Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 10-04-2009, 07:58   #31 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,176
Originally Posted by SAHEB View Post
hi supporter pls solve this,:::Initializing security card...
Security Card Reset Error -> Possible error: Unknown error 0x4E
Initialization has failed -> Security card was not found!""
i always get this error.when try for 10-15 times its start sometime.sometime after get info from the phone when try to flash suddenly it gives this error.i follow all instruction.now im tired with this box.i dont understand where is problem.so pls give me some accurate guideline to solve this problem.
anyway thanx.
br:shabbir-cellcare.
Check Your USB Cable Or Change It.
security card problem
Old 10-04-2009, 22:31   #32 (permalink)
nicacel's Avatar
Member: 111014
Thanks Meter: 132
I think my box is damaged
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918
Handling device: [Cyclone Team], [Cyclone Bootloader]
Initialization has failed -> No connection was established, or box is not in needed mode
Box was working great unlocking many nokia, now box cant even goes in boot mode, only in bootloader, I tried in different computer, I changed USB cable, I changed USB port, I did everything box cant go in boot mode, computer cant detect box, I checked in Hardware/device manager/ only bootloader..
After I click in DCT4 tab, box turn off that's all.\
Please help !!
Old 10-04-2009, 23:25   #33 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
@ Nicacel
Contact Mr. Siroya in Sonork : 100.58402 or ICQ : 176266002
Old 10-06-2009, 09:38   #34 (permalink)
Member: 603921
Thanks Meter: 71
cyclone always Initialization has failed -> No connection was established, or box is not in needed mode
ive done the procedures,, uninstall reinstall after that it will work,, the window will say in " main mode" then i unplug my box after a few minutes i plug it again den the window will say in bootloader mode,, again it won't connect,,, how is that,, where is the problem is it in the box,,
and one thing do i have to always plug the ac adaptor everytime i use the cyclone
Old 10-08-2009, 19:03   #35 (permalink)
Crazy Poster
Member: 801868
Sonork: EC84A74B
Thanks Meter: 3
please new link for cyclone box is not in needed mode
link is broken, please upload again
Originally Posted by NADEEM GONDAL View Post
Little Guide For new User.
Download Main Instaler
Download Mirror 0 : http://rapidshare.com/files/22831354...xInstaller.exe (TRAFFIC SHARE Download - download without logging into Rapidshare Premium zone, free - no wait and limits)
Download Mirror 1 : http://www.***************/downloads/...xInstaller.exe
After this
download the last update from here
http://rapidshare.com/files/24744090...one7828NCK.rar
And unzip all the files in the Cyclone folder (Normally c:\program files\Cyclone box) answering yes when asked to overwrite.
Conect your Box It will ask you For Driver
Install these Driver
After this now open cyclone Box From desktop Shortcut
Click DCT4/WD2/BB5
After this you need to Install Cyclone Box Driver
Other wise You Will See
After instaling These Driver
After These Steps You Can Use Your Box As Normal
If you Still Facing Any Problem The Cyclone Team And Other Expert Member Are Always Here For Your Help
Regards
Nadeem Gondal
The Following User Says Thank You to nowarno For This Useful Post:
Old 10-26-2009, 20:27   #36 (permalink)
Member: 389669
Sonork: 100.1583354
Thanks Meter: 226
hello me too today after update box i get box not in needed mode error, i update it 3 time but the same problem, also i change pc, usb, reinstall program, any help.
note: i get the same problem for ferst time i get my box, i correct it my self by hardware modification, but now i get the problem but the solution not work this time.
need help
Old 10-26-2009, 20:37   #37 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
@ mr khalid
You get this error because the First update fail.
When you update your box 2 updates are preformed : Security Area & Main Firmware
if there is a minor error in any of the 2 updates, you get an error....
The only way to solve this, is SEND PM to CYCLONEBOX, HONEY or SIROYA with your Box S/N an a description of your problem.
Otherwise you can try to udate your BOX 10000000000000000000 times and allways get an error..... so SEND PM and solve your problem....
The Following 2 Users Say Thank You to ptt For This Useful Post:
Old 10-27-2009, 12:44   #38 (permalink)
Member: 389669
Sonork: 100.1583354
Thanks Meter: 226
Originally Posted by ptt View Post
@ mr khalid
thanks sir i tray to pm siroya cyclone and hony if some off them connect.
great thanks to you.
The Following User Says Thank You to mr khalid For This Useful Post:
Old 10-27-2009, 13:02   #39 (permalink)
vampire13's Avatar
Member: 246444
Thanks Meter: 119
I have this problem after update
First Name: Indra
Surname: Gunawan
Nickname: Vampire13
Address: Jambi
Country: Indonesia
E-Mail: [email protected]
Reseller: SCPgsm, Indonesia
Warranty Start Date: 2009-07-13
Warranty Period (months): 6
Warranty Stop Date: 2010-01-13
Warranty active: Yes
Updating Security Area...
Security Area Update Skipped, Not allowed
Updating Main Firmware...
Main Firmware Update Skipped, Not allowed
Disconnected from Cyclone Server
Box Maintenance finished successfully
but not work when
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396
Many thanks
The Following User Says Thank You to vampire13 For This Useful Post:
Old 10-27-2009, 14:34   #40 (permalink)
Member: 182681
Same problem beguile
Old 10-27-2009, 18:29   #41 (permalink)
Member: 691872
Thanks Meter: 9
help
After this
Click DCT4/WD2/BB5
Regards
Nadeem Gondal
my box is not asking for the drive cyclone box only drive cyclone bootloader.
DCT4 when I click it all the lights and lock LEDs
The Following User Says Thank You to acessoriosecia For This Useful Post:
Old 10-27-2009, 18:30   #42 (permalink)
Member: 691872
Thanks Meter: 9
Old 10-27-2009, 20:01   #43 (permalink)
Member: 389669
Sonork: 100.1583354
Thanks Meter: 226
I connect Mr Siroya and they tell me to update box again, so I do, but same problem, please give a real solution,.
Old 10-28-2009, 03:22   #44 (permalink)
parengBok's Avatar
Member: 696820
Sonork: 100.1640853
Thanks Meter: 242
Lightbulb
perhaps this call must be brought to
the attention of the whole CYCLONE BOX team......
ive already done the same... ( w/c is to pm
siroya) likewise i got same reply from him...
He told me to update the box again..
but still no luck...
this scenario has a striking resemblance to what had
happen to my JAF box...
(there was one update released by jaf team
that spelled the doom of my box)..
same scene that happen with my cyclone box..
after update, the box couldnt no longer be
brought to main mode...
but im still looking forward for Cyclone Team
to do the fixing with this mess ( pardon me )..
a mess indeed for without cyclone box
repairing is somewhat impaired...
so PLEASE!! we need SOLUTION!! ASAP......
The Following User Says Thank You to parengBok For This Useful Post:
Old 10-28-2009, 16:21   #45 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,684
http://forum.gsmhosting.com/vbb/show...34#post4979234
Here is solution.
Upgrade your boxes.
The Following User Says Thank You to karwos For This Useful Post:
problem with my cyclone box.box is not in needed mode samih127 Cyclonebox 18 06-12-2010 06:05
Box is not in needed mode [SOLVED] renren Cyclonebox 2 01-19-2010 21:38
::solve:: box is not in needed mode mr khalid Cyclonebox 6 09-15-2009 08:36
Cyclone team (not connected) box is not in needed mode tims Cyclonebox 17 06-29-2009 03:54
Box is not in needed mode. masterunlock Cyclonebox 5 03-24-2009 16:44
Page generated in 0.47948 seconds with 9 queries
