01-31-2013, 08:02 | #1 (permalink) |
Insane Poster Join Date: Aug 2002
Member: 14677 Status: Offline Thanks Meter: 1 | c7 dead after flash windows xp box updated to latest version flashing via usb initially tried to update the handset [Nokia c7 - rm-675], using a usb cable as i have done so in the past. handset was working initially tried using two different flash images rpl and pm backed up method 1 111.030.0609 - original image for the handset product code the result is the phone went completely dead method two i ticked skip erase and flashed again using same flash image also tried the latest flash image 111.040.1511 result nokia logo just blinking i seem to be getting processing flash image failed. group erase failed see pic for details any help appreciated https://www.dropbox.com/s/z4q1b60udx6bovu/uno.JPG https://www.dropbox.com/s/nnkwb0cm8eq445v/dos.JPG |
01-31-2013, 20:31 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | ur uploaded images may be deleted ! btw what was d previous version of ur phone before flash ? did u try to flash ur set with another version using same product code ? |
02-01-2013, 08:25 | #3 (permalink) |
Member: 14677 Status: Offline Thanks Meter: 1 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:00, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B00xxxxx HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 5.00v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.77v PASSED VBAT Voltage 0.04v PASSED VBAT Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.86v PASSED Box VPP disabled VPP Voltage 0.02v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.1023GB Avaiable Virtual Memory: 1.894GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Phone not detected at USB -> Timeout, no any compatible USB device detected. Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0D70020A28A703445AC1434AC54602EA9B9D109C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: Single Line 8Bit Prepare phone failed with message -> Not found required CMT Secondary Loader Failed to Create RPL from phone -> Failed to Boot / Prepare Phone RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing RM-675_111.030.0609_79u_prd.core.fpsx (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0D70020A28A703445AC1434AC54602EA9B9D109C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-675_111.030.0609_79u_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND EraseArea[0,CMT]: 0x00DC0000-0x0E97FFFF, ONENAND EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 2.109s Processing Flash Image Failed -> Group Erase failed Failed to Process all Image files -> Failed to process RM-675_111.030.0609_79u_prd.core.fpsx |
The Following User Says Thank You to michaelpas For This Useful Post: |
02-01-2013, 08:43 | #4 (permalink) |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | bro its ur interface problem change us b cable try again we r also same time face to like this problem .or try fbus cable .don,t worry |
The Following User Says Thank You to ihsan.khan.gsm For This Useful Post: |
02-01-2013, 08:46 | #5 (permalink) | |
Freak Poster Join Date: Nov 2012 Location: BUTUAN CITY
Member: 1844948 Status: Offline Sonork: 12151984 Thanks Meter: 25 | Quote:
02-01-2013, 15:11 | #6 (permalink) |
Member: 14677 Status: Offline Thanks Meter: 1 | managed to flash now i get Phone failed to start, contact the retailer Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:00, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B000xxxx HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 4.95v PASSED MCU Voltage 3.26v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.03v PASSED VBAT Voltage 4.91v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.86v PASSED Box VPP disabled VPP Voltage 0.04v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 870.956MB Avaiable Virtual Memory: 1.871GB Avaiable Pagefile: 2.752GB Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Documents and Settings\All Users\Application Data\Nokia\Packages\Products\... Found 1 products, Filtering BB5 Products - wait... 1 Products left after filtering. Ready. Retrieving Variants for Product RM-675 - wait... 1 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Phone not detected at USB -> Timeout, no any compatible USB device detected. Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0D70020A28A703445AC1434AC54602EA9B9D109C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F APE Subsystem Not Found Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found CMT PARTNERC Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing RM-675_111.030.0609_79u_prd.core.fpsx (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0D70020A28A703445AC1434AC54602EA9B9D109C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-675_111.030.0609_79u_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND EraseArea[0,CMT]: 0x00DC0000-0x0E97FFFF, ONENAND EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 2.141s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT SOS+DECOMP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS+IVE3A Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 134.265s Flashing Speed: 7504.70 kBit/S Processing RM-675_111.030.0609_79u_prd.core.fpsx (APE)... Processing RM-675_111.030.0609_01.01_Euro1_79u_prd.rofs2.fpsx (CMT)... RM-675_111.030.0609_01.01_Euro1_79u_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x09F40000-0x0DA7FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.266s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 57.172s Flashing Speed: 7701.78 kBit/S Processing RM-675_111.030.0609_01.01_Euro1_79u_prd.rofs2.fpsx (APE)... Processing RM-675_111.030.0609_248.06_default_79u.2011.44_prd.ro fs3.fpsx (CMT)... RM-675_111.030.0609_248.06_default_79u.2011.44_prd.ro fs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x01378000-0x0139FFFF, ONENAND EraseArea[0,CMT]: 0x0DA80000-0x0E97FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.125s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Writing CMT SOS+IVE3B Certificate... Programming Status OK! All blocks written OK! Time taken 1.687s Flashing Speed: 5288.39 kBit/S Processing RM-675_111.030.0609_248.06_default_79u.2011.44_prd.ro fs3.fpsx (APE)... Processing RM-675_111.030.0609_248.06_default_79u.2011.44.uda.fp sx (CMT)... RM-675_111.030.0609_248.06_default_79u.2011.44.uda.fp sx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x0E980000-0x2E0FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 2.234s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 258.15s Flashing Speed: 7555.36 kBit/S Processing RM-675_111.030.0609_248.06_default_79u.2011.44.uda.fp sx (APE)... Processing rm675_ENO_v_0.0514_APEONLY.fpsx (CMT)... rm675_ENO_v_0.0514_APEONLY.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x008C0000-0x00DBFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.32s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 5.391s Flashing Speed: 7361.94 kBit/S Processing rm675_ENO_v_0.0514_APEONLY.fpsx (APE)... Processing RM-675_M001.25.emmc.fpsx (CMT)... RM-675_M001.25.emmc.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Sending XSR Configuration... XSR Configuration OK Partitioning... Partitioning OK Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 975.578s Flashing Speed: 7339.63 kBit/S Processing RM-675_M001.25.emmc.fpsx (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia C7-00 USB Phonet]: Port opened OK! MCU Version V 79_sr1_11w42.5 MCU Date 25-11-11 Product RM-675 (Nokia C7-00) Manufacturer (c) Nokia IMEI 12345610654321? IMEI Spare 1A32541660452301 IMEI SV 1332541660452331F3000000 PSN 10FCEABAA PSD 0000000000000000 LPSN 0 APE SW 111.030.0609 APE Variant 111.030.0609111.030.0609.01.01111.030.0609.248.06 APE Test rm675_ENO_v_0.0514_APEONLY APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 11 HW 6021 RFIC |Alli_4.3.4 DSP 79_SR1_11w42.5 Failed to read info -> Failed to read SP info Read info thread finished, continuing... Post flash tasks finished!ac Flashing successfully finished! help is appreciated, cheers |
02-02-2013, 05:35 | #7 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | ur phone imei & simlock data been f****d up . as u told above u already have rpl & pm backup , so restore them then check . & about connectivity don't use any usb hub . connect usb cable directly into ur pc usb port . |
02-02-2013, 19:04 | #9 (permalink) |
