732920257300000000253038583A202 53038582056412025303858204C6172676520257300
HWC_DATA_144=3C2D2D2D00000000202020202020200025303 8583A202530385820564120253038582046696E6520
HWC_DATA_145=2020204C32202530385820202020257320444 F4D41494E20257320257300000053746F72696E6720
HWC_DATA_146=4C3120656E7472792E2E2E00F82200D8D8050 00F01F09AF8079028680005800F01F0A3F87B4AA642
HWC_DATA_147=844600D07AA22B687AA19808C00700D179A1D F08FF0777A000D177A004AF07C7180D079A000501AF
HWC_DATA_148=614607C7099A73A1009452E0A6420DD18049E C20FBF7B3FBBC680122042029680623A047EC207C49
HWC_DATA_149=FBF7A9FB0BB0F0BDD805000F01F062F8624AA 64200D062A20100764802AB07C32B6875A19A0A9202
HWC_DATA_150=0192099AEC200094FBF791FB7F4B986800281 0D0A6420ED16A49EC20FBF787FB7A4B01229C680420
HWC_DATA_151=29680623A047EC206549FBF77CFB754B58688 028CED27449C2008F50421C5A60C000401829684160
HWC_DATA_152=C4E7484AA64200D047A20192099A6DA10094E C20FBF763FB684FB8680028A5D1B4E7F0B5060085B0
HWC_DATA_153=2CF09BFD002876D02FF04CF80500EC206AA1F BF750FB2A00EC2069A1FBF74BFBEC2066A1FBF747FB
HWC_DATA_154=5A480024012744603F030460200501AA02A90 1F06DF8A0004119320002A8FFF77CFE641CBC42F1D3
HWC_DATA_155=EC205AA1FBF72FFB00251EE04E480024EF003 81804904C482103C05901AA401802A901F051F80298
HWC_DATA_156=A100800A80024118049A330001A8FFF70FFD6 41CFF2CEAD9EC204AA1FBF70FFB6D1C3E4948688542
HWC_DATA_157=DCD300251FE054480024EF00381803905148A 102C05901AA401802A901F02CF80298A100000B0003
HWC_DATA_158=4118039A330001A8FFF7EAFC4948641C8442E 9D9EC2037A1FBF7E9FA6D1C2B4908688542DBD3EC20
HWC_DATA_159=32A1FBF7E0FA05B0F0BD000058E610F000000 0003100000030000000253038583A20253038582056
HWC_DATA_160=4120253038582053656374696F6E205041202 530385820415020257320444F4D41494E2025732043
HWC_DATA_161=257320422573202573000000A0E610F00CE61 0F060E610F0253038583A2025303858205641202530
HWC_DATA_162=385820436F61727365202020202020204C322 02530385820202020257320444F4D41494E20257320
HWC_DATA_163=25730000540500D8F82600D8253038583A202 53038582056412025303858204641554C5420202025
HWC_DATA_164=730000002A0000002A204C6576656C2031207 472616E736C6174696F6E207461626C6520696E2070
HWC_DATA_165=6879736963616C20616464726573733A20307 82530385800F82200D8FF03000070B50C000500EC20
HWC_DATA_166=15A1FBF754FAEC2014A1FBF750FAEC2011A1F BF74CFA23071B0F27F0F0EE10B509B509B513B516AE
HWC_DATA_167=19B09F0FA211A5B52A00EC200DA1FBF73AFA7 0BD17A19FE01FA19DE02A0027A190E02A002FA18DE0
HWC_DATA_168=2A0038A18AE000002A0000002A204661756C7 4207374617475733A002A20414C49474E4D454E5420
HWC_DATA_169=4641554C54202D2061636365737320746F206 164647265737320307825303858000000002A204558
HWC_DATA_170=5445524E414C2041424F525420494E204C312 05452414E534C4154494F4E00002A2045585445524E
HWC_DATA_171=414C2041424F525420494E204C32205452414 E534C4154494F4E00002A2053454354494F4E205452
HWC_DATA_172=414E534C4154494F4E204641554C542C20564 13A20307825303858002A2050414745205452414E53
HWC_DATA_173=4C4154494F4E204641554C542C2056413A203 07825303858000000002A20444F4D41494E20464155
HWC_DATA_174=4C54202D2053454354494F4E2C2056413A203 07825303858000000002A0025A104E02A002CA101E0
HWC_DATA_175=2A0036A1EC20FBF79EF92800FFF73DFE70BD3 CA100E042A1EC20FBF794F970BD27F04AFB70B590B0
HWC_DATA_176=01A829F04BFC424CA06800280FD0EC2040A1F BF784F906220092A4683C2201200F2301A9A047EC20
HWC_DATA_177=4149FBF778F9EC2140A0FBF701F9EC213FA0F BF7FDF8EC213CA0FBF7F9F8424D002401AEA0003358
HWC_DATA_178=2A58EC203FA1FBF762F9641C0F2CF5D310B07 0BD2A20444F4D41494E204641554C54202D20504147
HWC_DATA_179=452C2056413A203078253038580000002A205 045524D495353494F4E204641554C54202D20534543
HWC_DATA_180=54494F4E2C2056413A2030782530385800000 0002A205045524D495353494F4E204641554C54202D
HWC_DATA_181=20504147452C2056412030782530385800000 0002A2045585445524E414C2041424F5254202D2053
HWC_DATA_182=454354494F4E00002A2045585445524E414C2 041424F5254202D205041474500540500D853746F72
HWC_DATA_183=696E672043503135207265676973746572732 E2E2E0000000CE610F02A0000002A20435031352072
HWC_DATA_184=656769737465722064756D7000000000600E1 4F02A20252D313573203078253038580000F1B5EC20
