Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 05-17-2009, 08:24   #1 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 469
7370 can't unlock and can't read simlock status with cyclone box !!
Like in topic I try and can't
All initialized - Ready to work
MCU Version V 04.13
MCU Date 16-05-06
Product RM-70
Manufacturer (c) Nokia.
IMEI 351882013638131
Mastercode 626761264
IMEI Spare 3A15880231361803
IMEI SV 3315880231361803F6000000
PPM V 04.13, 16-05-06, RM-70, (c) Nokia., B
CNT Content: era_pl_cool, V 04.13, 16-05-06, RM-70, (c) Nokia.,
PSN CEF938931
Product Code 0540014
Module Code 0202645
Basic Product Code 0521585
PSD 0000001700000000
RETU 32
TAHVO 52
AHNE 11
HW 6001
RFIC 17191719
DSP dsp_soho_05w32v20.1
LCD SEIKO
Failed to read info -> Failed to read SP info
MCU Version V 04.13
MCU Date 16-05-06
Product RM-70
PSN CEF938931
Module Code 0202645
RETU 32
TAHVO 52
AHNE 11
HW 6001
RFIC 17191719
LCD SEIKO
BB5 Unlock Started...
MCU Version V 04.13
MCU Date 16-05-06
Product RM-70
Warning: Failed to read SP Info, Assuming defaults
BB5 Unlock Failed -> Initial SP corrupted or not a Baseband5 phone detected
with other box can read info without problem
MCU Nokia Version: 1.126, and up to date.
SMCU Nokia Version: 1.42, and up to date.
Initializing phone...
Output power at Line1 3,95V is in range of: 4,00V 10,0%
Phone powered.
Reading Info...
Soft Version: V 04.13 Date: 16-05-06 Type: RM-70 (7370) Pack: (c) Nokia.
Product code: 0540014
Original IMEI: 351882-01-********
Production serial: CEF938931
HW Version: 6001
DSP Version: dsp_soho_05w32v20.1
LCD Version: SEIKO
APE ADSP Version:
SIMLock service: SIMLOCK SERVER VERSION 62 [040A0105071B]
Profile bits: 8000000000000000
Simlock config: 2600200000000000
Invalid codes entered: 0 / 0
Block: 1; Lock: 1; State: Closed; Data: 26002F
Security code: 23282
Pleasse fix this becouse for now can't unlock this phone with cyclone. I added PM backup maybe you see problem.
Old 05-17-2009, 08:30   #2 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,174
Tick SKIP SP INFO Reading
and Proceed Unlock then see what it says
Old 05-17-2009, 08:34   #3 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 469
But why not work read info ?? Why with old phone is problem ?? I unlocked phone with other box but I want to cyclone box fix problem !! !!
Old 05-17-2009, 08:46   #4 (permalink)
Member: 575900
Thanks Meter: 3,174
Will keep that Read INFO stuff in notice for next update
Old 05-17-2009, 08:48   #5 (permalink)
pethu's Avatar
Member: 345698
Thanks Meter: 46
plz check ur cable.open your cable and put 10k resister then do unlock. ur problem solved
Old 05-17-2009, 08:56   #6 (permalink)
Member: 575900
Thanks Meter: 3,174
cant say for cable problem least phone isin needed mode thats why iNFO is readed
Old 05-17-2009, 10:08   #7 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 469
Cabel is ok other box read phone ok and all time phone is in local mode like should be !! I not new in this bisnes and all time check cable and got working for every phones.
Old 05-17-2009, 10:30   #8 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,971
Always TRY to USE TMA ADOPTER if u got such error
that error are due to bad cable
BAD CABLE means not good fo cyclone box. different resistor value needed.
Old 05-17-2009, 10:50   #9 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 469
No this is not bad cable errror!! !! !!
I try to use UFC cable and try few resistror and all time the same then error is not from cable !! !! !! !! !! !! !! !! !! !! !! !! !! !! !!
Old 05-17-2009, 12:26   #10 (permalink)
Member: 575900
Thanks Meter: 3,174
i said above its not cable problem but some people wont Listen...
@wgmmmx
Mate a test read info with USB and see what it shows
Old 05-21-2009, 13:13   #11 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,683
If there is problem with parsing sp info, or sp is corrupted itself (may happen),
just tick "skip sp read" during unlock !!!
And your phone will be unlocked anyway, no matter what sp status is .
Best regards !!!!!!
Can't flash with cyclone box kaino147 Cyclonebox 3 09-19-2009 10:59
Help i can't unlock nokia e62 with cyclone box edi21ar Cyclonebox 5 07-25-2009 07:02
Can't Unlock and can't read flash my433v said4 SMTi 1 05-20-2009 04:54
n95 code read done with cyclone box bad attampts was 5 yasermalik Cyclonebox 6 04-27-2009 06:34
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box FullFLASHgSMPH Cyclonebox 2 04-13-2009 14:00
Page generated in 0.34253 seconds with 9 queries