Member: 14677 Status: Offline Thanks Meter: 1 | phone switches on to nokia logo and switches off after 30 seconds heres the log Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:00, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B000xxxx HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 5.00v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.03v PASSED VBAT Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.86v PASSED Box VPP disabled VPP Voltage 0.02v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.1023GB Avaiable Virtual Memory: 1.895GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Phone not detected at USB -> Timeout, no any compatible USB device detected. Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0D70020A28A703445AC1434AC54602EA9B9D109C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F APE Subsystem Not Found Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found Storing PARTNERC... Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing RM-675_111.040.1511_79u_prd.core.fpsx (CMT)... Booting CMT... [Nokia C7-00 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0D70020A28A703445AC1434AC54602EA9B9D109C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-675_111.040.1511_79u_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND EraseArea[0,CMT]: 0x00DC0000-0x0E97FFFF, ONENAND EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 2.109s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT SOS+DECOMP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS+IVE3A Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 19.672s Flashing Speed: 52557.96 kBit/S Processing RM-675_111.040.1511_79u_prd.core.fpsx (APE)... Processing RM-675_111.040.1511_01.01_Euro1_79u_prd.rofs2.fpsx (CMT)... RM-675_111.040.1511_01.01_Euro1_79u_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x09F40000-0x0DA7FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.281s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 7.218s Flashing Speed: 64804.53 kBit/S Processing RM-675_111.040.1511_01.01_Euro1_79u_prd.rofs2.fpsx (APE)... Processing RM-675_111.040.1511_C00.01_79u_prd.rofs3.fpsx (CMT)... RM-675_111.040.1511_C00.01_79u_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x01378000-0x0139FFFF, ONENAND EraseArea[0,CMT]: 0x0DA80000-0x0E97FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.140s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Writing CMT SOS+IVE3B Certificate... Programming Status OK! All blocks written OK! Time taken 0.562s Flashing Speed: 211.15 kBit/S Processing RM-675_111.040.1511_C00.01_79u_prd.rofs3.fpsx (APE)... Processing RM-675_111.040.1511_U01.01_79u.uda.fpsx (CMT)... RM-675_111.040.1511_U01.01_79u.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x0E980000-0x2E0FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 2.125s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 28.125s Flashing Speed: 64617.72 kBit/S Processing RM-675_111.040.1511_U01.01_79u.uda.fpsx (APE)... Processing rm675_ENO_v_0.0514_APEONLY.fpsx (CMT)... rm675_ENO_v_0.0514_APEONLY.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x008C0000-0x00DBFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.31s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 0.875s Flashing Speed: 45357.98 kBit/S Processing rm675_ENO_v_0.0514_APEONLY.fpsx (APE)... Processing RM-675_M001.29.emmc.fpsx (CMT)... RM-675_M001.29.emmc.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Sending XSR Configuration... XSR Configuration OK Partitioning... Partitioning OK Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 163.797s Flashing Speed: 47083.50 kBit/S Processing RM-675_M001.29.emmc.fpsx (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia C7-00 USB Phonet]: Port opened OK! MCU Version V 79_sr1_12w18.5 MCU Date 27-07-12 Product RM-675 (Nokia C7-00) Manufacturer (c) Nokia IMEI 353755048294427 Mastercode 7126314573 IMEI Spare 3A35570584924402 IMEI SV 3335570584924442F5000000 PSN CKO828284 Product Code 059D8F1 PSD 0000000000000000 LPSN 0 WLAN MAC C8DF7CCD20E6 APE SW 111.040.1511 APE Variant 111.040.1511111.040.1511.01.01111.040.1511.C00.01 APE Test rm675_ENO_v_0.0514_APEONLY APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 11 HW 6010 RFIC |Alli_4.3.4 DSP 92_12w18 Simlock Server SIMLOCK SERVER Simlock Key 2343000000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23430F Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! [Nokia C7-00 USB Phonet]: Port opened OK! [1,0] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,1] Written, Length: 94 bytes, Status: Not accepted, Code: 19 [1,2] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,4] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,6] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,7] Written, Length: 