HWC_DATA_185=8EB077A576A477A1FBF7D5F8EC2076A1FBF7D 1F8EC2073A1FBF7CDF80E9A506C400840000A9029F0
HWC_DATA_186=C3FAC006C00E172807D01B2809D10E9A50688 00603D5022604E0082602E0042600E000260A9801F0
HWC_DATA_187=32FA431C70D00A9830380D9001F02BFA431CF 7D0654FB86800280FD0EC2064A1FBF7A1F80D98BF68
HWC_DATA_188=81088900032030220623B847EC206749FBF79 5F80E9A506881066BD5022009900A980890089D183D
HWC_DATA_189=0B200B902B88DA0A1E2A0C921ED16888C10A1 F2901D15CA400E05CA499054205520DC90A89184900
HWC_DATA_190=5A0501D5584A11436A18121D19040B0001922 A000343EC2054A10094FBF767F82D1D32E100229446
HWC_DATA_191=06927B22520200202D27BF021A400021BA420 79006D1012207921A0550A44AD450A448E01A0B0C2A
HWC_DATA_192=06D1012206921A054EA440D44FA43EE0082A0 6D102201A054EA438D44FA436E04AE2062A05D10420
HWC_DATA_193=1A054EA42FD44FA42DE0072A05D101201A054 EA427D44FA425E05A0A2C2A01D14EA413E02E2A02D1
HWC_DATA_194=48A40FE010E1282A01D14BA40AE02A2A01D14 6A406E0292A01D13CA402E02D2A02D138A401210AE0
HWC_DATA_195=0C9A132A01D141A403E00C9A122A02D13FA40 1229446002E09D00E9A526C52085200921BAA4202D1
HWC_DATA_196=00263AA200E008A267463F000AD01806810D5 805400F029103922A0036A101900094B6E080E00000
HWC_DATA_197=000000002A0000002A20496E7374727563746 96F6E2064756D703A00540500D853746F72696E6720
HWC_DATA_198=6661756C74696E6720696E737472756374696 F6E732E2E2E000000000CE610F0424C2000424C5800
HWC_DATA_199=0100C0FF2A203078253038582030782530385 820257320202030782530385800504F500050555348
HWC_DATA_200=000000004C444D494100000053544D4941000 0004C4452480000000053545248000000004C445220
HWC_DATA_201=0000000053545220000000004C44524200000 00053545242000000004C44520053545200203C2D2D
HWC_DATA_202=20486572652100002A2030782530385820307 8253034582020202020257320205225642C205B5350
HWC_DATA_203=2C20233078253032585D25730000000000280 DD05905C90E41439806400F02AF07C75A07520F0192
HWC_DATA_204=2A0035A1009424E000290CD0D805410F98064 00F02AF07C75A07520F01922A0039A1009415E00798
HWC_DATA_205=002804D001922A0040A100940DE0069800280 7D05805410F019102922A0044A1009402E000922A00
HWC_DATA_206=4BA1EC20FAF733FFAD1C0B98401E0B9000D3A 3E6002E0CD00998022801D1494900E049A1EC20FAF7
HWC_DATA_207=22FF089D1035089502E00998401E099009984 01E0028099000DD87E60FB0F0BDC0011BD5EC2044A1
HWC_DATA_208=FAF70DFF0E9A546C203C1F27002E06D00E9A4 B4D506C801BA04200D025A5220000952378EC2047A1
HWC_DATA_209=FAF7F9FE641C7F1EECD2DFE790E000002A203 0782530385820307825303458202020202025732020
HWC_DATA_210=5225642C205B5225642C20233078253032585 D25730000002A203078253038582030782530345820
HWC_DATA_211=20202020257320205225642C205B5225642C2 05225645D25730000002A2030782530385820307825
HWC_DATA_212=3034582020202020257320207B726567737D2 573000000002A203078253038582030782530345820
HWC_DATA_213=2020202025732020522564212C207B7265677 37D257300002A203078253038582030782530345825
HWC_DATA_214=73000000880F14F02E2E2E686D6D2C2061206 26164206461792E2E2E000000002A204A617A656C6C
HWC_DATA_215=65206D6F646520646973617373656D626C792 06E6F742079657420696D706C656D656E7465640000
HWC_DATA_216=64EF10F02A203078253038582030782530325 8257300000000200990EC2054A1FAF75DFE0E9A506C
HWC_DATA_217=8408A400303C0B200B90002E08D00E9A5C4D5 06C80088000801BA04200D05AA5276802200C214143
HWC_DATA_218=584B5A58C91849683A408A4206D10C2358435 44BC0188068099002E0401C2628ECD30998002808D0
HWC_DATA_219=3803010F09983B006F4623C722004CA127E07 80E7D2812D13802000A010202D5FF2109060843F90D
HWC_DATA_220=0222114080000843221808323B00009222004 9A111E00B200006B84311D13802000A010202D5FF21
HWC_DATA_221=090608438000221808323B000092220047A1E C20FAF7FFFD04E03B0022004CA10095F6E70B98241D
HWC_DATA_222=401E0B909DD2DDE6EC204CA1FAF7EFFDD8E6F 0B50025ED4300260400EC2085B052A1FAF7E4FDEC20
HWC_DATA_223=51A1FAF7E0FDEC204EA1FAF7DCFDA0688408A 4000027200000F055FF431C19D020000C30049000F0
HWC_DATA_224=4EFF431C12D0A54200D925000498864201D22 6000F36201D07C86B4607C32368220043A1EC20FAF7
HWC_DATA_225=BAFD9AE094E000002A204E4F54453A20636F6 E646974696F6E20636F646520616E64206164647265
HWC_DATA_226=7373696E67206D6F646520617265206E6F742 06465636F646564000064EF10F000000000980C14F0
