Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #17 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Apr 2006
Member: 267789 Status: Offline Thanks: 3
| Facoly Moulnisky I tried several times unsuccessfully I think you want a good solution to problem Did you update the firmware of your box again? BR Alex how to give me the tutorial Just click on box maintance and afterward on the "spanner" for maintance box ![]() BR Alex This is the answer Box Maintenance procedure started at 00:09:25 Box Open Error -> Security problem #1 Box Maintenance Error -> No connection was established, or box is not in needed mode Before doing click on box maintance unplug the box and plug it again on the usb cable. BR Alex I tried several times unsuccessfully same error you showed the logs before or different? before AND different Did the software see the box or not? Last edited by moulnisky; 08-24-2009 at 23:47. |
| The Following User Says Thank You to facoly For This Useful Post: |
| | #20 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2004 Location: Valladolid-Spain
Member: 48936 Status: Online Thanks: 37
| Hi i have the same problem too, but when i execute cyclone from another location, for example where i have extract cyclone 7828nck, i run cyclone box main module from here, the soft detects the box in main mode and beguin the self test, but when i try to unlock, always error BB5 Unlock Failed -> Failed to Boot / Prepare Phone What is the problem? |
| The Following User Says Thank You to rmarratia For This Useful Post: |
| | #21 (permalink) |
| Finally solved. The problem was, after uninstall cyclone, donīt delete cyclone folder First uninstall cyclone. Second delete folder c:archivos de programa/cyclone after that, follow exactly instructions from here: *** Cyclone Box - Download - Installation - First Steps *** And now cyclone is working OK. |
| | #23 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2005 Age: 39
Member: 178616 Status: Offline Thanks: 126
| hi plz help me yesterday i upgrade my box to new active super dct4 .activate ok and used 50 credits and after that my box not connecting for rpl service and always give eror when check credits.... this error Cyclone Server Send Command Error -> Code: 500, Box is not registered, support is not allowed then Failed to Check Credits -> Server transaction failed plz help me how to solve this problem |
| | #24 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks: 701
| Quote:
| | #28 (permalink) |
| here are the instructions for your box step 1-uninstall the program and the pilot 2 - remove the core of your program file 3 - reinstall the program and drivers |
| | #29 (permalink) |
| | #30 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2005 Location: Ahmedabad,gujarat,india. Age: 41
Member: 173509 Status: Offline Sonork: 100.1584320 Thanks: 130
| hi supporter pls solve this,:::Initializing security card... Security Card Reset Error -> Possible error: Unknown error 0x4E Initialization has failed -> Security card was not found!"" i always get this error.when try for 10-15 times its start sometime.sometime after get info from the phone when try to flash suddenly it gives this error.i follow all instruction.now im tired with this box.i dont understand where is problem.so pls give me some accurate guideline to solve this problem. anyway thanx. br:shabbir-cellcare. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| problem with my cyclone box.box is not in needed mode | samih127 | Cyclonebox | 18 | 06-12-2010 06:05 |
| Box is not in needed mode [SOLVED] | renren | Cyclonebox | 2 | 01-19-2010 21:38 |
| ::solve:: box is not in needed mode | mr khalid | Cyclonebox | 6 | 09-15-2009 08:36 |
| Cyclone team (not connected) box is not in needed mode | tims | Cyclonebox | 17 | 06-29-2009 03:54 |
| Box is not in needed mode. | masterunlock | Cyclonebox | 5 | 03-24-2009 16:44 |
