Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 08-25-2009, 00:46   #1 (permalink)
ptt
ptt's Avatar
Member: 348680
Exclamation Box Selftests Fail, What to do....
For those who have Box Selftests Fail Warnings, a litle guide....
1- Normal result of Selftests ( box is OK nothing to worry )
USB Voltage 4.94v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 4.91v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.86v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED -
Probably power supply is not connected
( nothing to worry,
this error is because the external VPP power supply is not conected )
2- VPP Supply Voltage test failed
Box Selftests Failed -> VPP Supply Voltage test failed,
1.25v is out of valid range
In this case, contact your reseller for Box exchange
3- VBAT Supply test fail
VBAT Voltage 0,01v PASSED
Box Selftests Failed -> VBAT Supply Voltage test failed,
0,03v is out of valid range
In this case you have to check ( with a multimeter )
if you have the correct voltage at F-Bus Battery contacts....
or if using an Unifbus, between red an black clips
( normal values are close to USB Voltage )
If dont get voltage or this is very low ( 0.03V,1.2V, 1.5V 2.4V, etc),
then you must contact your reseller for Box Exchange.
For more info, Use Search, Read sticky posts, there is alot of info already posted....
The Following 7 Users Say Thank You to ptt For This Useful Post:
Old 08-25-2009, 13:44   #2 (permalink)
sameenshah123's Avatar
Member: 619308
Sonork: 100.1591829
this is my error. and bought from *************. and to that box back its cost me too much. i already paid 146 for box and 100 usd from delivery. is there any easy way to fix this problem
Old 08-25-2009, 19:13   #3 (permalink)
ptt
ptt's Avatar
Member: 348680
@ sameenshah123
read here how VPP works:
*** Cyclone Box and VPP thing ***
Here an easy way to check VPP:
Product supporter, please see this error.
If your box is ones with the old HW, as mine (using LM1950T)
http://img91.imageshack.us/img91/4992/04012009062.jpg
http://forum.gsmhosting.com/vbb/atta...3&d=1245914162
you can tray resolder U5 ( LM1950T )
if this dont solve the problem, then you need to change the U5... you can remove U4 (used for switch ext VPP) and use it to replace U5, doing this you recover the Internal Box VPP function, and loose the ext VPP function...
The Following User Says Thank You to ptt For This Useful Post:
Old 08-25-2009, 19:39   #4 (permalink)
Member: 619308
Sonork: 100.1591829
witch box hardware is better old or new. man i am in big trouble coz i am not got to fix hardware.
Old 08-25-2009, 19:58   #5 (permalink)
ptt
ptt's Avatar
Member: 348680
I think there is at least 3 diferent HW versions, the first with LM1950T ( i have this ), the second with CS8240, and the third with LM3526H.... i cant say which is better as i only have 1....
If you dont have the skill to do the tests posted, then better contact reseller, or Mr. Cyclonebox ( see this post )
Attention! Not connect power supply with more than 5.5V to the EXT VPP Socket !!
The Following 2 Users Say Thank You to ptt For This Useful Post:
Old 08-26-2009, 19:24   #6 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks ptt for your superb suppport !
The Following 2 Users Say Thank You to karwos For This Useful Post:
Old 08-26-2009, 20:12   #7 (permalink)
Member: 619308
Sonork: 100.1591829
man today i open my box and i saw its have LM3526H should i change these 2 ice. coz i cyclone can read phone when conect cable direct to box without tx2 adapter. but with adapter its dont detect. and box self test fail.and some time box self test ok. i can flash dct4 phone and unlcok and as well bb5 unlock but not flash. plz tell me sould i change these 2 ice. and i cant get (LM3526H) i found uc3526h) is it ok to replace with this ic. ?
Old 08-26-2009, 20:19   #8 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Better check your adapter solderings, if you conncet directly to box and it works that means your box hardware is perefect
Old 08-26-2009, 21:11   #9 (permalink)
Member: 21937
well , mine all tests are o.k
thought im getting error when tma adapter conected to box with usb power ,then i get error . if i disconect the usb power , then all tests going fine ...
ideas ?
Old 08-26-2009, 21:21   #10 (permalink)
Member: 619308
Sonork: 100.1591829
i also open tx2 adapter. there 10 soldring point. and all sold well. i was also suspecting problem should be in adapter. can u plz give any hint or trick that i check adapter. i mean how to check adapter. if solding is ok. what wire to check with meter. i am that good in hard ware. plz sugestion ?
Old 08-26-2009, 22:23   #11 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
ideas ?
It is a little "hole" in the project of the tma adapter 1.1. The usb cable is connected to the Pin 1 of the adapter (Vbatt); if you connect the TMA to the box and you start the program, the self test check all the configurations; one of the test is the Vbat .. test one Vbatt must be about 5 V if needed and this test pass.. second part is Vbatt must be 0 if needed but whatever the box sto giving power to the vbatt the test read 5 Volts coming from the adapter USB cable to the pin1 and you get the error. was enaugh one diode on the pin 1 to prevent this error..
Obviously this error doesn't happen with the tma evolution.
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 08-29-2009, 07:00   #12 (permalink)
Member: 84525
Sonork: 100.1586310
Mr Ptt
i have this problem
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.06, (Aug  8 2009 17:54:19, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: Revised
Box Serial Number: 00000
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: Unknown
Initializing security card...
Card Serial Number: 00000
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage	4.95v	PASSED
Core Voltage	1.76v	PASSED
VBAT Voltage	3.39v	PASSED
Box Selftests Failed -> VBAT Supply Voltage test failed, 3.39v is out of valid range
Initializing FBUS...
All initialized - Ready to work
and same times give me this
[/CODE]Started box selftests procedure
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.42v is out of valid range
All initialized - Ready to work[/CODE]
What can i do to fix this problem
Old 08-29-2009, 11:30   #13 (permalink)
ptt
ptt's Avatar
Member: 348680
You get the error when start the soft with cable conected to Service socket ? Is better to start the software without cable conected at Service port.
If the error produces randomly, you can verify if the voltage at VBAT terminals of FBUS cable is correct ( if box say 3.39V and you get near 4.8V then is calibartion resistors, and is not to worry about )
If you get the voltages that Box say in box selftests, then maybe you have bad solders at IC which manages VBAT...
Old 08-29-2009, 14:21   #14 (permalink)
Member: 498158
hello , here with my box only green light is on , nothing no reaction
Old 08-29-2009, 22:46   #15 (permalink)
ptt
ptt's Avatar
Member: 348680
@ deal1975
Hi, the green led remains ON, and nothing more hapens ? PC detects Box and ask for drivers ? If the PC cant detect your box i think you need contact your reseller for Box Exchange....
I sugest you, open a new thread regarding your problem, here we are talking about "Box Seltests Fail" problem...
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range kosta25 Cyclonebox 2 11-04-2009 12:40
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range azad4u Cyclonebox 7 07-08-2009 14:48
just got box, dont know what to do masterunlocking VygisToolbox 2 11-11-2007 16:36
6280 flashing failed! what to do? rakhpai Universalbox 2 08-10-2006 18:33
Page generated in 0.24263 seconds with 12 queries