HWC_DATA_227=2A20307825303858203078253038582020202 02025732564202E2E2E202573002A20307825303858
HWC_DATA_228=203078253038582020202020424C582030782 530385800002A203078253038582030782530385820
HWC_DATA_229=20202020424C202030782530385800002A203 078253038582030782530385825730000002A204572
HWC_DATA_230=726F723A204C52206973206F7574206F66207 2616E6765202D207472616E736C6174696F6E206661
HWC_DATA_231=756C74002A0000002A20537461636B2064756 D703A0000002A203078253038583A20307825303858
HWC_DATA_232=2030782530385820307825303858203078253 0385800000023000C33220052A160E73F1D1034402F
HWC_DATA_233=00D240E7584CA068002815D0EC2057A1FAF71 1FD6B1C05D0002E03D0721B521C290001E00022511E
HWC_DATA_234=A46802200623A047EC205549FAF7FFFC05B0F 0BDFEB50600EC2052A1FAF7F7FCEC2051A1FAF7F3FC
HWC_DATA_235=EC204EA1FAF7EFFC3400544F10340025A800C 11949686268009101923A582368EC204FA1FAF7DFFC
HWC_DATA_236=AD1C08340E2DEFD3EC2042A1FAF7D7FC48497 268082400203831D506ED0EC300CB58AB4201D10400
HWC_DATA_237=02E0401C0928F6D3E00044186368EC2047A1F AF7C0FCF2686068019200900200B368EC2048A1FAF7
HWC_DATA_238=B6FC274CA06800280DD0EC204DA1FAF7AEFCA 4684422311D00200623A047EC202749FAF7A4FCFEBD
HWC_DATA_239=70B504002CF068FD2CF062FD6068C006C00E1 72801D01B2818D1626CEC2044A1FAF791FC144DA868
HWC_DATA_240=00280ED0EC204BA1FAF789FC2100AC6844310 42205200623A047EC201449FAF77EFCA9E08CE00000
HWC_DATA_241=2A20307825303858202E2E2E2030782530385 83A205452414E534C4154494F4E204641554C540000
HWC_DATA_242=540500D853746F72696E6720737461636B206 36F6E74656E74732E2E2E0000000CE610F02A000000
HWC_DATA_243=2A2050726F636573736F72207265676973746 5722064756D703A0000180C14F02A2025337320203D
HWC_DATA_244=20307825303858202025337320203D2030782 530385800002A20535053522020203D203078253038
HWC_DATA_245=58202825732900002A2053505F2573203D203 0782530385820204C525F2573203D20307825303858
HWC_DATA_246=0000000053746F72696E672041524D2072656 7732E2E2E002A20444154412041424F5254202D2044
HWC_DATA_247=4F55424C45204641554C542C204C52203D203 078253038580000000053746F72696E67204C520000
HWC_DATA_248=EC2061A1FAF7EBFB2000FFF7EBFE2000FFF7F 7FD2000FFF705FB2000FFF74EFAFEF78CF92EF0EAF8
HWC_DATA_249=04002EF0F4F82100FFF77AF9FEF727F90120C 00770BD70B504002CF095FC2CF08FFC6068C006C00E
HWC_DATA_250=172801D01B2818D1626CEC204EA1FAF7BEFB5 94DA868002826D05849EC20FAF7B6FB2100AC684431
HWC_DATA_251=042205200623A047EC205349FAF7ABFB16E0E C2051A1FAF7A6FB2000FFF7A6FE2000FFF7B2FD2000
HWC_DATA_252=FFF70CFAFEF74AF92EF0AEF80100606CFFF73 AF9FEF7E7F80120C00770BD70B504002CF055FC2CF0
HWC_DATA_253=4FFC60682500C006C00E4435172801D01B281 7D1626CEC2041A1FAF77CFB384CA068002825D03749
HWC_DATA_254=EC20FAF774FBA4680422290005200623A047E C203249FAF76AFB16E0EC2043A1FAF765FB2000FFF7
HWC_DATA_255=65FE2000FFF771FD2000FFF77FFA2000FFF7C 8F9FEF706F92800FEF7F6FFFEF7A6F80E20FBF7AEFE
HWC_DATA_256=002070BD002070471F49020088688A6070471 D490020886070477047354A0021CB00D358834203D1
HWC_DATA_257=C800801840687047491C0429F4D330A070471 3498007000F0C310858704700002A20444154412041
HWC_DATA_258=424F5254000000002A2050524546455443482 041424F5254202D20444F55424C45204641554C542C
HWC_DATA_259=204C52203D203078253038580000000054050 0D88CF610F00CE610F02A2050524546455443482041
HWC_DATA_260=424F5254000000002A20554E444546494E454 420494E535452554354494F4E202D20444F55424C45
HWC_DATA_261=204641554C542C204C52203D2030782530385 8002A20554E444546494E454420494E535452554354
HWC_DATA_262=494F4E009C0E14F0554E4B4E4F574E00F7B50 0250600ED4382B02DF0BFFF07002DF0B0FFC00704D0
HWC_DATA_263=032000073818444200E000242DF0BEFF01908 0088000401C2DF0BEFF310D89003819405803990860
HWC_DATA_264=8107890F01290BD0022907D0032911D1000B0 00300193103890D06E0002509E0800A800200193103
HWC_DATA_265=090E8900405804990125086001982DF09BFF2 80005B0F0BDF8B506000C002DF081FF07002DF072FF
HWC_DATA_266=C00704D0032000073818454200E000252DF08 0FF009080088000401C2DF080FF300D800079190A58
HWC_DATA_267=0D231B079107890FC018002923D0012979D00 22921D0032976D1A007800FB10A01282AD0022851D0
HWC_DATA_268=03287BD1100B3103890D00034019890044504 0182DF07CFF300000F0C3FB2DF093FF300000F0BEFB
