| Junior Member
Member: 1659750
| after flash c3-01 imei corrupt 12345610654321? [Is a 5310 not a c3-01] when i flash c3-01 with cyclone box after flash imei number corrupt with this one 12345610654321?
any body help me about this problem how i can solve this.i repair imei but can't repair it.any solution????????????
flashing log... Quote:
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.1.923
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B0000911
Time: 2012, wk01 / 2011, wk27
Box is activated
Started box selftests procedure
USB Voltage 5.04v PASSED
MCU Voltage 3.27v PASSED
Core Voltage 1.79v PASSED
VBAT Voltage 0.03v PASSED
VBAT Voltage 4.97v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.97v PASSED
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 670.376MB
Avaiable Virtual Memory: 1.897GB
Avaiable Pagefile: 2.163GB
Initializing FBUS...
All initialized - Ready to work
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
[Nokia USB Flashing Generic]: Port opened OK!
Proceeding with Recovery Mode...
Booting CMT...
Old ROM Detected
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101013000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 24900004F164025432CD423786B9F17CD6B53752
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
transport
Recovery Mode Failed, storing Certificates Only
Booting CMT...
Old ROM Detected
CMT Ready!
transport
Failed to Create RPL from phone -> Failed to Boot / Prepare Phone
RPL backup thread finished, continuing...
Pre flash tasks finished, continuing...
Selecting USB Flashing Method...
Proceeding with Dead USB Mode
Press power-on shortly to run USB Boot ROM
Old ROM Detected
DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5
Sending RAW Loader...
Sending CMT UPDAPP Certificate and Data...
ADL Server Startup Failed -> Timeout, no any compatible USB device detected.
Failed to Process all Image files -> Failed to prepare BB5 USB Flashing
Booting CMT...
Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem
Prepare phone failed with message -> Failed to Boot CMT
Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone
Booting CMT...
CMT Ready!
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
If software STUCK HERE with box TX LED lit, that means:
USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00EC220C (Samsung), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
Warning: PAPUBKEYS Hash Missing!
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Backing up RPL...
Booting CMT...
CMT Ready!
Box VPP disabled
APE Subsystem Not Found
AM.NPC.CMT.crt"
Set to Recovery Mode Finished
Storing Product Code...
Storing PSN...
Storing HWID...
Trying to store Simlock...
Reading Configuration Key...
Hashing...
Reading SHA1-RSA Signature...
Reading SHA1-HMAC Signature...
Storing Simlock...
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
Reading Security Block...
AM.SecurityBlock.PM"
read it...
Reading CYC file from phone...
Booting CMT...
CMT Ready!
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Old Loader Detected
Readed OK, Saving to "24900004F164025432CD423786B9F17CD6B53752.B0000911 "
Storing Additional Data...
Checking Superdongle Key...
Encrypting Superdongle Key...
Storing Superdongle Key...
Checking CMLA Key...
Storing CMLA Key...
Booting CMT...
CMT Ready!
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
CMT PARTNERC Not Found
Restoring from Recovery Mode...
Restored from Recovery Mode OK
Restarting MCU...
RPL Saved OK
Processing rm303__58.58.mcusw (CMT)...
'Cyclone.exe'. Read of address 00000000
Failed to Process all Image files -> Failed to process rm303__58.58.mcusw
Booting CMT...
CMT Ready!
Box VPP disabled
