09-21-2010, 08:58 | #2 (permalink) |
No Life Poster Join Date: Oct 2009 Age: 37
Member: 1149013 Status: Offline Thanks Meter: 247 | flsh problem flsh done but not power on phone Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.46, (Jul 24 2010 23:54:36, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0000081 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D100002A Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.17v PASSED MCU Voltage 3.25v PASSED Core Voltage 1.81v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.08v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: FALSE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 97 products, Filtering DCT4 Products - wait... 0 Products left after filtering. Ready. Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 97 products, Filtering DCT4 Products - wait... 0 Products left after filtering. Ready. Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Processing pre-flash tasks... Pre-flash tasks finished Checking rh125_003.610... 28 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [PBL] : SE0_091125 F11 [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh125_r03.610.fls"... Sending Certificate... Certificate Accepted Erasing 0x00800000-0x00A0FFFF... Erasing 0x00C60000-0x00EAFFFF... Erasing 0x00FFC000-0x00FFFFFF... Flashing at 0x00800000... Flashed 2162688 bytes OK Flashing at 0x00C60000... Flashed 2074112 bytes OK Flashing at 0x00FFC000... Flashed 64 bytes OK Box VPP disabled Checking rh1250_nai03.61ej... 26 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [PBL] : SE0_091125 F11 [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh1250_nai03.61ej.fls"... Sending Certificate... Certificate Accepted Erasing 0x00EB0000-0x00F7FFFF... Flashing at 0x00EB0000... Flashed 324480 bytes OK Box VPP disabled Checking rh125_003.61ej... 26 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [PBL] : SE0_091125 F11 [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh125_003.61ej.fls"... Sending Certificate... Certificate Accepted Erasing 0x00210000-0x0045FFFF... Flashing at 0x00210000... Flashed 2105088 bytes OK Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! |