HWC_DATA_269=2DF07EFFBEE00460BCE0046000F0B6FB2DF06 AFF300000F0B1FB2DF071FF300000F0ACFB2DF07CFF
HWC_DATA_270=ACE00F239B01120B12031940002052190B189 B00401C4028D450F9D388001018FF21491C2DF0CEFF
HWC_DATA_271=0024300000F092FBA5034019800B80032DF05 EFF300000F089FB4019800B80032DF046FF641C042C
HWC_DATA_272=EBD383E0FF239B00120B12031940002052190 B189B00401C0428D450F9D38800101810212DF0A6FF
HWC_DATA_273=0024300000F06AFBA5024019800A80022DF03 6FF02E00FE068E00BE0300000F05DFB4019800A8002
HWC_DATA_274=2DF01AFF641C042CE7D357E0F64A51E0A0078 00F310B002803D001280CD0022846D1900A80020906
HWC_DATA_275=890D4019445040182DF0F6FE002426E0F0239 20A92021940002052190B189B00401C1028D450F9D3
HWC_DATA_276=8800101840212DF065FF0024300000F029FB8 00B8003A50340192DF0F5FE300000F020FB800B8003
HWC_DATA_277=40192DF0DDFE641C042CEBD31AE0300000F01 4FB800A8002A50240192DF0E0FE300000F00BFB800A
HWC_DATA_278=800240192DF0C8FE641C042CEBD305E0CD4A8 632CDA1D2A02BF039FB00982DF08FFEF8BDC84A8E32
HWC_DATA_279=F4E7F7B58CB0002416000022E443002700250 02003AB099407940892069215C308CE26F018EE055F
HWC_DATA_280=040A1E4F590002CE08208443C907090F04E00 2CE04208443C907490F099A0D4382430992089A0A43
HWC_DATA_281=0892079A82430792069A0A430692059A2CE00 1CE0528029005D349221201ADA1B2A02BF0F8FA0298
HWC_DATA_282=C04980000858032189028C430999FF2380078 00F1B019943099101018301820200020B4318431043
HWC_DATA_283=1543089AFF2302430892079A1B019A4307920 69A02430692059A302082430F430592ADE701CEFF21
HWC_DATA_284=E1310007C00D05438C4301220492A3E7A94A9 2A196A02BF0C2FA9DE70C980D994118491E01910C98
HWC_DATA_285=0AAA0BA9FFF738FE00283BD0012879D10A988 107890F51D0012956D002297FD0032971D103980028
HWC_DATA_286=05D0DF22D20081A198A02BF0A0FA0A9805990 49A01403943002A0A9103D00B9A22402A430B928843
HWC_DATA_287=C008C0070FD00126B6020C983100FDF797FD0 02803D00C9831002DF095FE0C9831002DF0A3FE0C98
HWC_DATA_288=0A99FFF73DFE0126B60279E00B98009020400 10029430C980B91FFF731FE00980B9A012109059043
HWC_DATA_289=C0080E00C00767D00C98FDF771FD002801D02 DF015FE2DF03DFE5DE0744A9D325CA161A02BF057FA
HWC_DATA_290=4EE00999089A01401143049A0A91002A03D00 B9A22402A430B928843C008C00713D0012636040C98
HWC_DATA_291=3100FDF74DFD002807D00C9831002DF04BFE0 2E035E00BE031E00C9831002DF055FE0C980A99FFF7
HWC_DATA_292=EFFD012636042BE00799069A014011438843C 008C0070A910FD0012636030C9831002DF03FFE0C98
HWC_DATA_293=3100FDF725FD002803D00C9831002DF023FE0 49A002A03D00B98204028430B900C980A99FFF7C8FD
HWC_DATA_294=0126360304E04E4AA6E74D4A0932A3E70C987 11E88430199801988420C9000D239E70FB0F0BD0FB4
HWC_DATA_295=10B5039904AAFFF7BCFE10BC08BC04B018470 8B51300002200920322FFF7EFFF08BD7CB50D000024
HWC_DATA_296=0600E44301A96A46FFF75AFD431C23D000280 ED001286DD100988107890F1BD001291DD0022969D0
HWC_DATA_297=032975D1012D76D11EE0012D06D0022D06D00 32D06D0042D0BD106E0019813E0019854E001980005
HWC_DATA_298=6DE00198C005040F70E0254AB23269E0012D0 5D0022D46D0032D5CD131044CE0C007040F62E00000
HWC_DATA_299=A702000068775F6D6D755F646573637269707 46F722E6300300000006C69737476616C203C202873
HWC_DATA_300=697A656F662869667065726D326D6D7570657 26D292F73697A656F662869667065726D326D6D7570
HWC_DATA_301=65726D5B305D292900000000CC0F14F09C050 00030203D3D20696E6F75746368616E676500000000
HWC_DATA_302=1907000024E0C007440F1FE0012DB7D0022DF 8D0032D0ED13105890F4900091DC8408407A40F11E0
HWC_DATA_303=0BE000E003E0022DE9D0032D02D0042D93D00 7E08006840F04E07E4A7E497FA02BF041F920007CBD
HWC_DATA_304=7A4A521DF6E7032157E708B51300002200920 422FFF73FFF08BD08B51300002200920122FFF737FF
HWC_DATA_305=08BD08B51300002200920222FFF72FFF08BD7 0B586B00D0011000A9E039102210022040003200492
HWC_DATA_306=009129000122029020000196FFF71BFF06B07 0BD1CB56A4601A9FFF789FC0198C005000F1CBD7CB5
HWC_DATA_307=4618761E012504002D0320006A4601A9FFF77 AFC002814D0012836D100988007800F17D001281CD0
HWC_DATA_308=022823D0032829D1
SIMLOCK_DATA_1=8D15652AF81FAD349B84440CEAAD97D8DD1 7601F0000000000000000244070000000000000180700
SIMLOCK_DATA_2=000000000050000005FFFFFF00B4000005F FFFFF0118000005FFFFFF017C000005FFFFFF01E00000
SIMLOCK_DATA_3=05FFFFFF0244000005FFFFFF02A8000005F FFFFF000000007FFF6F07FFFFFFFFF800030C03000503
