Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 09-14-2009, 11:35   #31 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
@ q_ilabo_t
Hi, here you answer:
http://forum.gsmhosting.com/vbb/show...37&postcount=1 " 3- VBAT Supply test fail "
and make sure you don t have conected anyting to "Service port" when you start the software
Old 09-18-2009, 05:23   #32 (permalink)
Member: 1121952
hi all, i'm a newbie here,
can i know how to check the problem "vbatt Supply test fail"?
where to check?
any picture can post here how to check?
thanks!!!
Old 09-18-2009, 12:13   #33 (permalink)
ZoHaiB_(FoneGSM)'s Avatar
Member: 82666
Sonork: 100.108210
Thanks Meter: 284
Question Cyclone Support Check This Problem with YOUR NEW Boxes
what about this problem got new BOX
Register OK
after that
BOX Maintenance OK
Now if open Software you can USE only BOX Maintenance Option work profect check Pic
and if click on DCT4/WD2/BB5 BOX alway's give this msg
Initialization has failed -> No connection was established, or box is not in needed mode
reconnect Box
restart Pc
reinstall sw
Change USB cable
Change Port
change PC
what to Do.
not only one facing this problem this is my 3rd Box same ERROR
any other Box work fine on same port
Old 09-18-2009, 12:18   #34 (permalink)
Member: 82666
Sonork: 100.108210
Thanks Meter: 284
Old 09-18-2009, 12:35   #35 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
Unplug And Plug Again IF same Then Here is Little Help.
http://forum.gsmhosting.com/vbb/showthread.php?t=797559
Old 09-18-2009, 12:43   #36 (permalink)
Member: 82666
Sonork: 100.108210
Thanks Meter: 284
read carefully Bro
reconnect Box
restart Pc
reinstall sw
Change USB cable
Change Port
change PC
what to Do.
already done those Step you hav'nt check Pic if any problem with driver then How came Box MAINTANENCE work fine every time Only other Option not see some more Pic
in bottom it's show box connected
same if read creadts
same shows box connected but ERROR same
Old 09-18-2009, 13:06   #37 (permalink)
Member: 575900
Thanks Meter: 3,177
For Maintenance Box Need only Boot loader Mode And For Other Operation Need Main Mode ,And If You Dont Install Driver of Main mode So Always Face Error.
Old 09-18-2009, 13:14   #38 (permalink)
senkron24's Avatar
Member: 15880
Sonork: 100.1612155
Thanks Meter: 452
Originally Posted by infozohaib View Post
read carefully Bro
reconnect Box
restart Pc
reinstall sw
Change USB cable
Change Port
change PC
what to Do.
i think you have driver problem pls remove driver and instal again
b.r
senkron24
Old 09-18-2009, 13:46   #39 (permalink)
Member: 82666
Sonork: 100.108210
Thanks Meter: 284
Unhappy
b.r
senkron24
try to reinstalled sw and drivers still same problem
driver reinstalled problem still same
Old 09-18-2009, 17:17   #40 (permalink)
Member: 82666
Sonork: 100.108210
Thanks Meter: 284
Angry
where is Cyclone team to sort-Out this Problem
Old 09-18-2009, 18:58   #41 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Register OK
after that
BOX Maintenance OK
reconnect Box
restart Pc
reinstall sw
Change USB cable
Change Port
change PC
what to Do.
Try to contact Mr. Siroya in Sonork : 100.58402 or ICQ : 176266002 maybe he can guide you to solve your problem.
Old 09-18-2009, 22:06   #42 (permalink)
Member: 82666
Sonork: 100.108210
Thanks Meter: 284
Authenthication error -> No connection was established, or box is not in needed mode
how many pc i have to try now tell us Cyclone team ............ what's this
Old 09-18-2009, 22:21   #43 (permalink)
Member: 82666
Sonork: 100.108210
Thanks Meter: 284
when you click any option like
refill card
credits
DCT4/WD2/BB5
Box just try to connect in MAIN MODE but nothing happend and shown this msg
Old 09-18-2009, 23:18   #44 (permalink)
Member: 82666
Sonork: 100.108210
Thanks Meter: 284
Wink Problem Solved Credit goes to MR. SiRoYa
Problem Solved Credit goes to MR. SiRoYa for Great Support and Help
great work SiRoYa
really appreciated
Thanks
Old 09-18-2009, 23:28   #45 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
great work SiRoYa
really appreciated
Thanks
Glad to see you solve your problem.... i tell you to contact Mr. Siroya...
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range kosta25 Cyclonebox 2 11-04-2009 13:40
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range azad4u Cyclonebox 7 07-08-2009 14:48
just got box, dont know what to do masterunlocking VygisToolbox 2 11-11-2007 17:36
6280 flashing failed! what to do? rakhpai Universalbox 2 08-10-2006 18:33
Page generated in 0.23660 seconds with 10 queries
