Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 12-31-2011, 23:54   #1 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Red face 6600s possible log for brute force???please help {Solved]
Hello y have nokia 6600s wed some problem...y kent connect wed eny box wed f-bus cable....itīs working good.....y dont have eny idea how to unlock since the parte of pin inside fone is dark.....
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.11865
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: Cxxxxxxx
2009, wk40
Initializing security card...
Card Serial Number: Dxxxxxxxx
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5,21v PASSED
MCU Voltage 3,29v PASSED
Core Voltage 1,80v PASSED
VBAT Voltage 0,01v PASSED
VBAT Voltage 5,16v PASSED
Box VPP disabled
VPP Voltage 0,00v PASSED
Internal Box VPP Enabled
VPP Voltage 5,15v PASSED
Box VPP disabled
VPP Voltage 0,02v PASSED
External Box VPP Enabled
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Credits Left: 100
Avaiable Physical Memory: 1.457GB
Avaiable Virtual Memory: 1.419GB
Avaiable Pagefile: 3.379GB
Initializing FBUS...
All initialized - Ready to work
BB5 Unlock Started...
[Nokia 6600 slide USB Phonet]: Port opened OK!
MCU Version V 06.14
MCU Date 30-03-09
Product RM-414 (Nokia 6600 slide)
Manufacturer (c) Nokia
IMEI 351954038139807
Mastercode 3713252175
Simlock Server SIMLOCK SERVER
Simlock Key 2140700000000000
Simlock Profile 8000000000000002
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21407F
Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21402F
Reading Security Block...
2011_200612.SecurityBlock.PM"
read it...
Reading CYC file from phone...
Booting CMT...
Switching to RAW Mode...
[Nokia USB Flashing Generic]: Port opened OK!
Old ROM Detected
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101023000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 24F0000C0B777D567110040DB8C79616C4502039
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
transport
Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone)
BB5 Unlock Failed -> Failed to obtain Phone Unique Data
MCU Version V 06.14
MCU Date 30-03-09
Simlock Key Cnt 0
Simlock FBUS Cnt 0
2011_200719.SecurityBlock.PM"
Determining PA Simlock...
Booting CMT...
Old ROM Detected
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
transport
BB5 Unlock Failed -> Failed to Boot / Prepare Phone
MCU Version V 06.14
MCU Date 30-03-09
Simlock Key Cnt 0
Simlock FBUS Cnt 0
2011_200915.SecurityBlock.PM"
Booting CMT...
Old ROM Detected
CMT Ready!
Searching for BootCode: Single Line 8Bit
transport
MCU Version V 06.14
MCU Date 30-03-09
Simlock Key Cnt 0
Simlock FBUS Cnt 0
2011_201135.SecurityBlock.PM"
read it...
Booting CMT...
Old ROM Detected
CMT Ready!
transport
MCU Version V 06.14
MCU Date 30-03-09
Simlock Key Cnt 0
Simlock FBUS Cnt 0
2011_201243.SecurityBlock.PM"
read it...
Booting CMT...
Old ROM Detected
CMT Ready!
transport
dont now what ken y doo ...................
Old 01-01-2012, 00:13   #2 (permalink)
Haicha's Avatar
Member: 330579
Sonork: 100.1620425
Carlos! You don't Have USB Cable?
Regards
Haicha
Old 01-01-2012, 00:35   #3 (permalink)
Haicha's Avatar
Member: 330579
Sonork: 100.1620425
You can Read Phone with F-Bus Cable.In Program have Option For Use F-Bus.Check and see if Cable is OK.
In Connection-Select Cyclone Interface. (Use TXT Ad)
Regards
Haicha
The Following User Says Thank You to Haicha For This Useful Post:
Old 01-01-2012, 11:45   #4 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Regards
Haicha
y olredy use f-bus but noo box detect fone.....and unlock wed usb itīs impossible
Old 01-01-2012, 11:48   #5 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Connect it via fbus, do check flashing bus then do read unique data in the bb5/security tab
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 01-01-2012, 13:45   #6 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Alex
nathing sims to work...and wed cable FBBUS fone not heven goo to local mode ......
Initializing box...
Box Firmware: Cyclone Nokia/Blackberry Application v01.82, (Nov 12 2011 09:45:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011
Box Serial Number: xxxxxxxxx
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40
Card is activated
Box is activated
USB Voltage 5,17v PASSED
MCU Voltage 3,30v PASSED
VBAT Voltage 1,51v PASSED
VBAT Voltage 5,07v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
VPP Voltage 5,13v PASSED
Box VPP disabled
VPP Voltage 0,00v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Avaiable Physical Memory: 1.529GB
Avaiable Virtual Memory: 1.417GB
Avaiable Pagefile: 3.547GB
Booting CMT...
Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem
Failed to Read ASK via Flash Bus -> Failed to Boot CMT
Booting CMT...
Sending User Abort Signal...
CBUS Request Error -> User abort
Failed to Read ASK via FBUS -> Phone not detected
RPL Creation started...
Processing CMT Part...
Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only
Booting CMT...
Prepare phone failed with message -> Failed to Boot CMT
Failed to Create RPL from phone -> Failed to Boot / Prepare Phone
Booting CMT...
Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone
Booting CMT...
Booting CMT...
Old 01-01-2012, 16:55   #7 (permalink)
Member: 478535
What fbus cable are you trying to use carlos32?
Old 01-01-2012, 20:47   #8 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
y use gpg 6600s F-bus and f-bus jaf/hwk cable ...2 diferent cable and not heven good to local mode...only hwkufs turn fone normaly and fone say wek batery and then off.........humm........y ask again new cable......now new cable if dont work.......mast bee hardwere fone problem
...y
Old 01-01-2012, 20:59   #9 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
y use this 2 cables
Old 01-02-2012, 02:44   #10 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
...y
You need a tool for the local mode/power problem like the TMA evolution or the cyclone V2 adapter: use it to increase the BSI value and get a stable local mode
Alex
Old 01-02-2012, 12:36   #11 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Alex
sir ken you provide my linkīs for that cable???ur photo ???
Old 01-02-2012, 13:24   #12 (permalink)
Member: 490127
oh man 6600S IS SL2 PHONE
Old 01-02-2012, 13:25   #13 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
you can use one or the other with the same effect: both valid tools
GSMSP | Cyclone V2.0 Adaptor
or
GSMSP | TMA Evolution
Alex
Old 01-02-2012, 18:00   #14 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
this is very good sir.tankīs.....if wed all cables still kent read fone wed box .....ken y creat log for brute force???because y now this fone is sl2 fone ...problem is that y kent connect box ............
for shure y will buy all that cables......(tankīs for the tip)
REGARDīS
Old 01-02-2012, 18:05   #15 (permalink)
Member: 490127
use jig set..............
The Following User Says Thank You to josipluic For This Useful Post:
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
Page generated in 0.41198 seconds with 12 queries