SIMLOCK_DATA_4=000000007FFF6F3EFFFFFFFFC000030F020 00103000000007FFF6F3FFFFFFFFFC000031102000103
SIMLOCK_DATA_5=000000007FFF6F07FFFFFFFF07FE0313080 00503000000007FFF6F07FFFFFFFF07FE031B08000503
SIMLOCK_DATA_6=000000007FFF6F07FFFFFFFFF8000323030 00503000000007FFF6F3EFFFFFFFFC000032602000103
SIMLOCK_DATA_7=000000007FFF6F3FFFFFFFFFC0000328020 00103000000007FFF6F07FFFFFFFF07FE032A08000503
SIMLOCK_DATA_8=000000007FFF6F07FFFFFFFF07FE0332080 00503000000007FFF6F07FFFFFFFFF800033A03000503
SIMLOCK_DATA_9=000000007FFF6F3EFFFFFFFFC000033D020 00103000000007FFF6F3FFFFFFFFFC000033F02000103
SIMLOCK_DATA_10=000000007FFF6F07FFFFFFFF07FE034108 000503000000007FFF6F07FFFFFFFF07FE034908000503
SIMLOCK_DATA_11=000000007FFF6F07FFFFFFFFF800035103 000503000000007FFF6F3EFFFFFFFFC000035402000103
SIMLOCK_DATA_12=000000007FFF6F3FFFFFFFFFC000035602 000103000000007FFF6F07FFFFFFFF07FE035808000503
SIMLOCK_DATA_13=000000007FFF6F07FFFFFFFF07FE036008 000503000000003F007F206F07FFFFF800036803000503
SIMLOCK_DATA_14=000000003F007F206F3EFFFFC000036B02 000103000000003F007F206F3FFFFFC000036D02000103
SIMLOCK_DATA_15=000000003F007F206F07FFFF07FE036F08 000503000000003F007F206F07FFFF07FE037708000503
SIMLOCK_DATA_16=000000003F007F206F07FFFFF800037F03 000503000000003F007F206F3EFFFFC000038202000103
SIMLOCK_DATA_17=000000003F007F206F3FFFFFC000038402 000103000000003F007F206F07FFFF07FE038608000503
SIMLOCK_DATA_18=000000003F007F206F07FFFF07FE038E08 000503000000003F007F206F07FFFFF800039603000503
SIMLOCK_DATA_19=000000003F007F206F3EFFFFC000039902 000103000000003F007F206F3FFFFFC000039B02000103
SIMLOCK_DATA_20=000000003F007F206F07FFFF07FE039D08 000503000000003F007F206F07FFFF07FE03A508000503
SIMLOCK_DATA_21=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_22=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_23=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_24=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_25=FFFFFFFF
SIMLOCK_KEY_DATA_1=5AFDA494076C4C61F9E7DDBB6D7DF8E 0A388D377CAB44F3EAB6CE9DE508ED70AF5F6ABD95135C596
SIMLOCK_KEY_DATA_2=9DDD4E96BA1CE895A1D2AC2D8FABA9B DFD520DCF8B1EB5BFCE0862850F33E06017BCEE47FDC757C1
SIMLOCK_KEY_DATA_3=C1E1F746F0EEE53CC006F8F9A6DAFA9 6F99AACD1
WMDRM_PD_DATA_1=2E1100003C004400450056004300450052 0054002000760065007200730069006F006E003D002200
WMDRM_PD_DATA_2=31002E00300022003E003C004300450052 0054004900460049004300410054004500200074007900
WMDRM_PD_DATA_3=700065003D002200440045005600490043 00450022003E003C0044004100540041003E003C005500
WMDRM_PD_DATA_4=4E00490051005500450049004400200070 007200690076006100740065003D002200310022003E00
WMDRM_PD_DATA_5=4C00480041004200440058004700580066 005600620044007400770035004200630061006F004D00
WMDRM_PD_DATA_6=34003500430039003800440063003D003C 002F0055004E004900510055004500490044003E003C00
WMDRM_PD_DATA_7=5000550042004C00490043004B00450059 00200070007200690076006100740065003D0022003100
WMDRM_PD_DATA_8=22003E0046005900680033004F0066006D 002F004600460052005200630048006400550072004800
WMDRM_PD_DATA_9=4C0058007800500072005A0036006F0045 004600510072002F0073007A006E007300610032006E00
WMDRM_PD_DATA_10=660035007300490046006100300034006 E002B006F0063006F0067004A0051003D003D003C002F00
WMDRM_PD_DATA_11=5000550042004C00490043004B0045005 9003E003C004B004500590044004100540041003E004C00
WMDRM_PD_DATA_12=5600430036003700330074006E0046007 2004C00360076005A00450033004200700063006E006500
WMDRM_PD_DATA_13=5400420041004A00690045003D003C002 F004B004500590044004100540041003E003C002F004400
WMDRM_PD_DATA_14=4100540041003E003C004D00530044005 2004D005F005300490047004E0041005400550052004500
WMDRM_PD_DATA_15=5F00560041004C00550045003E0057007 500560075007A00380072006A005A003700450045006700
WMDRM_PD_DATA_16=75004700630043002F0048004D0072006 10033006500790042004E006F0058004500530049006300
WMDRM_PD_DATA_17=6C0058004C004B006B0032006B0035006 F005600620048002F004400550076003000700047006200
WMDRM_PD_DATA_18=67003D003D003C002F004D00530044005 2004D005F005300490047004E0041005400550052004500
