Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 08-01-2012, 14:38   #1 (permalink)
kashif_nawaz81's Avatar
Member: 246429
6500s-1 Group erase failed
when i flash using fbus cable, it give error, group erase faile. what should i do, its urgent plz
Iam flashing with version 12.35, Can i flash this mobile by ver 59.60
Old 08-01-2012, 14:51   #2 (permalink)
Member: 246429
Again i have flash the same ver 12.35 it flash whole mobile but stop at end factory setting defualt Can i flash with ver 59.60
here is log
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.04, (Jun 10 2012 18:37:23, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C00064C8
HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk48
Initializing security card...
Card Serial Number: D0080107
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4.94v PASSED
MCU Voltage 3.30v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 1.21v PASSED
VBAT Voltage 4.86v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 4.90v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 1.215GB
Avaiable Virtual Memory: 1.860GB
Avaiable Pagefile: 3.137GB
Initializing FBUS...
All initialized - Ready to work
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 14E00013708C02543F53E11056F1D8A75D1FAFBD
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR
FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
Warning: PAPUBKEYS Hash Missing!
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing rm240__12.35.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm240__12.35.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x01480000-0x015FFFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0147FFFF, NOR
Waiting 320s for erasure finish...
Erase taken 74.531s
Writing all blocks...
Initializing TurboCache...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 120.0s
Flashing Speed: 1425.62 kBit/S
Restarting MCU...
Processing rm240__12.35.mcusw (APE)...
Processing rm240__12.35.ppm_a (CMT)...
Booting CMT...
CMT Ready!
rm240__12.35.ppm_a, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
Box VPP disabled
PAPUBKEYS Hash for CMT: A69838E8C5F20150E64E2E6E06DE6E50B26B593F
EraseArea[0,CMT]: 0x01600000-0x01CBFFFF, NOR
Erase taken 33.625s
TurboCache Loaded!
All blocks written OK! Time taken 36.984s
Flashing Speed: 1292.73 kBit/S
Restarting MCU...
Processing rm240__12.35.ppm_a (APE)...
Processing rm240__12.35_ism_015.image_a_3_se_silver_v2 (CMT)...
Booting CMT...
CMT Ready!
rm240__12.35_ism_015.image_a_3_se_silver_v2, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01FC0000-0x03F9FFFF, NOR
EraseArea[0,CMT]: 0x01CC0000-0x01FBFFFF, NOR
Erase taken 56.640s
TurboCache Loaded!
All blocks written OK! Time taken 62.672s
Flashing Speed: 1507.58 kBit/S
Restarting MCU...
Processing rm240__12.35_ism_015.image_a_3_se_silver_v2 (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Old 08-01-2012, 15:02   #3 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
no as it is an sl3 firmware: the imei would go to 1234560.
if you have all the needed back-ups (rpl and PM) full erase the mobile and reflash it, if not try at least to make the rpl back-up in emergency mode or read the certs.
Be sure what class was the mobile before the flash (< 49.xx = SL2 simlock rebildable and needs only the NPC - 50.00 onward SL3 and you need the simlock back-up too)
Alex
Old 08-01-2012, 15:38   #4 (permalink)
Member: 246429
Flash agian with file ver 8.63 now the mobile flash successfully but when power on, after nokia logo mobile is shutting down, what is this problem
here is log
Sending User Abort Signal...
CBUS Request Error -> User abort
Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only
Booting CMT...
CMT Ready!
Box VPP disabled
APE Subsystem Not Found
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
CMT PARTNERC Not Found
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Processing rm240__10.30.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm240__10.30.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Erase taken 102.860s
TurboCache Loaded!
All blocks written OK! Time taken 122.797s
Flashing Speed: 1393.15 kBit/S
Restarting MCU...
Processing rm240__10.30.mcusw (APE)...
Processing rm240__10.30.ppm_c (CMT)...
Booting CMT...
CMT Ready!
rm240__10.30.ppm_c, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Erase taken 34.204s
TurboCache Loaded!
All blocks written OK! Time taken 43.62s
Flashing Speed: 1250.48 kBit/S
Restarting MCU...
