Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 10-04-2009, 22:57   #46 (permalink)
nicacel's Avatar
Member: 111014
Originally Posted by infozohaib View Post
Problem Solved Credit goes to MR. SiRoYa for Great Support and Help
great work SiRoYa
really appreciated
Thanks
How did u fix this problem? I have exact same problem like u had. Please help me fix box. I did everything like you. and cant find the way make box to go in main boot.
My box was working perfect before. Today after unlock 3 pcs nokia, then I close software then opened again, then cant go in main boot
Old 10-04-2009, 23:24   #47 (permalink)
ptt
ptt's Avatar
Member: 348680
@ nicacel
Contact Mr. Siroya in Sonork : 100.58402 or ICQ : 176266002
Old 10-05-2009, 17:19   #48 (permalink)
nicacel's Avatar
Member: 111014
Originally Posted by ptt View Post
@ nicacel
Can you tell to Siroya to add me to sonork 100.87753 Im getting problem in findin and addin him, I get not allowed please thanks in advance
Old 10-05-2009, 18:07   #49 (permalink)
nicacel's Avatar
Member: 111014
Sonork access denied when I try to add siroya
Old 10-05-2009, 21:36   #50 (permalink)
ptt
ptt's Avatar
Member: 348680
Really strange, i have in sonork and icq contacts without problem. try Yahoo: mashriq_soft
( i drop msj in sonork to mr. Siroya with your post link )
Old 10-06-2009, 13:18   #51 (permalink)
nicacel's Avatar
Member: 111014
@ptt,
I could connecto ICQ, I added SiRoYa, he's always offline, I dont know what time he can go online, please I need help, Im loosing many customers.
Old 10-06-2009, 14:41   #52 (permalink)
ptt
ptt's Avatar
Member: 348680
Try with mr Cyclonebox or mr Honey in Sonork & ICQ ( send PM too )
The Following User Says Thank You to ptt For This Useful Post:
Old 10-12-2009, 17:46   #53 (permalink)
nicacel's Avatar
Member: 111014
@ptt, @SiRoYa,
Thanks finally SiRoYa helped me to fix my cyclone box, now is working fine thanks a millions !
The Following User Says Thank You to nicacel For This Useful Post:
Old 10-12-2009, 18:53   #54 (permalink)
nazeera's Avatar
Member: 433359
Sonork: 100.1573487
check the box
u will check the box with software ,u flashed the mobile with fbus and also usb.
Old 10-13-2009, 15:46   #55 (permalink)
nicacel's Avatar
Member: 111014
????? what are you talking about?
Old 10-14-2009, 18:13   #56 (permalink)
Member: 254187
hello Ihave a probleme with my cyclone box...?!!
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4,81v PASSED
MCU Voltage 3,29v PASSED
Core Voltage 1,78v PASSED
Box Selftests Failed -> VBAT Supply Voltage test failed, 4,00v is out of valid range
Super DCT4 Activation: FALSE
Old 10-14-2009, 18:16   #57 (permalink)
ptt
ptt's Avatar
Member: 348680
@ Cher
Start reading this thread from the first post and you find your answer, and solution to your problem
Old 11-15-2009, 19:45   #58 (permalink)
ReyTech's Avatar
Member: 135945
@ Cher
@ptt
can u tell me is this error fine or i have to replace box? error image attached for your reference!
WBR
ReyTech.
Old 11-15-2009, 20:00   #59 (permalink)
ptt
ptt's Avatar
Member: 348680
@ ReyTech
Read: " 3- VBAT Supply test fail " of the Post #1 of this thread
Old 11-16-2009, 00:37   #60 (permalink)
Registered User
to_deal_with's Avatar
Member: 19168
And what could be the solution to this?
Box Selftests Failed -> VPP Supply Voltage test failed, 0,81v is out of valid range
The box is not used.
thanks in advance
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range kosta25 Cyclonebox 2 11-04-2009 12:40
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range azad4u Cyclonebox 7 07-08-2009 14:48
just got box, dont know what to do masterunlocking VygisToolbox 2 11-11-2007 16:36
6280 flashing failed! what to do? rakhpai Universalbox 2 08-10-2006 18:33
Page generated in 0.20455 seconds with 12 queries