WMDRM_PD_DATA_19=5F00560041004C00550045003E003C005 30059004D005300490047004E0041005400550052004500
WMDRM_PD_DATA_20=3E006F00560062003900510068005A005 400500041006E00300079005000320044006D0077005900
WMDRM_PD_DATA_21=6B0033005200500048004D004B0034003 D003C002F00530059004D005300490047004E0041005400
WMDRM_PD_DATA_22=5500520045003E003C002F00430045005 200540049004600490043004100540045003E003C004600
WMDRM_PD_DATA_23=41004C004C004200410043004B003E003 C0053004500430055005200490054005900560045005200
WMDRM_PD_DATA_24=530049004F004E003E0032002E0034002 E003100300038002E003200340039003C002F0053004500
WMDRM_PD_DATA_25=430055005200490054005900560045005 200530049004F004E003E003C0043004500520054004900
WMDRM_PD_DATA_26=460049004300410054004500200070007 200690076006100740065003D002200310022003E004600
WMDRM_PD_DATA_27=5900680033004F0066006D002F0046004 600520052006300480064005500720048004C0058007800
WMDRM_PD_DATA_28=500072005A0036006F004500460051007 2002F0073007A006E007300610032006E00660035007300
WMDRM_PD_DATA_29=490046006100300034006E002B006F006 3006F0067004A00510049004500620050006B0072005500
WMDRM_PD_DATA_30=6B0033003200490063005800490042003 500560079007100440046006C007600550034002F007A00
WMDRM_PD_DATA_31=7400780073006300780036006F0067005 50077004D004C0069005A00780068006B00640070003200
WMDRM_PD_DATA_32=2B0049006C00560070004700580052007 30045006B003C002F004300450052005400490046004900
WMDRM_PD_DATA_33=43004100540045003E003C002F0046004 1004C004C004200410043004B003E003C00430045005200
WMDRM_PD_DATA_34=540049004600490043004100540045002 00074007900700065003D002200470052004F0055005000
WMDRM_PD_DATA_35=22003E003C0044004100540041003E003 C004E0041004D0045003E00360033003000300069003C00
WMDRM_PD_DATA_36=2F004E0041004D0045003E0020000D000 A00200020003C004D0041004E0055004600410043005400
WMDRM_PD_DATA_37=55005200450052003E004E006F006B006 90061003C002F004D0041004E0055004600410043005400
WMDRM_PD_DATA_38=55005200450052003E0020000D000A002 00020003C004D0041004B0045003E004E006F006B006900
WMDRM_PD_DATA_39=61003C002F004D0041004B0045003E002 0000D000A00200020003C00440049005300540052004900
WMDRM_PD_DATA_40=4200550054004F0052003E004E006F006 B00690061003C002F004400490053005400520049004200
WMDRM_PD_DATA_41=550054004F0052003E0020000D000A002 00020003C004D004F00440045004C003E0052004D002D00
WMDRM_PD_DATA_42=3300330037003C002F004D004F0044004 5004C003E0020000D000A00200020003C00530045004300
WMDRM_PD_DATA_43=550052004900540059004C00450056004 5004C003E0032003000300030003C002F00530045004300
WMDRM_PD_DATA_44=550052004900540059004C00450056004 5004C003E0020000D000A00200020003C00480041005200
WMDRM_PD_DATA_45=440057004100520045005F00560045005 2005F004D0041004A004F0052003E00310030003C002F00
WMDRM_PD_DATA_46=480041005200440057004100520045005 F005600450052005F004D0041004A004F0052003E002000
WMDRM_PD_DATA_47=0D000A00200020003C004800410052004 40057004100520045005F005600450052005F004D004900
WMDRM_PD_DATA_48=4E004F0052003E0030003C002F0048004 1005200440057004100520045005F005600450052005F00
WMDRM_PD_DATA_49=4D0049004E004F0052003E0020000D000 A00200020003C004600490052004D005700410052004500
WMDRM_PD_DATA_50=5F005600450052005F004D0041004A004 F0052003E0033003C002F004600490052004D0057004100
WMDRM_PD_DATA_51=520045005F005600450052005F004D004 1004A004F0052003E0020000D000A00200020003C004600
WMDRM_PD_DATA_52=490052004D0057004100520045005F005 600450052005F004D0049004E004F0052003E0032003000
WMDRM_PD_DATA_53=3C002F004600490052004D00570041005 20045005F005600450052005F004D0049004E004F005200
WMDRM_PD_DATA_54=3E0020000D000A002D0020003C0046004 5004100540055005200450053003E000D000A0020002000
WMDRM_PD_DATA_55=3C0043004C004F0043004B003E0031003 C002F0043004C004F0043004B003E000D000A0020002000
WMDRM_PD_DATA_56=3C004D00450054004500520049004E004 7003E0031003C002F004D00450054004500520049004E00
WMDRM_PD_DATA_57=47003E0020000D000A00200020003C004 C004900430045004E00530045005F004100430051003E00
WMDRM_PD_DATA_58=31003C002F004C004900430045004E005 30045005F004100430051003E0020000D000A0020002000
