Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 11-04-2009, 13:49   #61 (permalink)
Member: 158999
Originally Posted by SiRoYa View Post
pm me ur box sn ................
Box Maintenance procedure started at 01:39:51 p.m.
Handling device: [Cyclone Team], [Cyclone Bootloader]
Bootloader: Cyclone Secure Bootloader v2.08, (Nov 14 2008 12:05:50), Type: Signed Production Application, For HW Rev E
Service Tag: 946724BC9F69AC845025D58A2D339224
Connecting to Cyclone Server
Cyclone Server (1.0.0.485), Cyclone Box Team 2008, 2009 - Ready.
========= Box Info =========
Box SN: C0000ABE
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27
Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty
Box registration status: Registered OK
Paired Card SN: D0000492
First Name: DAVID
Surname: FLOREZ
Nickname: JUSTINCEL
Address: CC.FEDECAFE
Country: COLOMBIA
E-Mail: JUSTINCEL@HOTMAIL.COM
Reseller: JustinCell, Colombia
Warranty Start Date: 2009-05-19
Warranty Period (months): 6
Warranty Stop Date: 2009-11-19
Warranty active: Yes
Updating Security Area...
Security Area Update Skipped, Not allowed
Updating Main Firmware...
Main Firmware Update Skipped, Not allowed
Disconnected from Cyclone Server
Box Maintenance finished successfully
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918
Initialization has failed -> No connection was established, or box is not in needed mode
Old 11-04-2009, 14:07   #62 (permalink)
guedes666's Avatar
Member: 108180
Sonork: 100.106866
The Following User Says Thank You to guedes666 For This Useful Post:
Old 11-05-2009, 18:21   #63 (permalink)
Member: 1107652
is maintained after usb disconnect box
Wait 3 to 5 min.volta to call your clicks
dct4/wd2/bb5 was in so I did several times and it works.
Tuareg:
Old 11-05-2009, 18:23   #64 (permalink)
Member: 1107652
* is maintained after usb disconnect box
Tuareg:
Old 11-06-2009, 03:48   #65 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Who has firmware problems can now update it again to the new version 1.0A
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 11-06-2009, 08:25   #66 (permalink)
Member: 700535
Problem solved with the new update. Thank you very much Siroya for your help!!
Good support
Regards
Old 11-09-2009, 00:29   #67 (permalink)
Member: 138423
Problem Whit Box
I have BOX but today conect and can't detec for software i see in the BOX only turn on TX LED (Yellow) and not detec please help me
Old 11-09-2009, 01:04   #68 (permalink)
ptt
ptt's Avatar
Member: 348680
@ henrynicolas
Read the Cyclonebox post about 06-11-2009 FW release
06-11-2009 New Cyclonebox Firmware Released
Firmware 01.0A LEDs Meaning upon Main Firmware startup
GREEN, BLUE, RED, ORANGE Firmware Starting - Initializing Interrupts
and PLL Clocks (at this stage check 12MHZ Crystals)
GREEN, RED, ORANGE Initializing HW Modules, RTC (at this stage check RTC Clock)
RED, ORANGE Doing Security Checkup (Should not hang here)
ORANGE Initializing USB Stack (Check crystals, USB Cable Length, etc)
NO LEDS Firmware Booted
Old 11-09-2009, 17:42   #69 (permalink)
Member: 730412
I have install the new software and update i cant connect???
Box Maintenance procedure started at 18:39:23
Service Tag: 6878DFD9039DD0F9A2850CF11D985A66
Cyclone Server Send Command Error -> Code: 500, SQL Error: MySQL server has gone away
Box Maintenance Error -> Server command send error
Old 11-09-2009, 17:44   #70 (permalink)
ptt
ptt's Avatar
Member: 348680
@ shubox112
Server down, try again later....
Old 11-09-2009, 17:56   #71 (permalink)
Member: 730412
I have now this problem it whont connect
Old 11-09-2009, 18:05   #72 (permalink)
ptt
ptt's Avatar
Member: 348680
Unplug your box and replug, and go to Box maintenance and try to update your box FW.
Old 11-09-2009, 18:07   #73 (permalink)
Member: 730412
Started card reading procedure at 19:06:30
Card reading error -> No connection was established, or box is not in needed mode
I have already update the firmware
Old 11-09-2009, 18:17   #74 (permalink)
ptt
ptt's Avatar
Member: 348680
have you reinstalled, the Software and the Box Drivers ? Your Box FW is the 1.1A ? When you plug the box, any led remain ON ?
Old 11-09-2009, 18:19   #75 (permalink)
Member: 730412
yeah it is on and then go off. Before update everthing working ok and now not. Ihave few mobiles to unlock
problem with my cyclone box.box is not in needed mode samih127 Cyclonebox 18 06-12-2010 06:05
Box is not in needed mode [SOLVED] renren Cyclonebox 2 01-19-2010 21:38
::solve:: box is not in needed mode mr khalid Cyclonebox 6 09-15-2009 08:36
Cyclone team (not connected) box is not in needed mode tims Cyclonebox 17 06-29-2009 03:54
Box is not in needed mode. masterunlock Cyclonebox 5 03-24-2009 16:44
Page generated in 0.45935 seconds with 12 queries