450 bytes, Status: Not accepted, Code: 19 [1,8] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,13] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,15] Written, Length: 30 bytes, Status: Not accepted, Code: 19 [1,16] Written, Length: 30 bytes, Status: Not accepted, Code: 19 [1,17] Written, Length: 30 bytes, Status: Not accepted, Code: 19 [1,18] Written, Length: 30 bytes, Status: Not accepted, Code: 19 [1,19] Written, Length: 30 bytes, Status: Not accepted, Code: 19 [1,22] Written, Length: 24 bytes, Status: Not accepted, Code: 19 [1,26] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,27] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,28] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,29] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,30] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,31] Written, Length: 24 bytes, Status: Not accepted, Code: 19 [1,32] Written, Length: 216 bytes, Status: Not accepted, Code: 19 [1,33] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,35] Written, Length: 24 bytes, Status: Not accepted, Code: 19 [1,36] Written, Length: 24 bytes, Status: Not accepted, Code: 19 [1,38] Written, Length: 216 bytes, Status: Not accepted, Code: 19 [1,39] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,40] Written, Length: 24 bytes, Status: Not accepted, Code: 19 [1,41] Written, Length: 216 bytes, Status: Not accepted, Code: 19 [1,43] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,44] Written, Length: 216 bytes, Status: Not accepted, Code: 19 [1,45] Written, Length: 216 bytes, Status: Not accepted, Code: 19 [2,0] Written, Length: 2240 bytes, Status: OK [4,1] Written, Length: 200 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,6] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,28] Written, Length: 2 bytes, Status: OK [6,0] Written, Length: 96 bytes, Status: OK [8,0] Written, Length: 2 bytes, Status: OK [8,1] Written, Length: 16 bytes, Status: OK [8,2] Written, Length: 16 bytes, Status: OK [8,3] Written, Length: 128 bytes, Status: OK [8,4] Written, Length: 128 bytes, Status: OK [8,5] Written, Length: 8 bytes, Status: OK [8,8] Written, Length: 8 bytes, Status: OK [8,10] Written, Length: 32 bytes, Status: OK [11,0] Written, Length: 4 bytes, Status: OK [11,1] Written, Length: 4 bytes, Status: OK [11,2] Written, Length: 4 bytes, Status: OK [11,3] Written, Length: 4 bytes, Status: OK [11,4] Written, Length: 1059 bytes, Status: OK [12,0] Written, Length: 8 bytes, Status: OK [26,0] Written, Length: 16 bytes, Status: OK [26,1] Written, Length: 68 bytes, Status: OK [31,4] Written, Length: 16 bytes, Status: OK [44,0] Written, Length: 1 bytes, Status: OK [50,0] Written, Length: 2 bytes, Status: OK [54,0] Written, Length: 2 bytes, Status: OK [54,2] Written, Length: 24 bytes, Status: OK [96,0] Written, Length: 2 bytes, Status: OK [96,1] Written, Length: 20 bytes, Status: OK [107,26] Written, Length: 12 bytes, Status: OK [117,0] Written, Length: 4 bytes, Status: OK [117,1] Written, Length: 3 bytes, Status: OK [117,2] Written, Length: 6 bytes, Status: OK [117,3] Written, Length: 1 bytes, Status: OK [117,5] Written, Length: 10 bytes, Status: OK [117,6] Written, Length: 8 bytes, Status: OK [117,8] Written, Length: 42 bytes, Status: OK [117,13] Written, Length: 3 bytes, Status: OK [117,14] Written, Length: 3 bytes, Status: OK [117,16] Written, Length: 40 bytes, Status: OK [120,0] Written, Length: 56 bytes, Status: OK [120,1] Written, Length: 160 bytes, Status: OK [120,2] Written, Length: 130 bytes, Status: OK [120,3] Written, Length: 112 bytes, Status: OK [122,0] Written, Length: 2 bytes, Status: OK [153,0] Written, Length: 68 bytes, Status: OK [153,1] Written, Length: 68 bytes, Status: OK [153,2] Written, Length: 68 bytes, Status: OK [153,3] Written, Length: 68 bytes, Status: OK [153,4] Written, Length: 68 bytes, Status: OK [153,5] Written, Length: 68 bytes, Status: OK [193,2] Written, Length: 8 bytes, Status: OK [193,3] Written, Length: 32 bytes, Status: OK [193,4] Written, Length: 32 bytes, Status: OK [193,9] Written, Length: 64 bytes, Status: OK [217,0] Written, Length: 32 bytes, Status: OK [239,0] Written, Length: 2 bytes, Status: OK [239,1] Written, Length: 3407 bytes, Status: OK [239,2] Written, Length: 3407 bytes, Status: OK [239,3] Written, Length: 3407 bytes, Status: OK [239,4] Written, Length: 3407 