WMDRM_PD_DATA_59=3C004C004900430045004E00530045005 F00530059004E0043003E0031003C002F004C0049004300
WMDRM_PD_DATA_60=45004E00530045005F00530059004E004 3003E0020000D000A00200020003C0045004E0043005200
WMDRM_PD_DATA_61=59005000540049004F004E003E0030003 C002F0045004E004300520059005000540049004F004E00
WMDRM_PD_DATA_62=3E0020000D000A00200020003C0053005 9004D004D00450054005200490043005F004F0050005400
WMDRM_PD_DATA_63=3E0031003C002F00530059004D004D004 50054005200490043005F004F00500054003E0020000D00
WMDRM_PD_DATA_64=0A00200020003C002F004600450041005 40055005200450053003E000D000A002D0020003C004C00
WMDRM_PD_DATA_65=49004D004900540053003E000D000A002 00020003C004D004100580043004800410049004E004400
WMDRM_PD_DATA_66=45005000540048003E0032003C002F004 D004100580043004800410049004E004400450050005400
WMDRM_PD_DATA_67=48003E0020000D000A00200020003C004 D00410058004C004900430045004E005300450053004900
WMDRM_PD_DATA_68=5A0045003E00310030003200340030003 C002F004D00410058004C004900430045004E0053004500
WMDRM_PD_DATA_69=530049005A0045003E0020000D000A002 00020003C004D0041005800480045004100440045005200
WMDRM_PD_DATA_70=530049005A0045003E003500310032003 0003C002F004D0041005800480045004100440045005200
WMDRM_PD_DATA_71=530049005A0045003E0020000D000A002 00020003C002F004C0049004D004900540053003E003C00
WMDRM_PD_DATA_72=5000550042004C00490043004B0045005 9003E007A0031007200510039006C007200360062004900
WMDRM_PD_DATA_73=4B0056004F00690072005500520077004 2004D00480044006D0049006E00460062004A002F006F00
WMDRM_PD_DATA_74=72002B006F0071004C004C00690078006 F004C0069007A006100480058007A00320032002B006200
WMDRM_PD_DATA_75=630049004E0051003D003D003C002F005 000550042004C00490043004B00450059003E003C002F00
WMDRM_PD_DATA_76=44004100540041003E003C004D0053004 40052004D005F005300490047004E004100540055005200
WMDRM_PD_DATA_77=45005F00560041004C00550045003E004 60034006E00490033005600590064006300340056006C00
WMDRM_PD_DATA_78=490031007000350046005800620067004 D0044006700680072007800490078006F0056004C006800
WMDRM_PD_DATA_79=430072005A006600320031006D0053004 4004500500067004E004B006A0049004F00350056004400
WMDRM_PD_DATA_80=670041003D003D003C002F004D0053004 40052004D005F005300490047004E004100540055005200
WMDRM_PD_DATA_81=45005F00560041004C00550045003E003 C002F004300450052005400490046004900430041005400
WMDRM_PD_DATA_82=45003E003C00430045005200540049004 60049004300410054004500200074007900700065003D00
WMDRM_PD_DATA_83=220041005500540048004F00520049005 A004100540049004F004E0022003E003C00440041005400
WMDRM_PD_DATA_84=41003E003C00530045004300550052004 900540059004C004500560045004C003E00320030003000
WMDRM_PD_DATA_85=30003C002F00530045004300550052004 900540059004C004500560045004C003E003C0041005500
WMDRM_PD_DATA_86=540048005F00490044003E00320031003 40031003C002F0041005500540048005F00490044003E00
WMDRM_PD_DATA_87=3C005000550042004C00490043004B004 50059003E00420076004900750061005300630061003000
WMDRM_PD_DATA_88=650042005000760077004600450073006 7006500380079004A004B006F0032006D0073007A004800
WMDRM_PD_DATA_89=3600360067002F0048004F006A002F006 D007A006A005400490066003700470055005A0062004200
WMDRM_PD_DATA_90=730054007400660077003D003D003C002 F005000550042004C00490043004B00450059003E003C00
WMDRM_PD_DATA_91=2F0044004100540041003E003C004D005 300440052004D005F005300490047004E00410054005500
WMDRM_PD_DATA_92=520045005F00560041004C00550045003 E0051004900720073003200310041006A00520033003600
WMDRM_PD_DATA_93=420056004D004F0065004C00330048004 60031006300560056007A00570055004C00550058004900
WMDRM_PD_DATA_94=4700470070004600370043004F0055005 90049005100660042004A00330055007100410075006900
WMDRM_PD_DATA_95=4500430041003D003D003C002F004D005 300440052004D005F005300490047004E00410054005500
WMDRM_PD_DATA_96=520045005F00560041004C00550045003 E003C002F00430045005200540049004600490043004100
WMDRM_PD_DATA_97=540045003E003C0043004500520054004 90046004900430041005400450020007400790070006500
WMDRM_PD_DATA_98=3D00220041005500540048004F0052004 9005A004100540049004F004E005F0052004F004F005400
