Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 12-10-2012, 23:02   #631 (permalink)
Member: 1825436
Originally Posted by moulnisky View Post
Try again to use box wizard
Alex
Note: if still problems, please, uninstall libusb in control panel/application manager
dont work. i already install in another computer but the problem persist.
Old 12-10-2012, 23:31   #632 (permalink)
Member: 1825436
work now.
thank you.
Old 12-15-2012, 11:03   #633 (permalink)
Member: 1434775
help my cyclone stuck in bootloader mode
SN:C0006EE1
The Following User Says Thank You to bigbag69 For This Useful Post:
Old 12-23-2012, 10:51   #634 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
SN:C0006EE1
Pls try update box now, should be work.
Old 12-24-2012, 02:47   #635 (permalink)
Member: 1434775
thaks...
Initializing box...
Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0006EE1
HW Revision: B, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2009, wk23 / wk19
Initializing security card...
Card Serial Number: D00C0085
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.10v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 5.09v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 5.06v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 1017.60MB
Avaiable Virtual Memory: 1.845GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
Old 01-04-2013, 08:52   #636 (permalink)
Member: 770071
please help sir
sir my box stuck in bootloader mode..here is box service tag :
6191320B0C4CDFAB6A14F9E0CD7B4AAB
thanks a lot, hope you can help
best regards
Old 01-04-2013, 09:29   #637 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
best regards
You can update your box via box wizard.
Old 01-09-2013, 09:27   #638 (permalink)
Member: 310458
my box stuck in bootloader mode please help
Cyclone Box Service Tag: CD4AC4C087D3728BB61F0089E29576E9
The Following User Says Thank You to utuh For This Useful Post:
Old 01-09-2013, 10:17   #639 (permalink)
Member: 1051581
plz help my box stacking always bootloader mode and showing red light is try to different pc bt siltt same i update box but still same plz
Old 01-09-2013, 19:50   #640 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
You can use box wizard
The Following User Says Thank You to kaisak For This Useful Post:
Old 01-11-2013, 10:36   #641 (permalink)
niceraees's Avatar
Member: 354975
Sonork: Love For All
Card Serial Number: D2000093 plz help us
Old 01-11-2013, 11:30   #642 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
Pls use box wizard and update Your box.
Old 01-12-2013, 06:48   #643 (permalink)
niceraees's Avatar
Member: 354975
sir same problam i have update box butt still stuck in bootloader mode
Old 01-12-2013, 15:25   #644 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
Paste sn or service tag
Old 01-13-2013, 12:29   #645 (permalink)
niceraees's Avatar
Member: 354975
problem with my cyclone box.box is not in needed mode samih127 Cyclonebox 18 06-12-2010 06:05
Box is not in needed mode [SOLVED] renren Cyclonebox 2 01-19-2010 21:38
::solve:: box is not in needed mode mr khalid Cyclonebox 6 09-15-2009 08:36
Cyclone team (not connected) box is not in needed mode tims Cyclonebox 17 06-29-2009 03:54
Box is not in needed mode. masterunlock Cyclonebox 5 03-24-2009 16:44
Page generated in 0.88320 seconds with 12 queries
