Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 01-27-2013, 15:45   #661 (permalink)
Member: 1873657
please mee! my s/n C00081F4 servis tag; 257954A0B3F118C6EAD9F3D6D2F53F3E
Old 01-29-2013, 08:20   #662 (permalink)
Member: 310458
stuck in bootloader mode please help
Cyclone Box Service Tag: 198B633AE61150033C1CC668E0803CE5
Old 01-29-2013, 09:10   #663 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
Please us ebox wizard now
The Following User Says Thank You to kaisak For This Useful Post:
Old 01-29-2013, 09:12   #664 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
Please use box wizard now
Old 01-29-2013, 09:13   #665 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
Originally Posted by niceraees View Post
[IMG] Uploaded with ImageShack.us[/IMG]
this err thanks cyclone team
Dear when You get this error- Your's service tag should be automatic copy to clipboard, then only paste it there. We will help solve Yours problem.
Old 01-29-2013, 20:07   #666 (permalink)
Member: 1873657
Thank you very much! Never was problems. Good box!
Old 03-03-2013, 22:52   #667 (permalink)
Member: 1786653
Please help me, still not estabilished.
Cyclone Box Service Tag: CA74228C14D78D29663288FD1D48E6A2
Old 03-04-2013, 10:57   #668 (permalink)
kaisak's Avatar
Member: 209842
Sonork: 100.93537
pls try use now box wizard.
Old 03-05-2013, 03:05   #669 (permalink)
Member: 1786653
Thanks. Box oke now,
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:00, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B0000xxxx
HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27
Box is activated
Started box selftests procedure
USB Voltage	4.83v	PASSED
MCU Voltage	3.26v	PASSED
Core Voltage	1.77v	PASSED
VBAT Voltage	0.04v	PASSED
VBAT Voltage	4.78v	PASSED
Box VPP disabled
VPP Voltage	0.04v	PASSED
Internal Box VPP Enabled
VPP Voltage	4.83v	PASSED
Box VPP disabled
VPP Voltage	0.02v	PASSED
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 624.472MB
Avaiable Virtual Memory: 1.809GB
Avaiable Pagefile: 2.346GB
Initializing FBUS...
All initialized - Ready to work
Old 05-08-2013, 13:09   #670 (permalink)
Member: 623972
cyclone box not in needed mode solved 100% for me
if cyclone box gives error (BOX NOT IN NEEDED MODE )
then check at other PC its windows fault
i have the same error i uninstal and install again but problem remain same
i checked box at another PC, box is ok ,SAME SET UP ,SAME DRIVER,SAME USB CABLE ,EVEN SAME WINDOW
after then i install a new window xp3 ,problem solved
run set up and gives drivers path
C:\Program Files\Cyclone Box\Drivers
problems solved .thanks GSM hosting members .
The Following User Says Thank You to rakesh77448 For This Useful Post:
problem with my cyclone box.box is not in needed mode samih127 Cyclonebox 18 06-12-2010 06:05
Box is not in needed mode [SOLVED] renren Cyclonebox 2 01-19-2010 21:38
::solve:: box is not in needed mode mr khalid Cyclonebox 6 09-15-2009 08:36
Cyclone team (not connected) box is not in needed mode tims Cyclonebox 17 06-29-2009 03:54
Box is not in needed mode. masterunlock Cyclonebox 5 03-24-2009 16:44
Page generated in 0.28685 seconds with 12 queries
