01-09-2010, 18:31 | #77 (permalink) | |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | Quote:
01-11-2010, 19:53 | #79 (permalink) |
Major Poster Join Date: Oct 2005
Member: 191749 Status: Offline Thanks Meter: 2 | @ptt - First I use 5v external power supply. After that 9V external power supply. Same message to both tries "VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected" . jack polarity : + int - ext. Till now I unlock 2600c, 5000 and N73. So I don't know... it's ok or not. |
01-11-2010, 20:06 | #80 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | VPP is not involved in the unlock operation, it is used to increase speed of the flash / erase in some phones... read this thread about VPP: http://forum.gsmhosting.com/vbb/showthread.php?t=705261 BR |
01-13-2010, 17:30 | #81 (permalink) |
Insane Poster Join Date: Nov 2009
Member: 1152552 Status: Offline Sonork: 100.1619432 Thanks Meter: 4 | Box Selftests Failed -> VPP Supply Voltage test failed, 0.58v is out of valid range sometimes 0.62v i use it and is working fine. my reseller is in uk and i am in southern africa(zimbabwe). how can i solve this problem. pliz include diagrams in solution |
01-13-2010, 22:03 | #82 (permalink) | |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Quote:
BR | |
01-20-2010, 13:36 | #83 (permalink) |
No Life Poster Join Date: Jul 2001 Location: PT
Member: 5550 Status: Offline Thanks Meter: 18 | hello and how about this error: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8155 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.15, (Jan 2 2010 03:59:40, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application Box Serial Number: HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,66v PASSED MCU Voltage 3,29v PASSED Box Selftests Failed -> Core Supply Voltage test failed, 1,64v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work what should i do? |
01-20-2010, 14:41 | #84 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | @ UnlockerPT Can you work with phones ? Read Info, check flash bus, read PM.... ? Te "normal" value of Core Voltage is ~ 1,8 V ( but the AT32UC3A Core Power Supply can be 1.65V to 1.95 V ) If you can work with the box, maybe is a problem with "calibration resistors" and it is nothing to worry about. You are using the soft version with "bug", please install the Stable release or at least the Hotfix stable installer 1.04 http://www.***************/downloads/...xInstaller.exe hotfix http://www.***************/downloads/Cyclone.zip do some tests and post results BR |
01-20-2010, 15:24 | #86 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Then is only "calibration resistors", dont worry I see your USB voltage 4.66V are you using a USB Hub ? try in other PC and see if get the error BR |
01-20-2010, 16:01 | #87 (permalink) |
Member: 5550 Status: Offline Thanks Meter: 18 | hello this box is connected to a pci adaptor with 4 usbs... like allways i've tried now with the box connected to the MB usb and this is the result: USB Voltage 4,67v PASSED MCU Voltage 3,30v PASSED Box Selftests Failed -> Core Supply Voltage test failed, 1,65v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work about this "calibration resistors". what should i do/change to fix this? |
01-20-2010, 16:11 | #88 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Check if the USB voltage is near to 4.67V , if yes, then your "problem" is related to PC USB port low voltage, if its near to 5V ( ~4.8V - 5V ), then maybe a USB bad quality cable or box calibration resistor problems. Check your PC 5V and 5V Stand-By voltage if is calibration resistors problem, you dont need to fix anything, they only used in the box selftest, and not afect the normal use of the box. BR |
01-27-2010, 05:19 | #90 (permalink) |
Temporary banned !! Join Date: Nov 2009 Location: P.H Age: 38
Member: 1151970 Status: Offline Sonork: 100.1597000 Thanks Meter: 378 | USB Voltage 5.14v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.81v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.04v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range | kosta25 | Cyclonebox | 2 | 11-04-2009 13:40 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range | azad4u | Cyclonebox | 7 | 07-08-2009 14:48 |
just got box, dont know what to do | masterunlocking | VygisToolbox | 2 | 11-11-2007 17:36 |
6280 flashing failed! what to do? | rakhpai | Universalbox | 2 | 08-10-2006 18:33 |