Processing rm240__10.30.ppm_c (APE)...
Processing rm240__10.30_ISM_001.image_c_tr_ctv_tr (CMT)...
Booting CMT...
CMT Ready!
rm240__10.30_ISM_001.image_c_tr_ctv_tr, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Erase taken 46.844s
TurboCache Loaded!
All blocks written OK! Time taken 65.438s
Flashing Speed: 1475.94 kBit/S
Restarting MCU...
Processing rm240__10.30_ISM_001.image_c_tr_ctv_tr (APE)...
Post flash tasks finished!
Flashing successfully finished!
Old 08-01-2012, 16:01   #5 (permalink)
Member: 246429
Is this is the original rpl as i make when i was flashing
Now i erase the mobile
Old 08-01-2012, 16:19   #6 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
Post security analyze log..and read info log
Old 08-01-2012, 16:23   #7 (permalink)
Member: 246429
Alex
Sir is this is the original rpl, iam new in flashing and before this i hav not do this type of work so please guide me
YOu have said to make sim lock, i have again flash by tick simlock option
please tell me where is the sim lock data, if i only take rpl from this phone and erase phone then this will better or not?????????
here is the log
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Initializing box...
Card is activated
Box is activated
USB Voltage 4.79v PASSED
MCU Voltage 3.29v PASSED
VBAT Voltage 1.03v PASSED
VBAT Voltage 4.75v PASSED
Box VPP disabled
VPP Voltage 4.83v PASSED
Box VPP disabled
Box VPP disabled
Avaiable Physical Memory: 1.179GB
Avaiable Virtual Memory: 1.878GB
Avaiable Pagefile: 3.87GB
Backing up simlock...
Simlock backup problem -> Phone not detected
Backup simlock thread finished, continuing...
Booting CMT...
CMT Ready!
Box VPP disabled
Erase taken 104.422s
TurboCache Loaded!
All blocks written OK! Time taken 121.703s
Flashing Speed: 1405.67 kBit/S
Restarting MCU...
Booting CMT...
CMT Ready!
Box VPP disabled
Erase taken 35.703s
TurboCache Loaded!
All blocks written OK! Time taken 45.359s
Flashing Speed: 1187.15 kBit/S
Restarting MCU...
Booting CMT...
CMT Ready!
Box VPP disabled
Erase taken 89.735s
TurboCache Loaded!
All blocks written OK! Time taken 69.641s
Flashing Speed: 1386.86 kBit/S
Restarting MCU...
Old 08-01-2012, 16:25   #8 (permalink)
Member: 246429
sir iam online and waiting for your answer, plz help
Old 08-01-2012, 16:25   #9 (permalink)
Mr.3.'s Avatar
Member: 962029
Go to bb5 / security read all certs
Erase cert tick npc only
Then check phone can go to local mode or not
Post result ....
Old 08-01-2012, 16:28   #10 (permalink)
Member: 246429
reading all cer successfully, but not going on local mode only which screen comes and agian shut down
Old 08-01-2012, 16:34   #11 (permalink)
Mr.3.'s Avatar
Member: 962029
And tell us what was the phone condition before you flash?
Old 08-01-2012, 16:34   #12 (permalink)
Member: 246429
reding certificatre and erase npc tick
now there is not any local mode comming
Old 08-01-2012, 16:36   #13 (permalink)
Member: 246429
sir nokia logo is comming and mobile is shutting after this
then i flash with ver 10 and ver 10.30
Old 08-01-2012, 16:38   #14 (permalink)
Member: 246429
when i flash with ver 10.30 it flash successfully but the same problem, after nokia logo shutting down immediately
now iam flashig again by this ver, flashing stop at end set factory setting default
Old 08-01-2012, 16:40   #15 (permalink)
Mr.3.'s Avatar
Member: 962029
Restore certs again
And open the phone and remove n2000 (hands free ic and check )
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
DES key Driver black Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-19-2012 05:32
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-19-1999 17:41
Page generated in 0.44813 seconds with 12 queries
