Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 11-10-2012, 23:44   #1 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 169
C5-00 RM-645 phone startup failed contact retailer solution
Hi to all
Here is solution for C5-00 RM-645 phone startup failed contact retailer
flash your set without rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
if you have not damege IMEI it means you have only simlock damege and
IMEI is ok
Here is log
Thats' all
regards
Old 11-11-2012, 01:27   #2 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 680
what do u mean if sim lock damege after flash ok ????????????????
Old 11-11-2012, 01:54   #3 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 169
c5-00
Hi
means that when I did self test I have only sim lock data correpted and good
IMEI and phone startup failed contact retailer I did what should to slove phone
startup failed SD Repair Procedure
All files processed OK!
MCU Version V ICPR82_11w16.4
MCU Date 02-06-11
Product RM-645 (Nokia C5)
Manufacturer (c) Nokia
IMEI 353792041778338
Mastercode 7563536731
IMEI Spare 3A35970214773803
IMEI SV 3335970214773813F5000000
PSN 0
PSD 0000000000000000
LPSN 0
APE SW 071.005
APE Variant 071.005071.005.10.01071.005.C00.01
APE Test 10wk48v0.001_APEONLY
APE HW 256
APE ADSP 256
RETU 35
TAHVO 00
AHNE 11
RFIC |Vapaus_5.1 | Mikki_1.1
DSP ICPR82_11w16
Failed to read info -> Failed to read SP info
SX4 Authorization / SD Repair Procedure Started....
"08C0010BEE8E0344650F549A8ED7D75CC7156AD1.C0002CA6 " Exists, That is good...
MCU Date 02-06-11
Reading Security Block...
645_353792041778338_09112012_190150.SecurityBlock. PM"
SX4 Status: Not authorized (74)
Started mutual authenthication with card...
Receiving Phone Seed 1...
Phone Seed 1 Received
Sending calculated Data 1, and expecting Seed 2...
Calculated Data 1 accepted, Phone Seed 2 Received
Superdongle Key is probably CORRUPTED, Writing custom keys...
Received SD Keys from box, writing to phone...
Superdongle Key ACCEPTED OK !
Sending calculated Data 2
Calculated Data 2 sent, Checking Authorization Status again
Authorization successfully finished!
Looking for Virgin PM In Database...
Found, writing...
[1,0] Written, Length: 116 bytes, Status: OK
[1,2] Written, Length: 12 bytes, Status: OK
[1,4] Written, Length: 112 bytes, Status: OK
[1,6] Written, Length: 12 bytes, Status: OK
[1,7] Written, Length: 216 bytes, Status: OK
[1,8] Written, Length: 112 bytes, Status: OK
[1,13] Written, Length: 12 bytes, Status: OK
[1,16] Written, Length: 208 bytes, Status: OK
[1,18] Written, Length: 208 bytes, Status: OK
[1,20] Written, Length: 208 bytes, Status: OK
[1,22] Written, Length: 16 bytes, Status: OK
[1,23] Written, Length: 4 bytes, Status: OK
[1,24] Written, Length: 84 bytes, Status: OK
[1,26] Written, Length: 112 bytes, Status: OK
[1,28] Written, Length: 12 bytes, Status: OK
[1,29] Written, Length: 12 bytes, Status: OK
[1,31] Written, Length: 208 bytes, Status: OK
[1,33] Written, Length: 36 bytes, Status: OK
[1,34] Written, Length: 376 bytes, Status: OK
[1,35] Written, Length: 16 bytes, Status: OK
[1,39] Written, Length: 36 bytes, Status: OK
[1,40] Written, Length: 16 bytes, Status: OK
[1,41] Written, Length: 184 bytes, Status: OK
[1,42] Written, Length: 4 bytes, Status: OK
[1,43] Written, Length: 36 bytes, Status: OK
[1,44] Written, Length: 184 bytes, Status: OK
[1,45] Written, Length: 184 bytes, Status: OK
[2,0] Written, Length: 2080 bytes, Status: OK
[309,0] Written, Length: 4 bytes, Status: OK
[309,1] Written, Length: 4 bytes, Status: OK
[309,2] Written, Length: 12 bytes, Status: OK
[309,3] Written, Length: 36 bytes, Status: OK
[309,4] Written, Length: 12 bytes, Status: OK
[309,7] Written, Length: 12 bytes, Status: OK
[309,17] Written, Length: 12 bytes, Status: OK
Write PM Finished, Record written OK: 35, Record written NOT OK: 0
MCU Date 02-06-11
PSN 0
LPSN 0
APE SW 071.005
APE HW 256
APE ADSP 256
RETU 35
TAHVO 00
AHNE 11
DSP ICPR82_11w16
Failed to read info -> Failed to read SP info becose sim lock is damege
Here is self test
Selftests to proceed: 42
Passed ST_SLEEP_X_LOOP_TEST
Passed ST_UEM_CBUS_IF_TEST
Passed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Failed ST_SIM_LOCK_TEST
Passed ST_SECURITY_TEST
Passed ST_PWR_KEY_TEST
Passed ST_CURRENT_CONS_TEST
Passed ST_HOOKINT_TEST
Passed ST_BTEMP_TEST
Passed ST_MBUS_RX_TX_LOOP_TEST
Passed ST_KELVIN_BATVOLTAGE_TEST
Passed ST_KELVIN_VIBRA_TEST
Passed ST_KELVIN_CAPACITOR_TEST
Passed ST_KELVIN_MISC_TEST
Failed ST_KELVIN_CHARGING_TEST
Passed ST_KELVIN_AUDIO_TEST
Passed ST_KELVIN_XEAR_TEST
Passed ST_USB_CHARGING_TEST
Passed ST_DIGIMIC_TEST
Passed ST_RAM_IF_TEST
Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST
Passed ST_CDSP_RF_BB_IF_TEST
Passed ST_CDSP_RF_SUPPLY_TEST
Passed ST_CDSP_TX_IQ_TEST
Passed ST_CDSP_TXC_DATA_TEST
Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Sending User Abort Signal...
CBUS Request Error -> User abort
Failed to make Selftests -> Phone is not responding for Selftest Request
so I flash it without deffault file and problem sloved
Page generated in 0.26324 seconds with 8 queries
