04-08-2013, 11:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: romania
Member: 492293 Status: Offline Thanks Meter: 324 | 8700 error (Solved) This is not Blackberry device, still waiting... New device attached, checking if it's Blackberry... Blackberry Found! PIN: 25001D22 "RIM CalTask" Channel open failed, Retrying... "RIM CalTask" Channel open failed, Trying "Caltask Config" ... Blackberry Read Failed -> No any useable channels can be opened! Device is password protected! Remove lock by entering 10 times "blackberry" when asked for passowrd. i hard reset....ufff pls help imei357646009927084 prd 09855-029 i need mep...pls help. |
04-08-2013, 22:16 | #4 (permalink) | |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Quote:
Br | |
The Following User Says Thank You to boucettay For This Useful Post: |
04-09-2013, 06:56 | #5 (permalink) |
Member: 492293 Status: Offline Thanks Meter: 324 | imei is ok 357646.00.992708.7 with *#06# prd 09855-029 BlackBerry 8700v Fcc ID: L6ARAT40GW the phone is ok i hard reset i reset pasword but not read mepp with cyclone... |