bytes, Status: OK [239,5] Written, Length: 3407 bytes, Status: OK [239,6] Written, Length: 218 bytes, Status: OK [291,0] Written, Length: 92 bytes, Status: OK [308,0] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19 [308,3] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,4] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,6] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,7] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,9] Written, Length: 40 bytes, Status: Not accepted, Code: 19 [309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [309,1] Written, Length: 2 bytes, Status: Not accepted, Code: 19 [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,3] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [309,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,7] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,17] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [313,0] Written, Length: 800 bytes, Status: OK [322,0] Written, Length: 1 bytes, Status: OK [327,0] Written, Length: 2 bytes, Status: OK [329,0] Written, Length: 8392 bytes, Status: OK [334,0] Written, Length: 1 bytes, Status: OK [341,0] Written, Length: 1 bytes, Status: OK [341,3] Written, Length: 4 bytes, Status: OK [341,4] Written, Length: 4516 bytes, Status: OK [341,10] Written, Length: 4 bytes, Status: OK [341,11] Written, Length: 1972 bytes, Status: OK [354,0] Written, Length: 13 bytes, Status: OK [356,0] Written, Length: 2 bytes, Status: OK [360,0] Written, Length: 1 bytes, Status: OK [360,1] Written, Length: 2 bytes, Status: OK [369,0] Written, Length: 40 bytes, Status: OK [382,1] Written, Length: 4 bytes, Status: OK [388,0] Written, Length: 4 bytes, Status: OK [395,0] Written, Length: 16 bytes, Status: OK Write PM Finished, Record written OK: 85, Record written NOT OK: 45 [Nokia C7-00 USB Phonet]: Port opened OK! MCU Version V 79_sr1_12w18.5 MCU Date 27-07-12 Product RM-675 (Nokia C7-00) Manufacturer (c) Nokia IMEI 353755048294427 Mastercode 7126314573 IMEI Spare 3A35570584924402 IMEI SV 3335570584924442F5000000 PSN CKO695841 Product Code 059D8F1 Module Code 0204505 Basic Product Code 0595319 PSD 0000000000000000 LPSN 0 WLAN MAC C8DF7CCD20E6 APE SW 111.040.1511 APE Variant 111.040.1511111.040.1511.01.01111.040.1511.C00.01 APE Test rm675_ENO_v_0.0514_APEONLY APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 11 HW 6003 RFIC |Alli_4.3.4 DSP 92_12w18 Failed to read info -> Failed to read SP info [Nokia C7-00 USB Phonet]: Port opened OK! MCU Version V 79_sr1_12w18.5 MCU Date 27-07-12 Product RM-675 (Nokia C7-00) Manufacturer (c) Nokia IMEI 353755048294427 Mastercode 7126314573 IMEI Spare 3A35570584924402 IMEI SV 3335570584924442F5000000 PSN CKO695841 Product Code 059D8F1 Module Code 0204505 Basic Product Code 0595319 PSD 0000000000000000 LPSN 0 WLAN MAC C8DF7CCD20E6 APE SW 111.040.1511 APE Variant 111.040.1511111.040.1511.01.01111.040.1511.C00.01 APE Test rm675_ENO_v_0.0514_APEONLY APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 11 HW 6003 RFIC |Alli_4.3.4 DSP 92_12w18 Failed to read info -> Failed to read SP info Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... [Nokia C7-00 USB Phonet]: Port opened OK! Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Handling as SL3 Simlock Data Handling as SIMLOCK1 Format Reading Security Block... Security block OK and saved to "RM-675_353755048294427_02022013_165552.SecurityBlock. PM" 15 Digits NCK Found Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key ACCEPTED OK ! Writing WMDRM PD Data... WMDRM PD Data ACCEPTED OK ! Processing FLASHBUS Part... Booting CMT... [Nokia C7-00 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 0D70020A28A703445AC1434AC54602EA9B9D109C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F APE Subsystem Not Found CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written CMT PARTNERC Erased CMT PARTNERC Written Restarting MCU... Write RPL Finished! Reading SL3 LOG File... [Nokia C7-00 USB Phonet]: Port opened OK! MCU Version V 79_sr1_12w18.5 MCU Date 27-07-12 Product RM-675 (Nokia C7-00) Manufacturer (c) Nokia IMEI 353755048294427 Mastercode 7126314573 Analyzing Profile Bits... Phone can be NCK unlocked using KEYPAD Phone can be NCK unlocked using FBUS 15 Digits NCK Found "0D70020A28A703445AC1434AC54602EA9B9D109C.B0001199 " Exists, That is good... Success! all suggestions appreciated ... cheers |