WMDRM_PD_DATA_99=22003E003C0044004100540041003E003 C0041005500540048005F00490044003E0031003C002F00
WMDRM_PD_DATA_100=41005500540048005F00490044003E00 3C005000550042004C00490043004B00450059003E006100
WMDRM_PD_DATA_101=31007400330068007800720067002100 710062004F0067006B0074006E0062005900610045004500
WMDRM_PD_DATA_102=69003400740065004300730065002100 67007A00360052007600540050007500430021007A006900
WMDRM_PD_DATA_103=7A004B004A006C007000550037007800 6F0064007500530077003D003D003C002F00500055004200
WMDRM_PD_DATA_104=4C00490043004B00450059003E003C00 2F0044004100540041003E003C004D005300440052004D00
WMDRM_PD_DATA_105=5F005300490047004E00410054005500 520045005F00560041004C00550045003E00390068007A00
WMDRM_PD_DATA_106=51002B0071006E004E005A0079005800 6400610072004E005A005500790031004500360070005A00
WMDRM_PD_DATA_107=47007500560035004700490050004600 45006900570074006700620034006100710070006C004D00
WMDRM_PD_DATA_108=4500640052005500640062004F007900 6C004D0067003D003D003C002F004D005300440052004D00
WMDRM_PD_DATA_109=5F005300490047004E00410054005500 520045005F00560041004C00550045003E003C002F004300
WMDRM_PD_DATA_110=45005200540049004600490043004100 540045003E003C002F004400450056004300450052005400
WMDRM_PD_DATA_111=3E00
CHECKSUM=-1
[CERT_PROG_DATA_OUT_APE]
PRODUCTCODE=0555967
PSN=KEV541594
HWID=1202
CHECKSUM=-1
[MISC_PROG_DATA_OUT]
RF_DATA_1=0001000C000000721B6F00000000000000000000 0000000000000000000000000000000000000002
RF_DATA_2=00050015003300040007FFD7FFDCFFE900000000 0000000000000000000000000000000000000000
RF_DATA_3=0000000000000000000000000000000000000000 000000000000000000000000000000000000FFDD
RF_DATA_4=007700020062FF3AFFCF40BD4009FDC400690000 247A247A247A247A1FFF1C2818F51709147A128F
RF_DATA_5=11470FFF0EB80E140CCC0C280B840AE1247A247A 247A247F20101B7417DC150012B510D60F370DD3
RF_DATA_6=0C880B5F0A68098408C307FE00071C7600071C76 00071C760004006E1AFD00000000000000000000
RF_DATA_7=0000000000000000000000000000000000000003 000C000E002D000FFFF9FFF2FFF3FFED00000000
RF_DATA_8=0000000000000000000000000000000000000000 0000000000000000000000000000000000000000
RF_DATA_9=0000000000000000000000000000000000000006 00620031003140BD4028047900570000247A1EB7
RF_DATA_10=1AE017AD151E128F11470F5B0E140D700C280B8 40AE10A3D0A3D09990999099925681D4C18DE154C
RF_DATA_11=1268103B0E6D0CEA0BA00A83098708A80818079 9072206AB0999099900011EA500011EA500011EA5
RF_DATA_12=0008006E1AE5000000000000000000000000000 00000000000000000000000000000000300350046
RF_DATA_13=003800070014FFF7FFDBFFAC000000000000000 00000000000000000000000000000000000000000
RF_DATA_14=000000000000000000000000000000000000000 00000000000000000000000000000000D00620051
RF_DATA_15=004340004016035A005B0000247A1EB71AE0185 115C2133211EB0FFF0EB80E140CCC0C280B840AE1
RF_DATA_16=0AE10A3D0A3D0A3D25041D0F18B8154B1278105 50EB60D390BEC0ACF09DA08FA086107DC076506F7
RF_DATA_17=0A3D0A3D00021BE700021BE700021BE70010005 6FF3AFFCF40BD4009FDC4006C00001A3D1A3D1A3D
RF_DATA_18=1A3D1A3D1A3D1A3D185115C213D6128F10A30F5 B0EB80D700CCC0C280B841A3D1A3D1A3D1A3D1A3D
RF_DATA_19=1A3D1A8517E61502128610690EAA0D230BE00AC B09D60903083F001200560031003140BD40280479
RF_DATA_20=005D00001AE01AE01AE01851166613D611EB10A 30F5B0E140D700C280B840B840AE10A3D0A3D0A3D
RF_DATA_21=1AE01AE01B3217BD143811AC0F6B0DDE0C780B4 B0A46095608AF0813079907150A3D0A3D00140056
RF_DATA_22=0051004340004016035A006100001AE01AE01AE 018511666147A128F11470FFF0EB80E140CCC0C28
RF_DATA_23=0C280B840AE10AE10AE11AE01AE01B0717DF141 A11A70F970E010C9B0B8C0A9309A80901086907DA
RF_DATA_24=07680AE10AE10019000401AD000C001D0
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
5110 Security Code Help! cahrisma Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-05-2010 09:04
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-22-1999 00:28
FREE SP unlock service timxy Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-22-1999 16:05
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-29-1999 22:35
Powered by Searchlight © 2012 Axivo Inc.
- GSM Hosting Ltd. - 1999-2011
Page generated in 1.28096 seconds with 10 queries
