09-24-2009, 16:39 | #1 (permalink) | ||
No Life Poster Join Date: Sep 2005 Location: ๑۩۞۩&&
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | .:: Big problem with a 5200 ::. [SOLVED] i make full backup from CERTS and RPL From Phone. next write PM using sx4 auth.. this showed error..... and NOW show this info : Quote:
I try now this not write RPL... not write CERTS.. this is writter rpl log: Quote:
and my phone still shows imei 12345610654321? What I'm doing wrong? Last edited by moulnisky; 09-24-2009 at 19:01. | ||
09-24-2009, 16:59 | #2 (permalink) | |
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | FIXED or SOLVED !! Solution ! Write CERTS ( XXXXXXXXXXXX.NPC.CMT.crt ) Using TX2 adapter cable and Unchecking Use TX2 but !.. now phone start up.... show " Start up Phone without SIM card ? " Accept and pfffffffff power off !! Any Solution ¿ this log INFO : Quote:
09-24-2009, 17:10 | #3 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | I'am new on BB5, and I never see this probleme, maybe you can write all cert backup and full PM of phone and make a Selftest and post result for see, Best Regards, JAVA Good. |
09-24-2009, 18:05 | #4 (permalink) |
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | i enter PM + sx4 Auth.. NOw start up...acept.. show fly mode.. acept and pffffffffff now Show CONTACT SERVICE !!! Any solution ¿... remember is NOkia 5200 PS: I write 5200_RM-174_rpl using Other Box.. but not work. |
09-24-2009, 18:31 | #5 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Inside your Dreams
Member: 551782 Status: Offline Sonork: 001135666 Thanks Meter: 59 | First Re-edit your post title The problem is you not the cyclone software...... Solution is very simple.... Just re-write fresh copy of 5200 pm using sx4.... done. |
09-24-2009, 19:04 | #9 (permalink) |
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | PS: make this step: 1. Sx4 Auth 2. write FULL PM ( not check bypass) 3. Show error to write 225 field ( i remove this field) and re-write and ok. but..this show contact service.. |
09-24-2009, 19:09 | #10 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | go in the tab common/info, click on selftest and post the logs of the self test BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
09-24-2009, 19:09 | #11 (permalink) | |||
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | Quote:
SELFTEST only Show Quote:
09-24-2009, 19:21 | #13 (permalink) | |
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | Using Adptador cable.. the phone is power on .y not work without adaptador Run..but show this errror. Quote:
tx u | |
09-24-2009, 19:35 | #14 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | go in the tab bb5/flash and thick where says "skip repower boot" and retry BR Alex |
09-24-2009, 19:51 | #15 (permalink) | |
Look this Problem : 1. Write all lot and OK 2. Power On phone -> Start up phone withou SIM card -> Accept 3. Active Flight Profile ? 3.1. if select YES.. the phone Work Perfect ! cam ok, Game ok, all OK 3.2. if select NO .. the phone POWER OFF jejeje I never see this probleme, Any Solution¿ | |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
.:: BIG PROBLEM WITH Huawei Modem !! ::. | The_Dj | FuriousGold | 2 | 10-07-2009 16:53 |
.:: BIG PROBLEM WITH Huawei ::. | The_Dj | FuriousGold | 9 | 10-02-2009 22:38 |
big problems with my fg box [SOLVED] | GSM2MAROC | FuriousGold | 29 | 01-09-2009 21:22 |
big problem with 5200 | altamedia | Nokia Hardware & Hardware Repair | 1 | 03-20-2008 17:16 |
