Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 11-16-2009, 00:43   #61 (permalink)
ptt
ptt's Avatar
Member: 348680
Originally Posted by to_deal_with View Post
And what could be the solution to this?
Box Selftests Failed -> VPP Supply Voltage test failed, 0,81v is out of valid range
The box is not used.
thanks in advance
Your answer in post #1 & #3 of this thread
Old 11-18-2009, 08:05   #62 (permalink)
atoxpert's Avatar
Member: 762728
Sonork: 100.1587901
USB Voltage 5.22v PASSED
Box Selftests Failed -> MCU Supply Voltage test failed, 2.41v is out of valid range
Initializing FBUS...
All initialized - Ready to work
br
how to solve
pls answer
Old 11-18-2009, 10:17   #63 (permalink)
ptt
ptt's Avatar
Member: 348680
Originally Posted by ++ato++ View Post
br
how to solve
pls answer
Check LM3940 ( 3,3V voltaje reg. IC ).
Is the Box working ? Can you work with phones ?
The Following User Says Thank You to ptt For This Useful Post:
Old 12-05-2009, 09:56   #64 (permalink)
digitalgsm_cora's Avatar
Member: 727888
Sonork: digitalgsm
Exclamation Big problem CYCLONE!
The box is brand new instalation is ok, but i get this error:
Started box selftests procedure
USB Voltage 5.07v PASSED
MCU Voltage 3.30v PASSED
Core Voltage 1.78v PASSED
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.20v is out of valid range
Super DCT4 Activation: FALSE
Please help what should i do Return box to resseller?
B.R.
Old 12-05-2009, 10:23   #65 (permalink)
ptt
ptt's Avatar
Member: 348680
B.R.
Read the First post of this thread..... your answer is in that post...
Old 12-05-2009, 11:05   #66 (permalink)
Member: 727888
Sonork: digitalgsm
I guess my answer is in 2 POINT of first post that means i have to proceed to exchange my box!
I'm i right?
B.R.
Old 12-05-2009, 11:38   #67 (permalink)
ptt
ptt's Avatar
Member: 348680
@ digitalgsm_cora
Conect an F-Bus cable to the box, and check the voltage at battery terminals
if voltage is 4.2V, contact your reseller, and ask permission to open the box to see if is a bad solder problem
if voltage is 4.8V or more (near to USB voltage ), your box is Ok
Old 12-06-2009, 09:47   #68 (permalink)
Member: 727888
Sonork: digitalgsm
Bro i have 4.35V What should i do in this situation?
Box working fine....
B.R.
Old 12-06-2009, 17:44   #69 (permalink)
Member: 727888
Sonork: digitalgsm
Please could u tell me if everything is ok?
Is dangerous to use box like that? Can do any harm of phones or box can be damage?
For me is a big black ball for Cyclone box because box is new and it comes with such problems.....
I really don't undestand...
Please one supporter member of CYCLONE reply
B.R.
Old 12-06-2009, 21:54   #70 (permalink)
ptt
ptt's Avatar
Member: 348680
Contact your reseller to solve your problem.
Old 01-01-2010, 06:10   #71 (permalink)
javish's Avatar
Member: 535130
Originally Posted by hasnain View Post
For those ho have Box Selftests Fail Warnings, a little guide....
1- Normal result of Selftests ( box is OK nothing to worry )
USB Voltage 4.94v PASSED
MCU Voltage 3.28v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 4.91v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.86v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED -
Probably power supply is not connected
( nothing to worry,
this error is because the external VPP power supply is not conected )
2- VPP Supply Voltage test failed
1.25v is out of valid range
In this case, contact your reseller for Box exchange
3- VBAT Supply test fail
VBAT Voltage 0,01v PASSED
0,03v is out of valid range
In this case you have to check ( with a multimeter )
if you have the correct voltage at F-Bus Battery contacts....
or if using an Unifbus, between red an black clips
( normal values are close to USB Voltage )
If dont get voltage or this is very low ( 0.03V,1.2V, 1.5V 2.4V, etc),
then you must contact your reseller for Box Exchange.
Original post by PTT
HERE IS MY BOX LOG
USB Voltage 5.00v PASSED
Core Voltage 1.79v PASSED
VBAT Voltage 4.93v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Box Selftests Failed -> VPP Supply Voltage test failed, 0.98v is out of valid range
Super DCT4 Activation: TRUE
what should i do? I cant sent to reseler( to far from my place)
Old 01-01-2010, 15:32   #72 (permalink)
ptt
ptt's Avatar
Member: 348680
If you cant send back your box , for exchange / repair under warranty you can repair your box if you have some knowledge in electronics.
But if open the box you lose your warranty.
Start for reading this thread from the first post, then, post your doubts here....
Old 01-08-2010, 12:58   #73 (permalink)
Member: 191749
I'm sorry but...
I'm sorry but don't understand...my box show on tab DCT4/BB5 always on SELF TEST "VPP Voltage 0.04v FAILED - IGNORED -
Probably power supply is not connected"
WITH or WITHOUT power supply.
It's ok or not?
Old 01-08-2010, 13:13   #74 (permalink)
ptt
ptt's Avatar
Member: 348680
@ Matei
Which power supply you conected ? voltage ? polarity ?
Old 01-08-2010, 13:37   #75 (permalink)
leroi's Avatar
Member: 107916
Cyclone box faulty
ear SIr
i can not used any more my Cyclone box when try to open soft i have this MSG
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8155
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v01.0C, (Nov 25 2009 03:18:28, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application
Box Serial Number: xxxxxxx
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06
Initializing security card...
Card Serial Number: xxxxx
Card Firmware Revision: xxxx
Card is activated
Box is not activated (0A)
ADC Selftest Initialization Failed -> ADC Initialization Failed
Box Selftests Failed -> Failed to initalize box ADC subsystem
Initialization has failed -> Failed to initialize FBUS subsystem
before this box was working fine before
here is the log file register
CYCLONE_BOX_RECOVERY_DATA]
BOX_SN=xxxxx
BOX_HW_REV=A112
CARD_ATR=3BFA1300008131FE4xxxxx4F5034315632323196
CARD_SN=xxxxx
CARD_FW=xxx
BOX_ACTIVATION_STATUS=0A
BOX_SERVICE_TAG=FC35BFxxxxxx6769FE4BD7AEB7DC
CARD_PRIVATE_ID=33D2EBCBDxxxxC6A52C3E87983B2BEEE35 4F0D
CARD_PUBLIC_ID=4BDA404E74xxxxxx0D1F972B64403C360B0 1C19
BOX_PUBLIC_ID=1E00DE2E89xxxxx3755886F600F0DF19B288 AE1
BOX_PRIVATE_ID=2266E1B0711A6DF33xxxxx81F27
also i can log send PM to you
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range kosta25 Cyclonebox 2 11-04-2009 12:40
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range azad4u Cyclonebox 7 07-08-2009 14:48
just got box, dont know what to do masterunlocking VygisToolbox 2 11-11-2007 16:36
6280 flashing failed! what to do? rakhpai Universalbox 2 08-10-2006 18:33
Page generated in 0.39006 seconds with 12 queries
